Home » Eclipse Projects » Eclipse Platform » [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.j
[Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.j [message #325954] |
Tue, 04 March 2008 04:20  |
Originally posted by: r.c.ladan.tue.nl
--------------030901050804090202090408
This seems Eclipse-specific, not really ATL-specific....
Does anyone have a solution for the random hangs described in the attached message?
Rene
Configuration details:
*** Date: dinsdag 4 maart 2008 10:17:57 Duitsland
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20071023-1652
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.bmp
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3.R33x_v20080118\eclipse_1023.dll
-startup
C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.jar
-vm
C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1204618361408
eclipse.vm=C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256M
-Djava.class.path=C:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\plugins\org.eclipse.equinox.launc her_1.0.1.R33x_v20080118.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_03\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.6.0_03\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_03
java.io.tmpdir=C:\DOCUME~1\rladan\LOCALS~1\Temp\
java.library.path=C:\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\WI NDOWS\system32;C:\WINDOWS;C:\Program Files\Java\jre1.6.0_03\bin\client;C:\Program Files\Java\jre1.6.0_03\bin;c:\ruby\bin;C:\PROGRA~1\RATIONAL\ RATION~1\NUTCROOT\bin;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT \bin\x11;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT\mksnt;C:\Per l\bin\;C:\texmf\miktex\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common Files\GTK\2.0\bin;C:\Program Files\Common Files\Compuware\NMShared;C:\Program Files\MySQL\MySQL Server 5.0\bin;c:\perl\bin;C:\Program Files\Rational\ClearQuest;C:\Program Files\Unisys\Unisys Rose XML Tools\MOF;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Unisys\Unisys Rose XML Tools\UML;C:\Program Files\Rational\common;C:\Program Files\Common Files\Compuware\;C:\Program Files\Rational\Rose\TopLink\;C:\Program Files\Rational\Rational Test;C:\PROGRA~1\ATT\Graphviz\bin;C:\Program Files\doxygen\bin
;C:\Program Files\GNU\GnuPG\pub;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\SSH Communications Security\SSH Secure Shell;C:\Program Files\LQN Solvers;C:\Program Files\Nmap
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_03-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_03-b05
line.separator=
org.eclipse.equinox.launcher.splash.location=C:\eclipse\\plu gins\org.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp
org.eclipse.update.resolution_url=
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=nl
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Curren
tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c. dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.do m.traversal,org.w3c.dom.views ,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.3 .2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.2.R33x_v20080105
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/rladan/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/rladan/workspace/
osgi.logfile=C:\Documents and Settings\rladan\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=nl_NL
osgi.os=win32
osgi.splashLocation=C:\eclipse\\plugins\org.eclipse.platform _3.3.3.r33x_r20080129\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.6.0_03\lib\resources.jar;C:\Program Files\Java\jre1.6.0_03\lib\rt.jar;C:\Program Files\Java\jre1.6.0_03\lib\sunrsasign.jar;C:\Program Files\Java\jre1.6.0_03\lib\jsse.jar;C:\Program Files\Java\jre1.6.0_03\lib\jce.jar;C:\Program Files\Java\jre1.6.0_03\lib\charsets.jar;C:\Program Files\Java\jre1.6.0_03\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0_03\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 2
user.country=NL
user.dir=C:\eclipse
user.home=C:\Documents and Settings\rladan
user.language=nl
user.name=rladan
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Eclipse CVS Client"
org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code Generation UI"
org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code Generator UI"
org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF) Programmers Guide"
