Home » Eclipse Projects » Eclipse Platform » EFS question ...
| EFS question ... [message #326232] |
Wed, 12 March 2008 10:06   |
Eclipse User  |
Hi all, hope this is the right forum to ask questions about EFS .
I'm trying to build an example that with the EFS helps will make me build a
view with a representation of what is contained in my DB .
I did actually manage to do it but there is something that I don't not
really like .
When I start my test it starts to ask information about the whole tree - the
problem is that this operation can take a long time if the DB contains more
than a 1000 object ..
Is there a way to (for example) just read the information about the first
"folder" and only once it get expanded read it . I do understand that
eclipse must probably cache information about name and structure . but this
really make totally not usable .
Kar
| Re: EFS question ... [message #326240 is a reply to message #326239] |
Wed, 12 March 2008 12:37    |
Eclipse User  |
--------------040202050005050507070208
Kar,
This looks like the right way.  How are you creating the file store
instance that you pass to the editor?
KarSc wrote:
> Hi Ed and thanks ...
> in the meantime I did actually create a simple treeview with a basic with
> viewer.setLabelProvider(new WorkbenchLabelProvider());
> viewer.setContentProvider(new BaseWorkbenchContentProvider());
> so I get back my tree for free (no icon no anything but it's a starting
> point) and items are only loaded when I do expand the folder.
> The trouble is ... what shall I do to be able to open an editor on the item
> this was free when a linked the "dbfilesystem" to the resource view ...
> What shall I do now?
> I have tried using what follows
> IEditorDescriptor desc2 =
>  PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or(fileStore.getName());
> try
> page.openEditor(new FileStoreEditorInput(fileStore), desc2.getId());
> catch (PartInitException e)
> // TODO Auto-generated catch block
> e.printStackTrace();
> but I don't get anything ...
> can u point me in the right direction or what is the class of the navigator
> view so I could probably check what does it do (bear in mind that I know
> very little of EFS and I haven't done any cache of the db file locally, but
> just implemented the get input/output stream on the filestore)
> thanks
> Kar
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fr8pgc$464$1@build.eclipse.org...
>> Kar,
>> I'm not sure this is entirely avoidable.  Eclipse does need to know the
>> time stamp for each resource the first time so that it can properly do a
>> refresh should the contents of the tree change outside the control of the
>> IResource APIs.  What specifically is driving the full walk.  Is it indeed
>> this need for an initial sync?  I assume it's not actually loading files
>> but just needs to understand the full folder structure.  If that indeed is
>> taking an unusably long time, you probably need to rethink your design
>> where the user needs to take explicit actions to bring folders into
>> view...
>>> a view with a representation of what is contained in my DB .
>>> really like .
>>> the problem is that this operation can take a long time if the DB
>>> contains more than a 1000 object ..
>>> this really make totally not usable .
>>> Thanks
>>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
instance that you pass to the editor?<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:fr8vp8$9na$1@build.eclipse.org" type="cite">
  <pre wrap="">Hi Ed and thanks ...
try
thanks
Kar
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fr8pgc$464$1@build.eclipse.org">news:fr8pgc$464$1@build.eclipse.org</a>...
  </pre>
  <blockquote type="cite">
    <pre wrap="">Kar,
view...
KarSc wrote:
    </pre>
      <pre wrap="">Hi all, hope this is the right forum to ask questions about EFS .
really like .
Kar
      </pre>
    </blockquote>
  </blockquote>
  <pre wrap=""><!---->
  </pre>
</blockquote>
<br>
</body>
</html>
--------------040202050005050507070208--
| Re: EFS question ... [message #326271 is a reply to message #326260] |
Thu, 13 March 2008 08:56    |
Eclipse User  |
--------------060104060402080606050700
Kar,
In that case it's using an IFile and for sure the editor supports that.
KarSc wrote:
> The weird thing is that ... if I do open the file from the mounted EFS (from
> resource view) - it works fine ...
> or at least I can able to open the file using the xml editor (but when I
> save it the document goes in out of sync ... but it has been saved correctly
> ... just pressing F5 I get the editor back ...)
> this whole thing is driving me crazy ...
> hope u can help me
> Thanks
> Kar
> "KarSc" <carmeloscala@hotmail.com> wrote in message
> news:fraste$44k$1@build.eclipse.org...
>> viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
>> and on the double click on the tree item i'm just opening the editor with
>> IDE.openEditorOnFileStore(page, fileStore);
>> i did actually discovered that the problem is different ...
>> i cannot open only xml file ...  follows the exception ....
>> thanks
>> kar
>> org.eclipse.ui.PartInitException: Editor could not be initialized.
>> at
>>  org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3028)
>> at
>>  org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
>> at
>>  org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2617)
>> at
>>  org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:186)
>> at
>>  org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:160)
>> at
>>  org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:378)
>> at
>>  org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:554)
>> at
>>  org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
>> at
>>  org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
>> at
>>  org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
>> at
>>  org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
>> at  org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
>> at
>>  org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
>> at
>>  org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
>> at
>>  org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
>> at
>>  org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
>> at
>>  org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
>> at  org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
>> at  org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
>> at  org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
>> at  org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
>> at
>>  org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
>> at
>>  org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
>> at
>>  org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
>> at
>>  org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
>> at
>>  org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
>> at
>>  org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
>> at  org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
>> at  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
>> at
>>  org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
>> at testefs.views.SampleView$4$1.run(SampleView.java:399)
>> news:fr90rj$ihq$1@build.eclipse.org...
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
In that case it's using an IFile and for sure the editor supports that.<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frau4f$m4n$1@build.eclipse.org" type="cite">
  <pre wrap="">The weird thing is that ... if I do open the file from the mounted EFS (from
.... just pressing F5 I get the editor back ...)
hope u can help me
Kar
"KarSc" <a class="moz-txt-link-rfc2396E" href="mailto:carmeloscala@hotmail.com"><carmeloscala@hotmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fraste$44k$1@build.eclipse.org">news:fraste$44k$1@build.eclipse.org</a>...
  </pre>
    <pre wrap="">viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
thanks
kar
<a class="moz-txt-link-freetext" href="news:fr90rj$ihq$1@build.eclipse.org">news:fr90rj$ihq$1@build.eclipse.org</a>...
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
    </pre>
  </blockquote>
  </pre>
</blockquote>
<br>
</body>
</html>
--------------060104060402080606050700--
| Re: EFS question ... [message #326272 is a reply to message #326263] |
Thu, 13 March 2008 08:58    |
Eclipse User  |
--------------080101090106060009070802
Kar,
It kind of circles back to your original problem.  To make it an IFile,
you need to use EFS as the backing for a view on your database.  Maybe
ask the WTP newsgroup about support for different types of input (if
debugging the stack trace doesn't make that clear by inspection).
KarSc wrote:
> checking the ResourceNavigotor I can see that it will actually work on a
> IFile ...
> still what shall I do to obtain an IFile from a filestore :-S
> Kar
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
debugging the stack trace doesn't make that clear by inspection).<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frb1l9$a1u$1@build.eclipse.org" type="cite">
  <pre wrap="">checking the ResourceNavigotor I can see that it will actually work on a
IFile ...
Kar
  </pre>
thanks
kar
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
    </pre>
  </blockquote>
  </pre>
</blockquote>
<br>
</body>
</html>
--------------080101090106060009070802--
| Re: EFS question ... [message #326276 is a reply to message #326269] |
Thu, 13 March 2008 10:17   |
Eclipse User  |
Hi Ed and really thanks for all ur help ...
I guess at this point is better for me to stop ... at least since I will
fully understand what I can do to actually get an IFile from an EFS object
I could try to dig and solve the problem for a structure text editor but I'm
sure that the trouble will rise again once someone will use a different
plug-in inside the RCP application for editing any other kind of file .
I did have a look at the Workspace / Workspace root and a bunch of other
classes inside the Resources Plugin but it's a really mess ...
Still thanks for ur help
Ciao
Kar
news:frb880$q1t$1@build.eclipse.org...
> Kar,
> Not all editors support the different input types.  :-(  Use the debugger
> to see what the structured text editor is doing with its input.
>> thanks
>> kar
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>>  at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> indeed
>> is
>> view...
>> really like .
>> Thanks
>> Kar
 Current Time: Tue Nov 04 02:11:54 EST 2025
 Powered by  FUDForum. Page generated in 0.57188 seconds
