Home » Eclipse Projects » Eclipse Platform » Bug 182800
Bug 182800 [message #326145] Sat, 08 March 2008 11:18 Go to next message
I am currently using the 3.3.2 release and I am experiencing the problem
reported in Bug 182800.
I just downloaded 3.4M5; which contains the fix, and the problem goes away.
Unfortunately, we cannot release using a M build so is there any
work-around/hack for this problem in 3.3.2?
-AJ
Re: Bug 182800 [message #326151 is a reply to message #326145] Sat, 08 March 2008 16:02 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
AJ wrote:
3.3.2 will most likely be the last release in the 3.3 branch of Eclipse.
My only solution for you would be to try to patch a copy of the plug-in
locally and place it into your local build...
~ Chris
Re: Bug 182800 [message #326157 is a reply to message #326145] Sun, 09 March 2008 08:22 Go to previous messageGo to next message
This bug adds API so even if there would be another release in 3.3.x
this won't get back ported.
What's your problem? Do you need to original cell?
Tom
AJ schrieb:
> -AJ
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Bug 182800 [message #326158 is a reply to message #326157] Sun, 09 March 2008 08:25 Go to previous messageGo to next message
Back porting this yourself with the sources from 3.3-maint isn't very
hard though but if you describe your problem maybe there's another solution.
Tom
> Tom
> AJ schrieb:
>> problem reported in Bug 182800.
>> away.
>> Thanks,
>> -AJ
Re: Bug 182800 [message #326162 is a reply to message #326158] Sun, 09 March 2008 19:52 Go to previous message
Chris & Tom, thank you both.
Yes, I need the original cell.
I have a TableViewer and 2 buttons (plus & minus) used to add/remove rows.
I get the exception when a row is removed and then you select any other
cell on TableViewer. However, with 3.4 the exception does not occur.
-AJ
Previous Topic:Initial state of radio MenuItems
Next Topic:How is IPackageDeclaration#getSourceRange supposed to work?
Current Time: Mon Sep 01 01:38:22 EDT 2025
Powered by FUDForum. Page generated in 0.03959 seconds
