Home » Eclipse Projects » Eclipse Platform » Feature as "Jar"
Feature as "Jar" [message #326303] Fri, 14 March 2008 05:08 Go to next message
Hi all,
As discussed in a previous post i created my first feature last weeks.
When i exported this feature i choose to export it as a Jar (a message in
PDE export dialog said : " Jar required for update sites").
After installing this Jar feature all is working perfectly !!
Yesterday a user of this feature email me about a strange problem:
Once he adds a new feature to is Eclipse installation using the Help ->
Find and install -> Manage configuration -> Add extension location, my
feature becomes disabled !!!
I was able to reproduce the bug and check the error log :
!ENTRY org.eclipse.update.configurator 2008-03-13 11:40:30.873 !MESSAGE
Unable to find feature.xml in directory: followed by the path of my Jar
feature.
Trying to export the feature as a directory (as all Eclipse features) fix
the problem ...
Have you any explication for this ?
Manu
http://manuelselva.wordpress.com
Re: Feature as "Jar" [message #326309 is a reply to message #326303] Fri, 14 March 2008 08:18 Go to previous messageGo to next message
Manuel,
Perhaps there's an issue with the bin.includes of the build.properties.
Are you sure the feature.xml is properly ending up in your final jar?
Manuel Selva wrote:
> Hi all,
> in PDE export dialog said : " Jar required for update sites").
> -> Find and install -> Manage configuration -> Add extension location,
> my feature becomes disabled !!!
> !MESSAGE Unable to find feature.xml in directory: followed by the path
> of my Jar feature.
> fix the problem ...
> Thanks
> Manu
Re: Feature as "Jar" [message #326312 is a reply to message #326309] Fri, 14 March 2008 08:51 Go to previous message
Hi Ed,
Ye sit is I checked that. What is very strange is that before any
extension location is added my feature works perfectly ...
Manu
Previous Topic:How to define commands from code
Next Topic:IFileStore -> IFile
Current Time: Fri Aug 22 21:46:41 EDT 2025
Powered by FUDForum. Page generated in 0.25008 seconds
