| Support for Multiple Linked files. [message #326250] |
Thu, 13 March 2008 02:06  |
Hi guys,
Is there a plan to support multiple files if you just want to link to them?
Instead of have to do this one by one. (File->New->Advanced->Link to File
System)
Thanks!
Mark
| Re: Support for Multiple Linked files. [message #326713 is a reply to message #326344] |
Sun, 30 March 2008 23:10  |
Originally posted by: rapha.d.gmx.de
Hi Mark,
I had pretty much the same problem. In the beginning I was thinking
about reusing the existing 'Import from Filesystem' dialog. But what we
do right now is linking the whole folder and using WorkingSets to
fianlly select the files we want to see.
Best,
Raphael
Mark Espiritu schrieb:
> Hi Eric,
> Thanks for the reply.
> I was thinking that if multiple files are selected, that we would just use
> the target filenames as the logical names.
> Anyway, I'm thinking now if my suggestion doesn't cover all cases (like you
> mentioned) and/or if we we really need to cover those cases.
> The real difficulty we are encountering is just the sheer number of linked
> files we have to individually link to by hand.
> Perhaps the community can give suggestions?
> Thanks!
> MarkE
> "Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
> news:frefva$ift$1@build.eclipse.org...
>> Mark Espiritu wrote:
>>> Hi Eric,
>>> Sorry for the vague description. Let me try to clarify. The dialog that
>>> pops up after hitting the browse button does not seem to allow multiple
>>> selection.
>>> It would be very convenient to be able to select multiple files that you
>>> want to link to instead of having to repeat the prcedure for each one.
>>> What do you think?
>> It won't really work, because when you create a linked resource it is
>> assigned a "logical" name (that you specify) that is used to refer to it
>> in the project/workspace. If multiple selection was allowed, the UI would
>> get complex because you'd have to have a way to specify the logical names
>> for each of them.
>> Eric
FUDForum. Page generated in 0.10175 seconds
