Home » Eclipse Projects » Eclipse Platform » deployed my gmf plug-in
deployed my gmf plug-in [message #326304] Fri, 14 March 2008 07:27 Go to next message
Originally posted by: pegasobros.tiscali.it
I've a big problem. I've created my gmf plug-in and I have to building and
export. I've used File>Export>Deployable plug-ins and fragments and I've
created my .zip file. Then I unzip this file in my eclipse folder "plugin"
but when I open Eclipse nothing is change! why? my plug-in works correctly
if I launch in development mode!!! Please, help me!!!!
Daniele
Re: deployed my gmf plug-in [message #326310 is a reply to message #326304] Fri, 14 March 2008 08:22 Go to previous message
Daniele,
Run eclipse.exe -clean -debug and check the Error Log view of the
contents of the <workspace>/.metadata/.log file to look for problems.
The build.properties file in each plugin has important contents that
might cause problems if they don't specify important files that need to
be deployed, so that's another potential source of problems.
Daniele Persechino wrote:
> and export. I've used File>Export>Deployable plug-ins and fragments
> and I've created my .zip file. Then I unzip this file in my eclipse
> folder "plugin" but when I open Eclipse nothing is change! why? my
> plug-in works correctly if I launch in development mode!!! Please,
> help me!!!!
> Daniele
Previous Topic:Cannot find color setting for search hints
Next Topic:How to define commands from code
Current Time: Tue Nov 04 17:30:42 EST 2025
Powered by FUDForum. Page generated in 0.03402 seconds
