Home » Eclipse Projects » Eclipse Platform » How to test internationalization plugin
How to test internationalization plugin [message #325983] Wed, 05 March 2008 01:07 Go to next message
Originally posted by: sania12.yahoo.com
I have created a fragment project for internationalizing my plugin.
But I do not know how to test where the nl plugin created works..
Had a look at the tutorial "How to Test your Internationalized plugin" but
could not get much.
Thanks in advance
Sania
Re: How to test internationalization plugin [message #325985 is a reply to message #325983] Wed, 05 March 2008 02:20 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Sania,
Simplest way to test nl plugin is to launch your product with -nl
<language> and see if all looks ok.
Automated testing, i.e. automatic verification of properties files is I
think in scope of Babel project, which has recently started.
Sania wrote:
> Hi
> but could not get much.
> Thanks in advance
> Sania
Re: How to test internationalization plugin [message #326054 is a reply to message #325985] Thu, 06 March 2008 07:25 Go to previous messageGo to next message
Originally posted by: chandra.mayamuthu.gmail.com
Hi sania,
If you have got answer for your question. Please reply me how did u
handle Double Byte Character Set in i18n, like Japanese language
characters.
Thanks in advance
Chandra M
Re: How to test internationalization plugin [message #326085 is a reply to message #326054] Fri, 07 March 2008 03:07 Go to previous messageGo to next message
While running your application , open Run Dialog ---> Arguments tab-->
set the program argumnet for nl option ..
For example, for French set fr_FR like -nl fr_FR.. and run ur
application...
Sania
Re: How to test internationalization plugin [message #326105 is a reply to message #326085] Fri, 07 March 2008 06:51 Go to previous messageGo to next message
Yes.. Sania, I did the same for French. Now my question is about double
byte characters handling. Example, Japanese letters are Double byte
characters, I am not able to save them in normal .properties files as we
used to for English and French, means we need to handle them in special
manner.
Please reply me.
Chandra M
Re: How to test internationalization plugin [message #326118 is a reply to message #326105] Fri, 07 March 2008 08:36 Go to previous message
The japanese chars are saved in a properties file, as normal. Download
the NL pack from
http://download.eclipse.org/eclipse/downloads/drops/L-3.2.1_ Language_Packs-200609210945/
and check it out.
As for how to enter them ... if you are editing and can type the real
chars from the keyboard, that works. These language packs simply escape
the chars in the properties file. ex:
CloseAllAction_text=\u3059\u3079\u3066\u9589\u3058\u308B(&am p;L)
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:How to overwrite text in about dialogs
Next Topic:Display actions when a project has a certain file
Current Time: Mon Jul 21 23:55:27 EDT 2025
Powered by FUDForum. Page generated in 0.05941 seconds