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF Model Query"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF Model Query OCL Integration"
org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88) "EMF Model Transaction Core"
org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF Validation Framework Core"
org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF Model Transaction Workbench Integration Core"
org.eclipse.gef (3.3.2.v20080129) "Graphical Editing Framework"
org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) "Eclipse Java Development Tools"
org.eclipse.ocl (1.1.2.v200711262212-3219oA55P6H8I9HDE) "Object Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse Plug-in Development Environment"
org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) "Eclipse Platform"
org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "Eclipse RCP"
org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG" [Resolved]
org.antlr.runtime (3.0.0.200802121151) "ANTLR Runtime" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver" [Resolved]
org.atl.eclipse.adt.builder (2.0.0) "ATL Builder" [Starting]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Starting]
org.eclipse.compare (3.3.2.r33x_20080128) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding" [Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection Management" [Active]
org.eclipse.core.resources (3.3.1.R33x_v20080205) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
org.eclipse.cvs (1.0.2.r33x_r20080129) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.3.2.v20080117_r332) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.2.v20080117_r332) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF)" [Starting]
org.eclipse.emf.ant (2.3.1.v200802051830) "EMF Ant Tasks" [Starting]
org.eclipse.emf.cheatsheets (2.3.0.v200802051830) "EMF Cheat Sheets" [Starting]
org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code Generator" [Starting]
org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code Generation" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore Code Generation UI" [Starting]
org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code Generator UI" [Starting]
org.eclipse.emf.common (2.3.2.v200802051830) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert Support" [Starting]
org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF) Programmers Guide" [Starting]
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore" [Starting]
org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore Change Edit Support" [Starting]
org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support" [Starting]
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.3.2.v200802051830) "EMF XMI" [Starting]
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export Support" [Starting]
org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import Support" [Starting]
org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830) "Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to XML Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI" [Starting]
org.eclipse.emf.ocl (1.1.1.v200709121956) "Object Constraint Language (OCL) 2.0 Compatibility API" [Starting]
org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query" [Starting]
org.eclipse.emf.query.ocl (1.1.0.v200706071712) "EMF Model Query OCL Integration" [Starting]
org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF) Source" [Resolved]
org.eclipse.emf.transaction (1.1.2.v200712061832) "EMF Model Transaction Core" [Starting]
org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model Transaction UI" [Starting]
org.eclipse.emf.validation (1.1.1.v200708161445) "EMF Validation Framework Core" [Starting]
org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation Framework UI" [Starting]
org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF Validation Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.1.2.v200712061832) "EMF Model Transaction Workbench Integration Core" [Starting]
org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model Transaction Workbench Integration UI" [Starting]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.3.R33x_v20080118) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry Support" [Active]
org.eclipse.gef (3.2.102.v20080116) "Graphical Editing Framework" [Starting]
