Home » Eclipse Projects » DSDP - Target Management » Problems with a dStore connection
Problems with a dStore connection [message #32980] Mon, 09 March 2009 08:46 Go to next message
IŽm trying to use RDT to work with a project stored in our departmentŽs
cluster
from my laptop. I've installed the RDT server (a daemon as root in port
4075) that starts a server in port 4033 for each connection. IŽve
configured the server to use SSL.
IŽve defined in my laptop two RSE connections, one SSH based and one
dStore based. The SSH based works fine, I can see and work with my remote
files, start shells and terminals. By the contrary, the dstore based
connection connects me to the server (as notified in the cluster console
and in the properties of the connection) but I can only start terminals
(that use SSH not dStore). I get "File '.' not found" and Empty List
messages for the Files and Processes parts of the connection, and "blank"
consoles for the Shell part.
I'm using MacOSX 10.5 and Eclipse 3.4.1 with RSE DStore 3.0.1 plugin. My
firewall is configured to not allow incoming connections by default, but I
accept incoming connections for Eclipse (I donŽt know if this has anything
to do with the problem).
Because I want to use the remote build and indexing features of RDT IŽd
really appreciate your assistance.
Excuse me if this question was more appropriate for the PTP newsgroup. I
wasnŽt sure where to post it first.
Re: Problems with a dStore connection [message #33050 is a reply to message #32980] Mon, 09 March 2009 11:51 Go to previous messageGo to next message
Hi Xo
Re: Problems with a dStore connection [message #33051 is a reply to message #33050] Tue, 10 March 2009 09:28 Go to previous messageGo to next message
Hi Dave,
contents of .eclipse/RSE are:
[pardo@nm RSE]$ ls -las
total 24
4 drwxr-xr-x 4 pardo gac 4096 Feb 26 12:52 .
4 drwxr-xr-x 4 pardo gac 4096 Mar 10 13:30 ..
4 drwxr-xr-x 2 pardo gac 4096 Feb 19 12:32 pardo
4 -rw-r--r-- 1 pardo gac 126 Feb 18 14:01 rmt_classloader_cache.jar
4 -rw-r--r-- 1 pardo gac 3549 Mar 5 17:35 rsecomm.log
4 drwxr-xr-x 2 pardo gac 4096 Feb 19 12:34 xoan
pardo and xoan directories contain the following:
pardo:
total 4
-rw-r--r-- 1 pardo gac 126 Feb 19 12:32 rmt_classloader_cache.jar
xoan:
total 4
-rw-r--r-- 1 pardo gac 126 Feb 19 12:34 rmt_classloader_cache.jar
and rsecomm.log has the following message repeated 13 times:
Thu Mar 05 17:35:01 CET 2009
ERROR UniversalProcessMiner: Unsupported subject for command: DataElement
Type: universal.FilterObject
Value: .
ID:
Source: .
Depth: 1
DataStore: server_host
I try to connect using pardo login. I think that the xoan directory was
created the first time I tried to connect using an erroneous user name. It
could be that the log messages were generated once I was playing with
filters trying to solve the problem.
I removed the RSE directory and started a connection from the beginning.
Following is the sequence of events in case it could help:
1) I started the daemon in our cluster
[root@nm rdt-server]# ./daemon.pl &
[1] 22564
[root@nm rdt-server]# SSL Settings
[daemon keystore: /home/users/pardo/apps/rdt-server/.keystore]
[daemon keystore pw: XXXXXXXXXXXXXXXXXX]
[server keystore: /home/users/pardo/apps/rdt-server/.keystore]
[server keystore pw: XXXXXXXXXXXXXXXXXX]
Daemon running on: nm.des.udc.es, port: 4075
2) Check the daemon is running
[pardo@nm rdt-server]$ ps aux | grep rdt-server
-DA_PLUGIN_PATH=/home/users/pardo/apps/rdt-server/
-DDSTORE_TRACING_ON=false org.eclipse.dstore.core.server.ServerLauncher
4075
3) Started a connection from Eclipse
4) A password is requested (I suppose it is for the RDT daemon). I enter
the
password of the user pardo.
5) In the cluster, the RDT server is started
[pardo@nm]$ handshake completed
launched new server on 4033
SSL Settings
[daemon keystore pw: XXXXXXXXXXXXXXXXX]
[server keystore pw: XXXXXXXXXXXXXXXXX]
6) In Eclipse, a dialog informs that an SSL connection is being established
7) A second password is requested (I suppose it is for the SSH daemon). I
enter the same password as in step 4.
8) The connection is completed. All subsystems are connected as it appears
in the Properties view.
