Home » Eclipse Projects » Eclipse Platform » Software update doesn't work
Software update doesn't work [message #326192] Tue, 11 March 2008 05:48 Go to next message
wenn try to start an update via "Help - >Software updates -> Find and
install..", nothing happens
The error log shows: "Unhandled event loop exception"
Stack trace looks like this:
java.lang.NoClassDefFoundError: org/eclipse/update/ui/UpdateManagerUI
org.eclipse.ui.internal.ide.update.InstallWizardAction$1.run (InstallWizardAction.java:47)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.ide.update.InstallWizardAction.openI nstaller(InstallWizardAction.java:45)
org.eclipse.ui.internal.ide.update.InstallWizardAction.run(I nstallWizardAction.java:41)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Any hints? Thx.
Re: Software update doesn't work [message #326198 is a reply to message #326192] Tue, 11 March 2008 08:20 Go to previous messageGo to next message
Simon,
Sounds like a screwed up installation to me. I can't imagine how the
update manager itself would be missing. Maybe if you rerun with
eclipse.exe -clean -debug, the error log might have more detailed
information about what might be missing from your installation...
Simon wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any hints? Thx.
Re: Software update doesn't work [message #326200 is a reply to message #326198] Tue, 11 March 2008 08:53 Go to previous messageGo to next message
Hi Ed,
The console output shows (but Eclipse seems to start "normally"):
C:\Programme\Eclipse3.3\eclipse>eclipsec.exe -clean -debug
Start VM: -Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256M
-Djava.class.path=C:\Programme\Eclipse3.3\eclipse\plugins\or g.eclipse.equinox.la
uncher_1.0.1.R33x_v20070828.jar
-os win32
-ws win32
-arch x86
-showsplash
C:\Programme\Eclipse3.3\eclipse\\plugins\org.eclipse.platfor m_3.3.2.R33x_v20071022\splash.bmp
-launcher C:\Programme\Eclipse3.3\eclipse\eclipsec.exe
-name Eclipsec
--launcher.library
C:\Programme\Eclipse3.3\eclipse\plugins\org.eclipse.equinox. launcher.win32.win32.x86_1.0.2.R331_v20071019\eclipse_1021.d ll
-startup
C:\Programme\Eclipse3.3\eclipse\plugins\org.eclipse.equinox. launcher_1.0.1.R33x_v20070828.jar
-clean
-debug
-vm C:\Programme\Java\jre1.5.0_14\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx256m
-Djava.class.path=C:\Programme\Eclipse3.3\eclipse\plugins\or g.eclipse.equinox.launcher_1.0.1.R33x_v20070828.jar
Install location:
file:/c:/Programme/Eclipse3.3/eclipse/
Configuration file:
file:/c:/Programme/Eclipse3.3/eclipse/configuration/config.i ni loaded
Configuration location:
Framework located:
file:/c:/Programme/Eclipse3.3/eclipse/plugins/org.eclipse.os gi_3.3.1.R33x_v2
0070828.jar
Framework classpath:
0070828.jar
Splash location:
Debug options:
file:/C:/Programme/Eclipse3.3/eclipse/.options not found
Time to load bundles: 47
Starting application: 3469
Application Started: 18656
[Fatal Error] :-1:-1: Premature end of file.
The .log file shows the following:
!SESSION 2008-03-11 13:41:49.911
eclipse.buildId=M20070921-1145
java.version=1.5.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -debug
!ENTRY org.eclipse.osgi 2 0 2008-03-11 13:41:53.427
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-03-11 13:41:53.427
!MESSAGE Bundle
update@plugins /org.eclipse.jdt.apt.pluggable.core_1.0.1.R33x_v20070831-043 5.jar
[96] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core 2 0 2008-03-11 13:41:53.427
!MESSAGE Missing imported package
org.eclipse.jdt.internal.compiler.tool_0.0.0.
org.eclipse.jdt.internal.compiler.apt.dispatch_0.0.0.
org.eclipse.jdt.internal.compiler.apt.model_0.0.0.