org.eclipse.help (3.3.2.v20071126_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server" [Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.2.v20071126_33x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.2.v20071102_33x) "Help System Webapp" [Starting]
org.eclipse.jdt (3.3.1.r332_v20080131) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) "Java Compiler Apt IDE" [Active]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.3.3.v_793_R33x) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) "Eclipse Java Development User Guide" [Starting]
org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) "Java Development Tools JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.2.v20080115_r332) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.3.2.r332_20080128) "Java Development Tools UI" [Active]
org.eclipse.jem.util (2.0.2.v200802192030) "Java EMF Model Utilities" [Starting]
org.eclipse.jface (3.3.2.M20080207-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.1.1.M20080207-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.3.1.r332_20080128) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.3.1.r332_20080128) "Refactoring UI" [Starting]
org.eclipse.m2m.atl.adt.builder (2.0.0.200802251526) "ATL Builder" [Starting]
org.eclipse.m2m.atl.adt.debug (2.0.0.200802251526) "ATL Debugger" [Starting]
org.eclipse.m2m.atl.adt.editor (2.0.0.200802251526) "ATL Editor" [Active]
org.eclipse.m2m.atl.adt.perspective (2.0.0.200802251526) "ATL Perspective" [Starting]
org.eclipse.m2m.atl.adt.wizard (2.0.0.200802251526) "ATL Wizard" [Active]
org.eclipse.m2m.atl.compilers.atl2006 (2.0.0.200802251526) "ATL Compiler 2006 Plug-in" [Starting]
org.eclipse.m2m.atl.drivers.emf4atl (2.0.0.200802251526) "EMF4ATL Plug-in" [Resolved]
org.eclipse.m2m.atl.drivers.mdr4atl (2.0.0.200802251526) "MDR4ATL Plug-in" [Starting]
org.eclipse.m2m.atl.drivers.uml24atl (2.0.0.200802251526) "UML24ATL Plug-in" [Resolved]
org.eclipse.m2m.atl.engine (2.0.0.200802251526) "ATLAS Transformation Language (ATL)" [Starting]
org.eclipse.m2m.atl.engine.emfvm (2.0.0.200802251526) "ATL EMF Virtual Machine" [Starting]
org.eclipse.m2m.atl.engine.vm (2.0.0.200802251526) "ATL VM Plug-in" [Active]
org.eclipse.m2m.atl.ocl.core (2.0.0.200802251526) "Ocl Core Plug-in" [Starting]
org.eclipse.ocl (1.1.2.v200711262212) "Object Constraint Language (OCL) 2.0 Parser/Interpreter" [Starting]
org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for Ecore" [Starting]
org.eclipse.osgi (3.3.2.R33x_v20080105) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1 Services" [Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility Classes" [Resolved]
org.eclipse.pde (3.3.1.r33x_r20080129) "Eclipse Plug-in Development Environment" [Active]
org.eclipse.pde.build (3.3.2.v20071019) "Plug-in Development Environment Build Support" [Starting]
org.eclipse.pde.core (3.3.2.v20071121-0800) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development Environment Runtime" [Starting]
org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI" [Starting]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates" [Starting]
org.eclipse.platform (3.3.3.r33x_r20080129) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse Workbench User Guide" [Starting]
org.eclipse.rcp (3.2.1.r33x_r20080131) "Eclipse RCP" [Starting]
org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support" [Starting]
org.eclipse.swt (3.3.2.v3349d) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.3.v3349) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.3.1.r33x_20080128) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.2.r33x_20080128) "CVS Team Provider Core" [Starting]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI" [Starting]
org.eclipse.team.ui (3.3.2.r33x_20080128) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.1.M20071128-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.1.v20080125_33x) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.2.v20071031_r332) "Console" [Active]
org.eclipse.ui.editors (3.3.2.r332_20080109-0800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.2.M20080207-0800) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.3.2.M20080207-0800) "Common Navigator View" [Starting]
org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator Workbench Components" [Starting]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI" [Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.101.M20080207-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) "Tabbed Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.2.M20080207-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.2.r332_20080109-0800) "Text Editor Framework" [Active]
