Home » Eclipse Projects » Eclipse Platform » How to disable/replace eclipse logger implementation
How to disable/replace eclipse logger implementation [message #325957] Tue, 04 March 2008 06:21 Go to next message
Hello Everybody,
I am trying to run an eclipse based application in an embedded
environment with limited disk space and would like to severely limit
eclipse log file (workspace/.metadata/.log) size.
Currently it seems that the log file is grown until it reaches 1GB size,
which is then renamed, backed up and new log file is created. This
process is repeated until 10 backed up log files are created, thus
increasing the total size of log files to 10GB, which is unacceptable.
We would like to either entirely disable logging or replace default
eclipse logger with our own, that we could control more tightly.
Roland Tepp
Re: How to disable/replace eclipse logger implementation [message #325977 is a reply to message #325957] Tue, 04 March 2008 15:40 Go to previous messageGo to next message
umm, there is something wrong that is causing the logging to the log
file. I would figure out what that is first.
In my RCP app, I have a log handler that reports an error to the user
(and considers it a bug) whenever there is something logged. Therefore
my log file is virtually empty.
Roland Tepp wrote:
> Hello Everybody,
Re: How to disable/replace eclipse logger implementation [message #326578 is a reply to message #325977] Tue, 25 March 2008 11:57 Go to previous messageGo to next message
Sorry Francis, but this did not answer my question.
I know that the eclipse logging facility is mostly used for logging
errors and warnings and most of these cases are "critical" enough to be
considered bugs in their own right.
But in addition to these items there are also info, debug and trace
level logs, that should also be logged at some point.
Current Eclipse practice of logging debug level logs to stdout is not
satisfying, since this separates conventional log messages from error
messages that could be relevant for debugging problems in the
testing/production environment.
What I need is to have the ability to redirect all logging statements to
a single location, irrespective of it's severity. I also do not want to
manage multiple logging facilities - one for reporting errors and
warnings and one for info/debug/trace level logging...
Also - the need to disable the eclipse log altogether is required in the
embedded environment without any writable disk space available.
Francis Upton kirjutas mulle midagi seesugust:
> Roland Tepp wrote:
>> Hello Everybody,
>> size, which is then renamed, backed up and new log file is created.
>> This process is repeated until 10 backed up log files are created,
>> thus increasing the total size of log files to 10GB, which is
>> unacceptable.
Roland Tepp
Re: How to disable/replace eclipse logger implementation [message #326655 is a reply to message #326578] Thu, 27 March 2008 12:04 Go to previous message
have you considered to use java.util.logging? It would be easy to create log
handler which is fowarding Info/Error/Warning messages to the Eclipse error
log additional to capture the log record to where ever you want. From client
perspective, you always use the same interface and you do not need to care
about where the messages will end up. All the logic is centralized to the
log handler.
Regards, Uwe Stieber
"Roland Tepp" <roland@videobet.com> wrote in message
news:fsb7a0$e7f$1@build.eclipse.org...
> I know that the eclipse logging facility is mostly used for logging errors
> But in addition to these items there are also info, debug and trace level
> What I need is to have the ability to redirect all logging statements to a
> manage multiple logging facilities - one for reporting errors and warnings
>> Roland Tepp wrote:
>>> Hello Everybody,
> Roland Tepp
Previous Topic:Dynamic menu contribution to view toolbar does not work?
Next Topic:property changes on a resource
Current Time: Mon Jul 21 21:08:56 EDT 2025
Powered by FUDForum. Page generated in 0.08799 seconds