9) Check that the server is running on the cluster
[pardo@nm]$ ps aux | grep rdt-server
4075
root 22681 0.0 0.1 80576 2612 pts/7 S 13:30 0:00 perl
/home/users/pardo/apps/rdt-server//auth.pl pardo
/home/users/pardo/apps/rdt-server/ 4033 120000 1236688249538
/usr/java/jdk1.6.0_07/jre
root 22683 0.0 0.0 100988 1264 pts/7 S 13:30 0:00 su -p
pardo -c /usr/java/jdk1.6.0_07/jre/bin/java -cp
/home/users/pardo/apps/rdt-server:/home/users/pardo/apps/rdt -server/dstore_extra_server.jar:/home/users/pardo/apps/rdt-s erver/dstore_core.jar:/home/users/pardo/apps/rdt-server/dsto re_miners.jar:/home/users/pardo/apps/rdt-server/clientserver .jar
-DA_PLUGIN_PATH=/home/users/pardo/apps/rdt-server/ -DDSTORE_SPIRIT_ON=true
org.eclipse.dstore.core.server.Server 4033 120000 1236688249538
pardo 22684 0.4 1.8 837816 38120 ? Ssl 13:30 0:02
10) In Eclipse I try to open the Files part of my connection.
In the Files tree the message "Pending..." is shown
In the Progress View the message "Resolving ./*" is shown, there's no
progress: always 0%.
No messages in the Error Log View.
11) After a while the message "File '.' not found" is shown in the Files
tree.
Contents of the ./eclipse/RSE directory in the cluster are:
total 12
4 drwxr-xr-x 2 pardo gac 4096 Mar 10 13:30 .
4 -rw-r--r-- 1 pardo gac 126 Mar 10 13:30 rmt_classloader_cache.jar
As you can see, there isn't a log file.
And that's all. Sorry for the long message.
Thanks very much,
Xoán
David McKnight wrote:
> Hi Xoán,
> Are you able to see whether there are any messages logged on the console
> that started the daemon? Are there a .dstoreTrace log file under the
> directory ~/.eclipse/RSE?
> Dave
> "" Xoán" C. Pardo" <xoanpardo@gmail.com> wrote in message
> news:a224b36f5f9a1f0dd1e14e5a08b94974$1@www.eclipse.org...
>> cluster
Re: Problems with a dStore connection [message #33227 is a reply to message #33051] Thu, 12 March 2009 10:29 Go to previous messageGo to next message
Hi Xo
Re: Problems with a dStore connection [message #33336 is a reply to message #33051] Thu, 19 March 2009 08:46 Go to previous messageGo to next message
Hi Xoan,
could you file a bug for follow-up disucssion on this please?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target
Management&component=RSE
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Xoán C. Pardo wrote:
> Hi Dave,
> total 24
> pardo:
> total 4
> xoan:
> total 4
> ERROR UniversalProcessMiner: Unsupported subject for command: DataElement {
> Value: .
> ID:
> Source: .
> Depth: 1
> It could be that the log messages were generated once I was playing with
> [1] 22564
> 4075
> the
> SSL Settings
> I enter the same password as in step 4.
> appears in the Properties view.
> 4075
> -DDSTORE_SPIRIT_ON=true org.eclipse.dstore.core.server.Server 4033
> tree.
> total 12
> Thanks very much,
> Xoán
>> Hi Xoán,
>> console that started the daemon? Are there a .dstoreTrace log file
>> under the directory ~/.eclipse/RSE?
>> Thanks,
>> Dave
>>> Hi,
>>> departmentŽs cluster
>>> port 4075) that starts a server in port 4033 for each connection.
>>> IŽve configured the server to use SSL.
>>> remote files, start shells and terminals. By the contrary, the dstore
>>> based connection connects me to the server (as notified in the
>>> cluster console and in the properties of the connection) but I can
>>> only start terminals (that use SSH not dStore). I get "File '.' not
>>> found" and Empty List messages for the Files and Processes parts of
>>> the connection, and "blank" consoles for the Shell part.
>>> My firewall is configured to not allow incoming connections by
>>> default, but I accept incoming connections for Eclipse (I donŽt know
>>> if this has anything to do with the problem).
>>> IŽd really appreciate your assistance.
>>> newsgroup. I wasnŽt sure where to post it first.
Re: Problems with a dStore connection [message #33610 is a reply to message #33227] Mon, 23 March 2009 09:15 Go to previous messageGo to next message
Hi David,
excuse me for the delay in the answer, I was ill last week.
IŽve tried activating tracing in auth.pl and in daemon.pl but it makes no
difference. I canŽt find a .dstoreTrace file in the cluster.
Java version is the same for both users:
[pardo@nm RSE]$ java -version
java version "1.6.0_07"
Java(TM) SE Runtime Environment (build 1.6.0_07-b06)
Java HotSpot(TM) 64-Bit Server VM (build 10.0-b23, mixed mode)
[pardo@nm RSE]$
Xoán C. Pardo
> Hi Xoán,
> Could you change the server's auth.pl file to have the following in it's
> invocation of java from the system call?