org.eclipse.uml2 (2.1.0.v200706251652) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.3.0.v200708221323) "UML2 Ecore Code Generation" [Starting]
org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore Code Generation UI" [Starting]
org.eclipse.uml2.common (1.3.1.v200707311200) "UML2 Common" [Starting]
org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit Support" [Starting]
org.eclipse.uml2.uml (2.1.1.v200707311200) "UML2 UML Model" [Starting]
org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML Exporter for EMF" [Starting]
org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML Importer for EMF" [Starting]
org.eclipse.uml2.uml.edit (2.1.0.v200708301222) "UML2 UML Edit Support" [Starting]
org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor" [Starting]
org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML Resources" [Resolved]
org.eclipse.update.configurator (3.2.101.R33x_v20070810) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.101.R33x_v20070911) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates Scheduler" [Starting]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Active]
org.eclipse.wst.command.env (1.0.205.v200710161954) "Environment Command Framework (headless)" [Starting]
org.eclipse.wst.command.env.core (1.0.203.v200707302047) "Environment Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web services UI" [Starting]
org.eclipse.wst.command.env.ui (1.0.203.v200709052219) "Environment Command Framework (GUI)" [Starting]
org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.104.v200709131115) "EMF Utilities" [Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.105.v200802192030) "EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.200.v200705302225) "Enviornment Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.103.v200802192030) "Common Frameworks" [Starting]
org.eclipse.wst.common.frameworks.ui (1.1.101.v200709122200) "WTP UI Plug-in" [Starting]
org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.104.v200802192030) "Modulecore Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.2.2.v200802200327) "Project Facet Core" [Starting]
org.eclipse.wst.common.project.facet.ui (1.2.1.v200708232226) "Project Facet UI" [Starting]
org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets View" [Starting]
org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI extensions" [Starting]
org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common Properties UI" [Starting]
org.eclipse.wst.common.uriresolver (1.1.203.v200802200327) "Common URI Resolver Framework" [Starting]
org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source DTD Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source Editor" [Starting]
org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD Editor documentation" [Resolved]
org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI Resolver Plug-in" [Starting]
org.eclipse.wst.sse.core (1.1.203.v200802140626) "Structured Text Model" [Starting]
org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured text editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.305.v200802142230) "Structured Source Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) "SSE infopops" [Resolved]
org.eclipse.wst.standard.schemas (1.0.1.v200705302225) "Standard Schemas and DTDs" [Resolved]
org.eclipse.wst.validation (1.1.102.v200709122200) "Validation Framework" [Starting]
org.eclipse.wst.validation.infopop (1.0.202.v200706110217) "WST validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.102.v200706071630) "Validation Framework UI" [Starting]
org.eclipse.wst.xml.core (1.1.202.v200802140626) "Structured Source XML Model" [Starting]
org.eclipse.wst.xml.ui (1.0.302.v200802140626) "XML UI Plugin" [Starting]
org.eclipse.wst.xml.ui.infopop (1.0.2.v200706110217) "XML infopops" [Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.300.v200705302225) "XML editor" [Resolved]
org.eclipse.wst.xsd.core (1.1.202.v200710011705) "XSD Core Plugin" [Starting]
org.eclipse.wst.xsd.ui (1.2.2.v200802141800) "XML Schema Editor" [Starting]
org.eclipse.wst.xsdeditor.doc.user (1.0.300.v200705302225) "XML schema editor" [Resolved]
org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)" [Starting]
