Home » Eclipse Projects » Eclipse Platform » How to get StatusLineManager...my plug-in does not have a ViewPart
How to get StatusLineManager...my plug-in does not have a ViewPart [message #326018] Wed, 05 March 2008 16:45 Go to next message
Originally posted by: james.towers.siemens.com
Hello all,
I would like to contribute to the StatusLine. I would like my StatusLine
contribution to be seen in all views. So I need to contribute to the
StatusLineManager. Is there an easy way to get the StatusLineManager? My
plug-in is a utility plug-in. It does not have a ViewPart.
I have tried the code below. I get the desired behavior but I think there
should be a better way.
Jim
IStatusLineManager slMan =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getViewReferences()[0].getView(false).getViewSite() .getActionBars().getStatusLineManager();
if (slMan instanceof SubStatusLineManager )
SubStatusLineManager sub = (SubStatusLineManager) slMan;
slMan = (IStatusLineManager)sub.getParent();
Re: How to get StatusLineManager...my plug-in does not have a ViewPart [message #326076 is a reply to message #326018] Thu, 06 March 2008 19:18 Go to previous messageGo to next message
James Towers wrote:
> Hello all,
The status line manager in eclipse is specifically designed to show each
active part's status (which means global access is not available).
In 3.3.x you can use org.eclipse.ui.menus to contribute a control, where
you can provide your own status line/label/icon/control.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to get StatusLineManager...my plug-in does not have a ViewPart [message #326235 is a reply to message #326076] Wed, 12 March 2008 10:25 Go to previous message
Thanks Paul.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:fqq1dn$asp$2@build.eclipse.org...
> James Towers wrote:
>> Hello all,
>> My plug-in is a utility plug-in. It does not have a ViewPart.
> Later,
> PW
> Paul Webster
Previous Topic:JUnit and Plugins
Next Topic:non-blinking cursor
Current Time: Fri Jul 18 21:58:38 EDT 2025
Powered by FUDForum. Page generated in 0.05049 seconds
