Home » Eclipse Projects » Subversive » Repository on local hard drive
Repository on local hard drive [message #32989] Wed, 27 August 2008 12:31 Go to next message
I'm new to Eclipse and Subversive so forgive me if my question is silly.
I'd like to use a repository located on my local hard drive - as in the
subject. I've already created it using TortoiseSVN and I'd like to use it
as Subversive's New Repository Location. However, when I try to enter an
URL for this repository, it doesn't work and Subversive says that:
Location information has beend specified incorrectly.
svn: unable to open an ra_local session to URL...
svn: unable to open repository 'file:///C:/Users/Michał
Olejnik/Documents/PWr/Repo
svn: expected FS format '2'; found format '3'
The URL is correct (e.g. Netbeans works with it perfectly) and I have no
idea why this doesn't work. I'd be very grateful for any help, because I'm
planning to switch to Eclipse from Netbeans for a while, and being able to
control repository directly from IDE would be much more comfortable for
me. Thanks for your help in advance.
Re: Repository on local hard drive [message #33098 is a reply to message #32989] Thu, 28 August 2008 06:39 Go to previous messageGo to next message
Hello, Michał.
What SVN Connector are you using? Did you try to switch it?
I didn't try to create locations from tortoise, but after creating it with
command line client using --fsfs param everything is fine for Subversive.
Best regards, Alexei Goncharov.
Re: Repository on local hard drive [message #33131 is a reply to message #33098] Thu, 28 August 2008 07:19 Go to previous message
Hello Alexei,
It actually was the matter of connector. I was using SVNKit 1.1.7 and when
I changed it to SVNKit 1.2.0 it worked. And it works with both types of
repositories - created with Tortoise and created from command line.
Thanks for help.
Michal Olejnik
Previous Topic:Which versions for Ganymede?
Next Topic:[Subversive] ChangeSet
Current Time: Sat Sep 27 15:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.02873 seconds