org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework" [Starting]
org.junit (3.8.2.v200706111738) "JUnit Testing Framework" [Resolved]
org.junit4 (4.3.1) "JUnit Testing Framework Version 4" [Resolved]
org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]
*** User Preferences:
#Tue Mar 04 10:18:00 CET 2008
/instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_annotati ons=true
/project/mt-test/org.eclipse.core.resources/encoding//model/ meta.ecore_diagram=UTF-8
@org.eclipse.ui.editors=3.3.2.r332_20080109-0800
/instance/org.topcased.web.server/urlValue0=127.0.0.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.invalidJavadocTags=enabled
@org.eclipse.debug.ui=3.3.2.v20080117_r332
@org.eclipse.core.net=1.0.1.r33x_20070709
/instance/org.eclipse.jdt.ui/cleanup_profile=_rene
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=/usr/local/eclipse-devel/plugins/org.ju nit_3.8.2.v200706111738
/instance/eclipseme.core/auto_launch_migration=false
/instance/org.atl.eclipse.adt.editor/Atl.Typing.CloseBraces= false
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_unnecessary_c asts=true
/instance/org.eclipse.gmf.ecore.editor/rulergrid.gridlevel=t rue
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.cleanupprofi les= <?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<profiles version\="2">\r\n<profile kind\="CleanUpProfile" name\="rene" version\="2">\r\n<setting id\="cleanup.add_missing_nls_tags" value\="false"/>\r\n<setting id\="cleanup.format_source_code" value\="true"/>\r\n<setting id\="cleanup.add_missing_override_annotations" value\="true"/>\r\n<setting id\="cleanup.qualify_static_method_accesses_with_declaring_class " value\="false"/>\r\n<setting id\="cleanup.remove_unused_private_types" value\="true"/>\r\n<setting id\="cleanup.remove_unused_private_fields" value\="true"/>\r\n<setting id\="cleanup.always_use_parentheses_in_expressions" value\="false"/>\r\n<setting id\="cleanup.never_use_blocks" value\="true"/>\r\n<setting id\="cleanup.make_local_variable_final" value\="true"/>\r\n<setting id\="cleanup.add_missing_deprecated_annotations" value\="true"/>\r\n<setting id\="cleanup.remove_unused_private_methods" v
alue\="true"/>\r\n<setting id\="cleanup.convert_to_enhanced_for_loop" value\="true"/>\r\n<setting id\="cleanup.remove_unnecessary_nls_tags" value\="true"/>\r\n<setting id\="cleanup.remove_unused_imports" value\="true"/>\r\n<setting id\="cleanup.remove_trailing_whitespaces_ignore_empty" value\="false"/>\r\n<setting id\="cleanup.sort_members" value\="false"/>\r\n<setting id\="cleanup.make_private_fields_final" value\="true"/>\r\n<setting id\="cleanup.add_generated_serial_version_id" value\="false"/>\r\n<setting id\="cleanup.remove_unused_local_variables" value\="true"/>\r\n<setting id\="cleanup.organize_imports" value\="true"/>\r\n<setting id\="cleanup.sort_members_all" value\="false"/>\r\n<setting id\="cleanup.remove_trailing_whitespaces" value\="true"/>\r\n<setting id\="cleanup.never_use_parentheses_in_expressions" value\="true"/>\r\n<setting id\="cleanup.remove_unused_private_members" value\="true"/>\r\n<setting id\="cleanup.remove_unnecessary_casts" value\="true"/>\r\n<sett
ing id\="cleanup.make_parameters_final" value\="true"/>\r\n<setting id\="cleanup.use_this_for_non_static_field_access" value\="true"/>\r\n<setting id\="cleanup.use_blocks_only_for_return_and_throw" value\="false"/>\r\n<setting id\="cleanup.remove_private_constructors" value\="true"/>\r\n<setting id\="cleanup.use_blocks" value\="true"/>\r\n<setting id\="cleanup.add_missing_annotations" value\="true"/>\r\n<setting id\="cleanup.always_use_this_for_non_static_method_access" value\="true"/>\r\n<setting id\="cleanup.use_parentheses_in_expressions" value\="true"/>\r\n<setting id\="cleanup.remove_trailing_whitespaces_all" value\="true"/>\r\n<setting id\="cleanup.always_use_this_for_non_static_field_access" value\="true"/>\r\n<setting id\="cleanup.qualify_static_field_accesses_with_declaring_class " value\="false"/>\r\n<setting id\=" cleanup.use_this_for_non_static_field_access_only_if_necessa ry " value\="false"/>\r\n<setting id\="cleanup.add_default_serial_version_id" value\="true"/>\r\
