Home » Eclipse Projects » Eclipse Platform » How to add marker without using resources
How to add marker without using resources [message #326218] Wed, 12 March 2008 01:53 Go to next message
Originally posted by: avikram.novell.com
I have to add Problem Markers on my XML Source Viewer which is not anyway
attached to a resource. How can I have achieve this?
I have seen the Spell check markers in my source viewer, so I understand
that there should be a way to add other markers as well!
Aditya
Re: How to add marker without using resources [message #326226 is a reply to message #326218] Wed, 12 March 2008 08:29 Go to previous messageGo to next message
Aditya,
I don't think you can. IMarker is a resource thing. I suppose of
course you can have decorators like the ones IMarkers produce. I'm not
sure how to do those, but there ought to be code in Eclipse itself you
could track down for examples. Maybe someone will give a pointer to
some source code that decorates the left margin of an editor...
aditya vikram wrote:
> Aditya
Re: How to add marker without using resources [message #326233 is a reply to message #326218] Wed, 12 March 2008 10:22 Go to previous messageGo to next message
Originally posted by: valere.fedronic.ext.streamezzo.com
What you see in the source viewer is not a marker, it's an annotation.
The object responsible of the creation and update of annotations is the
IAnnotationModel. In the TextEditor the annotation model watch for
markers in the edited file and then create an annotation for each marker
(ResourceMarkerAnnotationModel).
You just need to create your custom annotation (like SpellingAnnotation).
When you detect a problem on the edited file, add a new annotation :
ISourceViewer#getAnnotationModel()#addAnnotation(new
CustomAnnotation(),new PositionOffsett());
Your annotation can be painted by the AnnotationPainter, you just need
to define the presentation specification of your annotation using the
'org.eclipse.ui.editors.markerAnnotationSpecification' extension point.
Valère.
aditya vikram a écrit :
> Aditya
Re: How to add marker without using resources [message #326268 is a reply to message #326233] Thu, 13 March 2008 09:00 Go to previous message
valere fedronic wrote:
Thanks Valere, Ed, I'll try working on the annoatations & decorators as you
suggested.
--aditya
Previous Topic:how to create a folder in package explorer
Next Topic:multi-width images in Tree
Current Time: Mon Jul 21 23:51:52 EDT 2025
Powered by FUDForum. Page generated in 0.15643 seconds