org.eclipse.jdt.internal.compiler.apt.util_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.jdt.compiler.apt_1.0.1.R33x_v20070831-0435.jar
[98] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2008-03-11 13:41:53.427
!MESSAGE Bundle
update@plugins/org.eclipse.jdt.compiler.tool_1.0.1.v_780_R33x.jar [99] was
not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2008-03-11 13:41:53.427
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment:
JavaSE-1.6
!ENTRY org.eclipse.osgi 4 0 2008-03-11 13:41:59.317
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.update.ui (223).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.ui.UpdateUI.start() of bundle
org.eclipse.update.ui.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.update.internal.scheduler.SchedulerStartup.creat eJobChangeAdapter(SchedulerStartup.java:259)
org.eclipse.update.internal.scheduler.SchedulerStartup.start Search(SchedulerStartup.java:218)
org.eclipse.update.internal.scheduler.SchedulerStartup.sched uleUpdateJob(SchedulerStartup.java:116)
org.eclipse.update.internal.scheduler.SchedulerStartup.early Startup(SchedulerStartup.java:94)
org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartupRunnable.java:87)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.swt.widgets.Display.error(Display.java:1137)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:666 )
at org.eclipse.swt.widgets.Display.getActiveShell(Display.java: 1300)
org.eclipse.update.internal.ui.UpdateUI.getActiveWorkbenchSh ell(UpdateUI.java:78)
at org.eclipse.update.internal.ui.UpdateUI.log(UpdateUI.java:17 0)
at org.eclipse.update.internal.ui.UpdateUI.logException(UpdateU I.java:163)
at org.eclipse.update.internal.ui.UpdateUI.logException(UpdateU I.java:140)
org.eclipse.update.internal.ui.model.BookmarkUtil.parse(Book markUtil.java:44)
org.eclipse.update.internal.ui.model.UpdateModel.reset(Updat eModel.java:35)
org.eclipse.update.internal.ui.model.UpdateModel.<init>(UpdateModel.java:29)
at org.eclipse.update.internal.ui.UpdateUI.start(UpdateUI.java: 100)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 26 more
Root exception:
!ENTRY org.eclipse.ui.workbench 4 2 2008-03-11 13:41:59.411
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/update/ui/UpdateJob
!ENTRY org.eclipse.ui 4 4 2008-03-11 13:41:59.442
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.update.scheduler 4 0 2008-03-11 13:41:59.474
!MESSAGE Unable to execute early startup code for an extension
!STACK 0
Re: Software update doesn't work [message #326203 is a reply to message #326200] Tue, 11 March 2008 10:29 Go to previous messageGo to next message
--------------000505030004000200000102
Simon,
It looks like this exception causes the other problems:
To me this looks like a error in the code's logic that needs to be
fixed. I.e., it looks like the startup happens on a background thread
which is then trying to work directly with the display on that
background thread.
Probably you should open a bugzilla. The folks will need to be able to
reproduce the problem, so likely they'll need to know exactly what
you've got installed. Is this happening with a "bare version of
Eclipse". I.e., one of the zipped packages with no other plugins added?
Simon wrote:
> Hi Ed,
> -Xms40m
> -Xmx256m
> -os win32
> -ws win32
> -arch x86
> -showsplash
> -name Eclipsec
> --launcher.library
> -startup
> -clean
> -debug
> -vmargs
> -Xms40m
> -Xmx256m
> Install location:
> Configuration file:
> Framework located:
> 0070828.jar
> 0070828.jar
> Splash location:
> Debug options:
> !MESSAGE Bundle
> 13:41:53.427
> 13:41:53.427
> 13:41:53.427
> 13:41:53.427
> !MESSAGE Bundle
> !MESSAGE Bundle
> was not resolved.
> JavaSE-1.6
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 26 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
<html>
<head>
http-equiv="Content-Type">
</head>
Simon,<br>
<br>
It looks like this exception causes the other problems:<br>
<blockquote>org.eclipse.swt.SWTException: Invalid thread access
<br>
</blockquote>
fixed.
Re: Software update doesn't work [message #326204 is a reply to message #326203] Tue, 11 March 2008 11:04 Go to previous messageGo to next message
Ed,
unfortunately it's not a "bare" Eclipse as several plugins are installed
(I've worked with this installation for approx. half a year).