n<setting id\=" cleanup.use_this_for_non_static_method_access_only_if_necess ary " value\="false"/>\r\n<setting id\="cleanup.use_this_for_non_static_method_access" value\="true"/>\r\n<setting id\=" cleanup.qualify_static_member_accesses_through_instances_wit h_declaring_class " value\="true"/>\r\n<setting id\="cleanup.add_serial_version_id" value\="true"/>\r\n<setting id\=" cleanup.qualify_static_member_accesses_through_subtypes_with _declaring_class " value\="true"/>\r\n<setting id\="cleanup.make_variable_declarations_final" value\="true"/>\r\n<setting id\="cleanup.always_use_blocks" value\="false"/>\r\n<setting id\="cleanup.qualify_static_member_accesses_with_declaring_class " value\="true"/>\r\n</profile>\r\n</profiles>\r\n
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/project/mt-test/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.source=1.6
/project/mt-test.editor/org.eclipse.gmf.bridge.ui.dashboard/ gmf_dashboard/domainGenerationModel=platform\:/resource/mt-t est/model/meta.genmodel
/instance/org.eclipse.gmf.runtime.emf.core/referenced.path.v ariables=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unusedDeclaredThrownException=warning
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.6
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_CODEGEN_ECORE=C\:/eclipse-3/plugins/org.eclips e.emf.codegen.ecore_2.2.1.v200609210005.jar
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/instance/org.eclipse.jdt.ui/cleanup.use_this_for_non_static _method_access=true
/instance/org.eclipse.jdt.ui/sp_cleanup.convert_to_enhanced_ for_loop=false
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=f ile\:/C\:/DOCUME~1/rladan/LOCALS~1/Temp/eclipse/.update/1184 139572802/1184139573209/pde_schema_mt_test-diagram-custom-1_ preview.html|*|
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_CODEGEN=C\:/eclipse-3/plugins/org.eclipse.emf. codegen_2.2.1.v200609210005.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .debug.localVariable=generate
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=always
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
@org.eclipse.core.runtime=3.3.100.v20070530
/instance/fr.tm.elibel.smartqvt.qvteditor/ENABLE_AUTOPARSE=t rue
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.jdt.ui/cleanup.use_blocks=true
/instance/org.eclipse.jdt.ui/cleanup.qualify_static_member_a ccesses_through_subtypes_with_declaring_class=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.ExpressionView= <?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_perspective_to_show=always
/instance/org.eclipse.gmf.bridge.ui/ignore_mapmodel_validati on=true
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
@org.eclipse.ui=3.3.1.M20071128-0800
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.exception.na me=e
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.unusedLocal=optimize out
/instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_nls_tags =false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJsrBytecode=enabled
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.missingJavadocCommentsOverriding=enabled
/instance/org.eclipse.jdt.ui/cleanup.qualify_static_method_a ccesses_with_declaring_class=false
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/fr.tm.elibel.smartqvt.qvtparser/PYTHON_EXE_PATH=C\ :\\Python25\\python.exe
/instance/org.atl.eclipse.adt.editor/Atl.Typing.ClolseBracke ts=false
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1203937481556
/instance/org.eclipse.update.scheduler/day=Every day
/instance/org.eclipse.jdt.ui/sp_cleanup.use_this_for_non_sta tic_method_access=false
/instance/org.eclipse.jdt.ui/sp_cleanup.add_serial_version_i d=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_ECORE=C\:/eclipse-3/plugins/org.eclipse.emf.ec ore_2.2.1.v200609210005.jar
/project/mt-test.edit/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.assertIdentifier=error
/instance/org.eclipse.ui.intro/org.eclipse.sdk.ide_INTRO_THE ME=org.eclipse.ui.intro.universal.circles
/instance/org.eclipse.jdt.ui/cleanup.make_variable_declarati ons_final=true
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_privat e_types=true
/instance/org.eclipse.jdt.ui/cleanup.sort_members=false
/project/mt-test.edit/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.enumIdentifier=error
/instance/org.eclipse.jdt.ui/cleanup.remove_trailing_whitesp aces_ignore_empty=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.missingJavadocTags=warning
/instance/org.eclipse.jdt.ui/sp_cleanup.make_local_variable_ final=false
/instance/org.eclipse.jdt.ui/cleanup.add_default_serial_vers ion_id=true
