Home » Eclipse Projects » Eclipse Platform » Menu label problems (seeing % names)
Menu label problems (seeing % names) [message #326139] Fri, 07 March 2008 17:27 Go to next message
I am developing the Mylyn CDT plug-in and for some strange reason, my menu
labels are appearing in their % form. For example, I have a menu label I
refer to as: %FocusActiveTask.label. This key is found in my
plugin.properties and is set to be "Focus Active Task". When I edit my
plugin.xml, the string is resolved for me automatically when I look at the
extensions. However, when I start up an Eclipse application from my
workspace that uses my plugin, the menu label appears as
I have plugin.properties specified in my binary build.
I am using Eclipse 3.4 M5. Anybody have any ideas what I could look
for/try?
Re: Menu label problems (seeing % names) [message #326159 is a reply to message #326139] Sun, 09 March 2008 09:05 Go to previous messageGo to next message
Originally posted by: malloovidio.bluewin.ch
Hi Jeff,
I guess you are defining the actual content of your menu labels in the
plugin.properties file. If so, try opening your plugin.xml file, switching
to the "build" tab in the plugin.xml editor and see whether the
plugin.properties file is marked to be included (at least) in the binary
build of your plug-in. If not, mark it and try whether this solves your
problem.
Hope that helps,
Ovidio
> menu labels are appearing in their % form. For example, I have a menu
> label I refer to as: %FocusActiveTask.label. This key is found in my
> the extensions. However, when I start up an Eclipse application from my
> for/try?
Re: Menu label problems (seeing % names) [message #326160 is a reply to message #326159] Sun, 09 March 2008 09:29 Go to previous messageGo to next message
--------------020902060608020502080508
Ovidio,
Good advice. It's probably good to also make sure that this line
appears in the MANIFEST.MF:
Bundle-Localization: plugin
Ovidio Mallo wrote:
> Hi Jeff,
> switching
> problem.
> Hope that helps,
> Ovidio
>> menu label I refer to as: %FocusActiveTask.label. This key is found
>> in my plugin.properties and is set to be "Focus Active Task". When I
>> edit my plugin.xml, the string is resolved for me automatically when
>> I look at the extensions. However, when I start up an Eclipse
>> application from my workspace that uses my plugin, the menu label
>> appears as %FocusActiveTask.label.
>> for/try?
<html>
<head>
http-equiv="Content-Type">
</head>
Ovidio,<br>
<br>
Good advice.
Re: Menu label problems (seeing % names) [message #326187 is a reply to message #326160] Mon, 10 March 2008 15:56 Go to previous messageGo to next message
Ed Merks wrote:
> Ovidio,
Thanks Ed,
I actually already did have the plugin.properties file in my binary build,
but this little gem you mention works like a charm.
Is there any way to make this show up without manually editing MANIFEST.MF
(e.g. a tab option like Build, Overview etc..)?
Re: Menu label problems (seeing % names) [message #326188 is a reply to message #326187] Mon, 10 March 2008 16:31 Go to previous message
Jeff,
I looked for it and suspect it's hiding in one of those tabs somewhere,
but I couldn't find it...
> Ed Merks wrote:
>> Ovidio,
> Thanks Ed,
> build, but this little gem you mention works like a charm.
> MANIFEST.MF (e.g. a tab option like Build, Overview etc..)?
Previous Topic:StructuredTextEditor hide some contents
Next Topic:TitleAreaDialog message is cut off if it is longer than 2 lines
Current Time: Fri Jul 25 22:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.24832 seconds
