Eclipse under Mac OS X 10.2 [message #32997] |
Mon, 04 November 2002 13:54  |
Originally posted by: robgratz.hotmail.com
I've seen older posts on this subject, but still haven't found where to get
the downloads necessary to run Eclipse on a Mac. Has there been any work
done in this area to make it one of the standard downloads?
Re: Eclipse under Mac OS X 10.2 [message #33593 is a reply to message #33032] |
Fri, 08 November 2002 19:12   |
Originally posted by: jereldh.hotmail.com
Bob Foster wrote:
> "Rob Gratz" <robgratz@hotmail.com> wrote in message
> news:aq6dsq$tua$1@rogue.oti.com...
> get
> It is a standard download. Unfortunately, its availability lasted for only
> one release (M1). Then they started a re-engineering project on it that has
> so far prevented a subsequent release.
> Bob
You can try this (worked for 10.1 a couple days ago for me). At your own
risk, of course. :-)
Go to
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/0904/
and download the Eclipse_2.0.dmg.gz
Unzip it, and mount the drive on your Mac.
Read the 'Read Me.rtf' file contained within. I quote here from said file:
<quote>
How to run Eclipse 2.0 on MacOS X
Unpack the archive, mount the disk image and copy its contents into
a folder 'Eclipse 2.0' on your hard disk
Download any Eclipse SDK 2.0 or 2.0.1 release (platform does not matter)
from www.eclipse.org into your 'Eclipse 2.0' folder
unpack the Eclipse zip file with /usr/bin/unzip (don't use StuffIt
Expander because
it silently truncates file names longer than 31 characters!);
open the top level folder 'eclipse'
Open the context menu on the aplication 'Eclipse 2.0' and select
'Show Package Contents': the application opens as a folder (the
'bundle').
Drill down to 'Contents/Resources/Java' and copy the contents of
the previously opened folder 'eclipse' into the folder 'Java'
(if the 'Contents' folder is disabled and you cannot open it,
just log-out and log-in again or use the command line)
Delete the single plugin 'org.eclipse.swt.Xyz_2.0.0' where Xyz
corresponds
to the platform that you've downloaded in step 2 (one of 'gtk',
'motif', 'photo', 'win32').
Copy the three MacOS X plugins into 'Contents/Resources/Java/plugins'
Close all folders and double click the 'Eclipse 2.0' application.
After a minute or so it should open an empty workspace showing a Readme
document.
</quote>
Note that this step 5 is unclear, even incorrect, and should read:
the previously opened folder 'eclipse/Eclipse_20/Contetns/Resources/Java'
Note also that you need to download an actual version of Eclipse as well.
This is just the SWT stuff, and an empty Eclipse "app wrapper".
I did this, and Eclipse ran, at least. I never actually tried to do
anything with it, but the app launched and came up.
Jer
Re: Eclipse under Mac OS X 10.2 [message #38458 is a reply to message #32997] |
Mon, 16 December 2002 00:46  |
Originally posted by: mlatta.ceira.com
The M3 release supports Mac OS/X. It is available from the eclipse download
page.
get
Re: Eclipse under Mac OS X 10.2 [message #585441 is a reply to message #32997] |
Mon, 04 November 2002 15:19  |
get
Bob
Re: Eclipse under Mac OS X 10.2 [message #585657 is a reply to message #33032] |
> get
> Bob
Go to
<quote>
Expander because
'bundle').
corresponds
document.
</quote>
Jer
Re: Eclipse under Mac OS X 10.2 [message #587661 is a reply to message #32997] |
page.
get
FUDForum. Page generated in 0.04230 seconds