/instance/org.eclipse.jdt.ui/cleanup.add_missing_annotations =true
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_trailing_whit espaces_ignore_empty=false
/instance/org.eclipse.jdt.ui/sp_cleanup.always_use_this_for_ non_static_field_access=false
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.deprecationInDeprecatedCode=enabled
/instance/org.eclipse.jdt.ui/sp_cleanup.organize_imports=tru e
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.invalidJavadoc=warning
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.syntheticAccessEmulation=warning
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.gettersetter .use.is=true
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_import s=false
/instance/org.eclipse.update.scheduler/enabled=true
/instance/org.eclipse.gmf.bridge.ui/show_dashboard=true
/instance/org.eclipse.jdt.ui/MemberFilterActionGroup.org.ecl ipse.jdt.ui.JavaOutlinePage.4=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ANTLR_HOME=C\:/eclipse/plugins/org.antlr_2.7.6
@org.eclipse.jdt.debug.ui=3.2.102.v20071002_r332
/instance/org.eclipse.update.core/org.eclipse.update.core.au tomaticallyChooseMirror=true
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_trailing_whit espaces_all=true
/project/mt-test.editor/org.eclipse.jdt.core/org.eclipse.jdt .core.compiler.codegen.targetPlatform=1.6
/instance/org.eclipse.ui.intro.universal/org.eclipse.sdk.ide _INTRO_DATA= <?xml version\="1.0" encoding\="utf-8" ?>\r\n<extensions>\r\n <page id\="tutorials">\r\n <group path\="page-content/bottom-left" default\="true">\r\n </group>\r\n <group path\="page-content/bottom-right" default\="true">\r\n </group>\r\n <group path\="page-content/top-left">\r\n <extension id\="org.eclipse.jdt" importance\="low"/>\r\n <extension id\="org.eclipse.team" importance\="low"/>\r\n </group>\r\n <group path\="page-content/top-right">\r\n <extension id\="org.eclipse.pde" importance\="low"/>\r\n </group>\r\n </page>\r\n <page id\="samples">\r\n <group path\="page-content/bottom-left" default\="true">\r\n </group>\r\n <group path\="page-content/bottom-right" default\="true">\r\n </group>\r\n <group path\="page-content/top-left">\r\n <extension id\="org.eclipse.pde.workbench" importance\="low"/>\r\
n </group>\r\n <group path\="page-content/top-right">\r\n <extension id\="org.eclipse.jdt" importance\="low"/>\r\n <extension id\="org.eclipse.pde.swt" importance\="low"/>\r\n </group>\r\n </page>\r\n <page id\="whatsnew">\r\n <group path\="page-content/bottom-left" default\="true">\r\n </group>\r\n <group path\="page-content/bottom-right" default\="true">\r\n </group>\r\n <group path\="page-content/top-left">\r\n <extension id\="org.eclipse.ui.workbench.news" importance\="low"/>\r\n <extension id\="org.eclipse.jdt" importance\="low"/>\r\n <extension id\="org.eclipse.pde.changes" importance\="low"/>\r\n <extension id\="org.eclipse.ui.workbench.migration" importance\="callout"/>\r\n </group>\r\n <group path\="page-content/top-right">\r\n <extension id\="org.eclipse.ui.workbench" importance\="low"/>\r\n </group>\r\n </page>\r\n <page id\="overview">\r\n <g
roup path\="page-content/bottom-left" default\="true">\r\n </group>\r\n <group path\="page-content/bottom-right" default\="true">\r\n </group>\r\n <group path\="page-content/top-left">\r\n <extension id\="org.eclipse.ui.workbench" importance\="low"/>\r\n </group>\r\n <group path\="page-content/top-right">\r\n <extension id\="org.eclipse.jdt" importance\="low"/>\r\n <extension id\="org.eclipse.pde" importance\="low"/>\r\n </group>\r\n </page>\r\n</extensions>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and Settings\\rladan\\workspace
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.workspace-par ticipant
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_unnecessary_n ls_tags=false
/instance/org.eclipse.jdt.ui/sp_cleanup.always_use_blocks=tr ue
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.missingOverrideAnnotation=warning
/instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands/>
@org.eclipse.m2m.atl.adt.editor=2.0.0.200802251526
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.incompleteEnumSwitch=warning
/instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_local_ variables=false
/project/mt-test.editor/org.eclipse.jdt.core/org.eclipse.jdt .core.compiler.source=1.6
