Bug 182800 [message #326145] |
Sat, 08 March 2008 11:18  |
I am currently using the 3.3.2 release and I am experiencing the problem
reported in Bug 182800.
I just downloaded 3.4M5; which contains the fix, and the problem goes away.
Unfortunately, we cannot release using a M build so is there any
work-around/hack for this problem in 3.3.2?
-AJ
Re: Bug 182800 [message #326162 is a reply to message #326158] |
Sun, 09 March 2008 19:52  |
Chris & Tom, thank you both.
Yes, I need the original cell.
I have a TableViewer and 2 buttons (plus & minus) used to add/remove rows.
I get the exception when a row is removed and then you select any other
cell on TableViewer. However, with 3.4 the exception does not occur.
-AJ
FUDForum. Page generated in 0.03324 seconds
