Home » Eclipse Projects » Eclipse Platform » Loading a non-properties files from a fragment into and editor
Loading a non-properties files from a fragment into and editor [message #326093] Fri, 07 March 2008 04:58 Go to next message
I have a html file that is translated and its translated copies reside in
my plugin fragment. I need to open it in an editor. The English version of
the file is at the root of my plugin. Currently I am using this code to
locat the file url, where relativePath is the file name:
public URL getURLFromFragment(relativePath){
Bundle bundle = Platform.getBundle(MY_PLUGIN_ID);
try{
IPath path = new Path("$nl$/"+relativePath);
URL url = FileLocator.find(bundle, path, null);
return url;
catch (Exception exc) {
exc.printStackTrace();
return null;
Then I instantiate my editor input class, a subclass of IPathEditorInput,
with a Path object built from the url returned my method above like:
myEditorInput editor = new myEditorInput(new
Path(getURLFromFragment("myFileName")));
This currently only opens the English version of the file! Anyone has any
idea why? Do I need to read in the file as an inputStream and then somehow
display it. I am thinking something must be wrong with how I am
instantiating my editor input class.
Any help is truly appreciated...
Re: Loading a non-properties files from a fragment into and editor [message #326103 is a reply to message #326093] Fri, 07 March 2008 05:23 Go to previous messageGo to next message
Lila,
What does the folder structure in your plugin for the translated
versions look like? Did you use the -nl flag to direct Eclipse to use a
different locale?
> in my plugin fragment. I need to open it in an editor. The English
> version of the file is at the root of my plugin. Currently I am using
> this code to locat the file url, where relativePath is the file name:
> try{
> return url;
> exc.printStackTrace(); return null;
> IPathEditorInput, with a Path object built from the url returned my
> method above like:
> any idea why? Do I need to read in the file as an inputStream and then
> somehow display it. I am thinking something must be wrong with how I
> am instantiating my editor input class.
Re: Loading a non-properties files from a fragment into and editor [message #326109 is a reply to message #326103] Fri, 07 March 2008 07:30 Go to previous messageGo to next message
I actually put the translated files under a nl\local directory structure
like this in the NL fragment plugin:
nl\de\myfile.html
nl\es\myfile.html
nl\zh\hk\myfile.html
I know that you can place the files at the root of the fragment like
myfile_zh_hk.html, myfile_de.html, etc.
Re: Loading a non-properties files from a fragment into and editor [message #326117 is a reply to message #326109] Fri, 07 March 2008 08:30 Go to previous messageGo to next message
Lila,
You might need to specify your path as "nl/$NL$/myfile.html. I'm not
really exactly sure the specific naming conventions that are followed.
Have you tried stepping with the debugger through the lookup logic to
see where it all searches for the path you've provided?
> structure like this in the NL fragment plugin:
> nl\de\myfile.html
> nl\es\myfile.html
Re: Loading a non-properties files from a fragment into and editor [message #326124 is a reply to message #326109] Fri, 07 March 2008 08:40 Go to previous message
and you started your eclipse with -nl de?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Display actions when a project has a certain file
Next Topic:compare with revision/compare examples
Current Time: Sat Aug 30 22:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.03888 seconds