As this error did erase recently, maybe a misconfigured plugin causes this
error. Is there a way to uninstall/disable components by hand to isolate
the problem more precisely?
Ed Merks wrote:
> Simon,
> background thread.
> Simon wrote:
>> Hi Ed,
>> C:ProgrammeEclipse3.3eclipse>eclipsec.exe -clean -debug
>> -Xms40m
>> -Xmx256m
>> -Djava.class.path=C:ProgrammeEclipse3.3eclipsepluginsorg.ecl ipse.equinox.la
>> -os win32
>> -ws win32
>> -arch x86
>> -showsplash
C:ProgrammeEclipse3.3eclipse\pluginsorg.eclipse.platform_3.3 .2.R33x_v20071022splash.bmp
>> -launcher C:ProgrammeEclipse3.3eclipseeclipsec.exe
>> -name Eclipsec
>> --launcher.library
C:ProgrammeEclipse3.3eclipsepluginsorg.eclipse.equinox.launc her.win32.win32.x86_1.0.2.R331_v20071019eclipse_1021.dll
>> -startup
C:ProgrammeEclipse3.3eclipsepluginsorg.eclipse.equinox.launc her_1.0.1.R33x_v20070828.jar
>> -clean
>> -debug
>> -vm C:ProgrammeJavajre1.5.0_14binclientjvm.dll
>> -vmargs
>> -Xms40m
>> -Xmx256m
-Djava.class.path=C:ProgrammeEclipse3.3eclipsepluginsorg.ecl ipse.equinox.launcher_1.0.1.R33x_v20070828.jar
>> Install location:
>> Configuration file:
>> Framework located:
>> 0070828.jar
>> 0070828.jar
>> Splash location:
>> Debug options:
>> !MESSAGE Bundle
>> 13:41:53.427
>> 13:41:53.427
>> 13:41:53.427
>> 13:41:53.427
>> !MESSAGE Bundle
>> !MESSAGE Bundle
>> was not resolved.
>> JavaSE-1.6
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
Re: Software update doesn't work [message #326205 is a reply to message #326204] Tue, 11 March 2008 11:30 Go to previous messageGo to next message
Simon,
You can use Help->Software Updates->Manage Configuration and use that to
disable features. I've never tried it. I think it's always best to
restart after doing that because many if not most plugins don't handle
other plugins dynamically stopping very well...
Simon wrote:
> Ed,
> installed (I've worked with this installation for approx. half a year).
> this error. Is there a way to uninstall/disable components by hand to
> isolate the problem more precisely?
> Ed Merks wrote:
>> Simon,
>> thread which is then trying to work directly with the display on that
>> background thread.
>> to reproduce the problem, so likely they'll need to know exactly what
>> Simon wrote:
>>> Hi Ed,
>>> -Xms40m
>>> -Xmx256m
>>> -os win32
>>> -ws win32
>>> -arch x86
>>> -showsplash
>>> -name Eclipsec
>>> --launcher.library
>>> -startup
>>> -clean
>>> -debug
>>> -vmargs
>>> -Xms40m
>>> -Xmx256m
>>> Install location:
>>> Configuration file:
>>> loaded
>>> Framework located:
>>> 0070828.jar
>>> 0070828.jar
>>> Splash location:
>>> Debug options:
>>> !MESSAGE Bundle
>>> 13:41:53.427
>>> 13:41:53.427
>>> 13:41:53.427
>>> 13:41:53.427
>>> !MESSAGE Bundle
>>> !MESSAGE Bundle
>>> [99] was not resolved.
>>> JavaSE-1.6
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: Software update doesn't work [message #326219 is a reply to message #326205] Wed, 12 March 2008 03:15 Go to previous messageGo to next message
That's part of the problem. "Manage Configuration" doesn't work as well
and raises the same error.
Ed Merks wrote:
> Simon,
> Simon wrote:
>> Ed,
>> Ed Merks wrote:
>>> Simon,
>>> background thread.