> -DSTORE_TRACING_ON=true
> The system call will look something like this:
> system("su $suOptions $userIN -c '$javaExe -cp
> $classpath -DSTORE_TRACING_ON=true -DA_PLUGIN_PATH=$pathIN
> org.eclipse.dstore.core.server.Server $portIN $timeoutIN $ticketIN'");
> Once you connect to to the datastore server this way, a .dstoreTrace file
> should get created. I think that would help the most. Also, could you tell
> me which version of java is used by root and by your user account?
> Dave
> news:93493b0b4f297153bca421c8cd5ce272$1@www.eclipse.org...
>> Hi Dave,
>> total 24
>> pardo:
>> total 4
>> xoan:
>> total 4
>> Value: .
>> Depth: 1
>> [1] 22564
>> org.eclipse.dstore.core.server.ServerLauncher 4075
>> the
>> SSL Settings
>> established
>> tree.
>> total 12
>> Thanks very much,
>> Xoán
>>> Hi Xoán,
>>> Thanks,
>>> Dave
>>>> Hi,
>>>> cluster
>>>> based connection connects me to the server (as notified in the cluster
>>>> console and in the properties of the connection) but I can only start
>>>> terminals (that use SSH not dStore). I get "File '.' not found" and
>>>> Empty List messages for the Files and Processes parts of the connection,
>>>> I accept incoming connections for Eclipse (I donŽt know if this has
Re: Problems with a dStore connection [message #33675 is a reply to message #33336] Mon, 23 March 2009 12:37 Go to previous message
Ok.
I filed the bug.
Bug number: #269709
Summary: [dstore] A dstore-based connection doesn't work properly
Martin Oberhuber wrote:
> Hi Xoan,
>> Hi Dave,
>> total 24
>> pardo:
>> total 4
>> xoan:
>> total 4
>> Value: .
>> ID:
>> Source: .
>> Depth: 1
>> [1] 22564
>> 4075
>> the
>> SSL Settings
>> 4075
>> tree.
>> total 12
>> Thanks very much,
>> Xoán
>>> Hi Xoán,
>>> Thanks,
>>> Dave
>>>> Hi,
OK.
The bug has been filed
Re: Problems with a dStore connection [message #579650 is a reply to message #32980] Mon, 09 March 2009 11:51 Go to previous message
Hi Xo
Re: Problems with a dStore connection [message #579658 is a reply to message #33050] Tue, 10 March 2009 09:28 Go to previous message
Hi Dave,
total 24
pardo:
total 4
xoan:
total 4
Value: .
ID:
Source: .
Depth: 1
[1] 22564
4075
the
SSL Settings
4075
tree.
total 12
Thanks very much,
Xoán
> Hi Xoán,
> Dave
>> cluster
Re: Problems with a dStore connection [message #579764 is a reply to message #33051] Thu, 12 March 2009 10:29 Go to previous message
Hi Xo
Re: Problems with a dStore connection [message #579810 is a reply to message #33051] Thu, 19 March 2009 08:46 Go to previous message
Hi Xoan,
> Hi Dave,
> total 24
> pardo:
> total 4
> xoan:
> total 4
> Value: .
> ID:
> Source: .
> Depth: 1
> [1] 22564
> 4075
> the
> SSL Settings
> 4075
> tree.
> total 12
> Thanks very much,
> Xoán
>> Hi Xoán,
>> Thanks,
>> Dave
>>> Hi,
Re: Problems with a dStore connection [message #579987 is a reply to message #33227] Mon, 23 March 2009 09:15 Go to previous message
Hi David,
[pardo@nm RSE]$
Xoán C. Pardo
> Hi Xoán,
> Dave
>> Hi Dave,
>> total 24
>> pardo:
>> total 4
>> xoan:
>> total 4
>> Value: .
>> Depth: 1
>> [1] 22564
>> the
>> SSL Settings
>> established
>> tree.
>> total 12
>> Thanks very much,
>> Xoán
>>> Hi Xoán,
>>> Thanks,
>>> Dave
>>>> Hi,
>>>> cluster
Re: Problems with a dStore connection [message #580011 is a reply to message #33336] Mon, 23 March 2009 12:37 Go to previous message
Ok.
I filed the bug.
Bug number: #269709
> Hi Xoan,
>> Hi Dave,
>> total 24
>> pardo:
>> total 4
>> xoan:
>> total 4
>> Value: .
>> ID:
>> Source: .
>> Depth: 1
>> [1] 22564
>> 4075
>> the
>> SSL Settings
>> 4075
>> tree.
>> total 12
>> Thanks very much,
>> Xoán
>>> Hi Xoán,
>>> Thanks,
>>> Dave
>>>> Hi,
OK.
Previous Topic:help on SaveAs
Next Topic:Which side initiates when using dstore daemon?
Current Time: Thu Jul 17 20:11:59 EDT 2025
Powered by FUDForum. Page generated in 0.13532 seconds
