Home » Eclipse Projects » Eclipse Platform » Error marking
Error marking [message #326210] Tue, 11 March 2008 15:30 Go to next message
I have developed an editor.If a user types something which is not valid I
want to mark that as an error.How do I do this? I have checked the code
for the XML editor and it is using a SAX Parser.Do I have to design my own
parser or can I use an existing one.
Junaid.
Re: Error marking [message #326212 is a reply to message #326210] Tue, 11 March 2008 15:53 Go to previous messageGo to next message
Junaid,
You'll want to learn about IMarkers. You can use whatever mechanism
you want for finding locations within your source files. If it's XML,
likely you'll want to use SAX's locator mechanism.
Junaid wrote:
> valid I want to mark that as an error.How do I do this? I have checked
> the code for the XML editor and it is using a SAX Parser.Do I have to
> design my own parser or can I use an existing one.
> Thanks
> Junaid.
Re: Error marking [message #326246 is a reply to message #326212] Wed, 12 March 2008 18:26 Go to previous messageGo to next message
Hi Ed,
Can you give me the url to few examples so that I can learn from them.
Can you tell me how does the java editor marks errors when a semicolon is
missing at the end of a line.
Junaid
Re: Error marking [message #326247 is a reply to message #326246] Wed, 12 March 2008 19:17 Go to previous message
Junaid,
See the post a few notes down about "How to add a marker without using
resources"? There's good information in that note chain...
As far as I know, the Java editor uses IMarkers. In order to give you a
URL, I would just do some google searches and stuff like that, so it's
probably just as well you do that yourself...
Junaid wrote:
> Hi Ed,
> is missing at the end of a line.
> Thanks Junaid
Previous Topic:Programatically detect if project needs building
Next Topic:how to position toolbar button in the main toolbar
Current Time: Tue Jul 08 09:37:21 EDT 2025
Powered by FUDForum. Page generated in 0.04531 seconds