>>> Simon wrote:
>>>> Hi Ed,
>>>> -Xms40m
>>>> -Xmx256m
>>>> -os win32
>>>> -ws win32
>>>> -arch x86
>>>> -showsplash
C:ProgrammeEclipse3.3eclipsepluginsorg.eclipse.platform_3.3. 2.R33x_v20071022splash.bmp
>>>> -name Eclipsec
>>>> --launcher.library
>>>> -startup
>>>> -clean
>>>> -debug
>>>> -vmargs
>>>> -Xms40m
>>>> -Xmx256m
>>>> Install location:
>>>> Configuration file:
>>>> loaded
>>>> Framework located:
>>>> 0070828.jar
>>>> 0070828.jar
>>>> Splash location:
>>>> Debug options:
>>>> !MESSAGE Bundle
>>>> 13:41:53.427
>>>> 13:41:53.427
>>>> 13:41:53.427
>>>> 13:41:53.427
>>>> !MESSAGE Bundle
>>>> !MESSAGE Bundle
>>>> JavaSE-1.6
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 26 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Software update doesn't work [message #326224 is a reply to message #326219] Wed, 12 March 2008 08:23 Go to previous messageGo to next message
Simon,
It sounds like you're kind of hosed by something that's been installed
and misbehaves. :-(
Hopefully the new P2 work will not have these kinds of issues...
> well and raises the same error.
> Ed Merks wrote:
>> Simon,
>> to disable features. I've never tried it. I think it's always best
>> to restart after doing that because many if not most plugins don't
>> handle other plugins dynamically stopping very well...
>> Simon wrote:
>>> Ed,
>>> causes this error. Is there a way to uninstall/disable components by
>>> hand to isolate the problem more precisely?
>>> Ed Merks wrote:
>>>> Simon,
>>>> that background thread.
>>>> able to reproduce the problem, so likely they'll need to know
>>>> exactly what you've got installed. Is this happening with a "bare
>>>> version of Eclipse". I.e., one of the zipped packages with no
>>>> Simon wrote:
>>>>> Hi Ed,
>>>>> -Xms40m
>>>>> -Xmx256m
>>>>> -os win32
>>>>> -ws win32
>>>>> -arch x86
>>>>> -showsplash
>>>>> -name Eclipsec
>>>>> --launcher.library
>>>>> -startup
>>>>> -clean
>>>>> -debug
>>>>> -vmargs
>>>>> -Xms40m
>>>>> -Xmx256m
>>>>> Install location:
>>>>> Configuration file:
>>>>> loaded
>>>>> Framework located:
>>>>> 0070828.jar
>>>>> 0070828.jar
>>>>> Splash location:
>>>>> Debug options:
>>>>> !MESSAGE Bundle
>>>>> 13:41:53.427
>>>>> 13:41:53.427
>>>>> 13:41:53.427
>>>>> 13:41:53.427
>>>>> !MESSAGE Bundle
>>>>> !MESSAGE Bundle
>>>>> JavaSE-1.6
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 26 more
>>>>> Root exception:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: Software update doesn't work [message #326230 is a reply to message #326219] Wed, 12 March 2008 09:21 Go to previous messageGo to next message
> Ed Merks wrote:
>> Simon,
>> Simon wrote:
>>> Ed,
I would do a search in the plugins directory and sort by date to find
the most recently added plugins. You can then delete it(or move it away)
and restart Eclipse with the -clean command-line argument to see if that
resolves the problem.
Hope this helps,
Eric
Re: Software update doesn't work [message #326234 is a reply to message #326230] Wed, 12 March 2008 10:25 Go to previous messageGo to next message
Didn't help yet, but I'm still trying.
Re: Software update doesn't work [message #326251 is a reply to message #326203] Thu, 13 March 2008 03:51 Go to previous messageGo to next message
I opened a ticket and it seems to be a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=222364
Re: Software update doesn't work [message #326349 is a reply to message #326251] Mon, 17 March 2008 05:59 Go to previous message
Fixed
Previous Topic:Update editor
Next Topic:Deleting directory fails in the 3.4M5 test suite on Windows Vista ia32.
Current Time: Sun Jul 27 08:51:52 EDT 2025
Powered by FUDForum. Page generated in 0.05473 seconds
