Home » Eclipse Projects » Eclipse Platform » Associating a command to a global handler
Associating a command to a global handler [message #326016] Wed, 05 March 2008 13:51 Go to next message
Originally posted by: bvkiran.yahoo.com
I am trying to move to the new command and menu way of adding popup menus
via extension. I have added a new command and a new popupmenu for a view
using the org.eclipse.ui.commands and org.eclipse.ui.menu extensions. I
have added cut copy paste as popup menus. I would like to associate them
with the global cut, copy paste menus.
I know using IAction I can manually create these actions and tie them
using setGlobalActionHandler(). How can I do the same thing with commands
and menus added via extension points. Thanks in advance.
Kiran
Re: Associating a command to a global handler [message #326073 is a reply to message #326016] Thu, 06 March 2008 19:15 Go to previous message
You mean you want to provide your own handlers for the commands (like
org.eclipse.ui.edit.copy)?
From your createPartControl(*) if you have your own CopyHandler that
acts on your view, you would do something like:
createHandlers() {
IHandlerService hs
= (IHandlerService) getSite().getService(IHandlerService.class);
myCopyHandler = new CopyHandler(this);
hs.activeHandler("org.eclipse.ui.edit.copy", myCopyHandler);
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Reading Console View Messages
Next Topic:Help needed writing a custom expression for visibleWhen of a command menuContribution
Current Time: Sun Nov 09 05:38:30 EST 2025
Powered by FUDForum. Page generated in 0.03695 seconds