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unnecessaryTypeCheck=warning
/instance/org.eclipse.gmf.ecore.editor/rulergrid.gridlinecol or=12632256
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dir ty_editors_before_launch=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.fallthroughCase=warning
/instance/org.eclipse.core.runtime/content-types/org.eclipse .core.runtime.xml/file-extensions=scenario,uml
/project/mt-test.editor/org.eclipse.jdt.core/org.eclipse.jdt .core.compiler.compliance=1.6
/instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@dev.eclipse.org%%cvsroot%tools/location=\:pserver\:anonymous@dev.eclipse.org\:/cvsroot/tools
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.nav igator.layout=2
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_p erspective_on_suspend=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
@org.eclipse.team.cvs.ui=3.3.1.r33x_20070807
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.6
@org.eclipse.ui.intro.universal=3.2.100.v20070530A
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.potentialNullReference=warning
/instance/org.eclipse.jdt.ui/cleanup.remove_trailing_whitesp aces=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=/usr/local/eclipse-devel
/instance/org.topcased.modeler/InitializeDiagramContent=true
/instance/org.eclipse.jdt.ui/cleanup.remove_unused_private_m embers=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.argumentPrefixes=
/instance/org.eclipse.cdt.managedbuilder.core/properties/hel lo\ CPP.cdt.managedbuild.target.gnu.cygwin.exe.1351315284/cdt.ma nagedbuild.config.gnu.cygwin.exe.debug.800667955=\#\r\n\#Mon Jul 09 11\:39\:15 CEST 2007\r\ncdt.managedbuild.tool.gnu.c.compiler.cygwin.exe.debu g.1856867278\=\\\#\\r\\n\\\#Mon Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too l.gnu.archiver.cygwin.base.727317038\=\\\#\\r\\n\\\#Mon Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too lchain.gnu.cygwin.exe.debug.1317606257\=\\\#\\r\\n\\\#Mon Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too l.gnu.assembler.cygwin.exe.debug.1970941068\=\\\#\\r\\n\\\#M on Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too l.gnu.c.linker.cygwin.exe.debug.1121321078\=\\\#\\r\\n\\\#Mo n Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too l.gnu.cpp.linke
r.cygwin.exe.debug.242195898\=\\\#\\r\\n\\\#Mon Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\ncdt.managedbuild.too l.gnu.cpp.compiler.cygwin.exe.debug.658816265\=\\\#\\r\\n\\\ #Mon Jul 09 11\\\:39\\\:15 CEST 2007\\r\\nrebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unnecessaryElse=warning
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="ead" name\="*">\r\n<editor id\="com.omondo.uml.emf.ActivityDiagramEditor"/>\r\n</info >\r\n<info extension\="ecd" name\="*">\r\n<editor id\="com.omondo.uml.emf.ClassDiagramEditor.ecd"/>\r\n</info >\r\n<info extension\="uad" name\="*">\r\n<editor id\="com.omondo.uml.ActivityDiagramEditor"/>\r\n</info>\r\n <info extension\="ucd" name\="*">\r\n<editor id\="com.omondo.uml.ClassDiagramEditor"/>\r\n</info>\r\n <info extension\="upd" name\="*">\r\n<editor id\="com.omondo.uml.ComponentDiagramEditor"/>\r\n</info>\r\n <info extension\="utd" name\="*">\r\n<editor id\="com.omondo.uml.StateDiagramEditor"/>\r\n</info>\r\n <info extension\="urd" name\="*">\r\n<editor id\="com.omondo.uml.RobustnessDiagramEditor"/>\r\n</info >\r\n<info extension\="ecore2xml" name\="*">\r\n<editor id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n</info>
\r\n<info extension\="tcs" name\="*">\r\n<editor id\="org.eclipse.am3.tools.tge"/>\r\n<defaultEditor id\="org.eclipse.am3.tools.tge"/>\r\n</info>\r\n<info extension\="jpage" name\="*">\r\n<editor id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info extension\="shtml" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info extension\="uld" name\="*">\r\n<editor id\="com.omondo.uml.CollaborationDiagramEditor"/>\r\n</info >\r\n<info extension\="ecore" name\="*">\r\n<editor id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n <editor id\="com.omondo.uml.emf.ClassDiagramEditor.ecore"/>\r\n</info >\r\n<info extension\="uud" name\="*">\r\n<editor id\="com.omondo.uml.UseCaseDiagramEditor"/>\r\n</info>\r\n <info extension\="ecore2ecore" name\="*">\r\n<editor id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info extension\="eod" name\="*">\r\n<editor id\="com.omondo.uml.emf.ObjectDiagramEditor"/
>\r\n</info>\r\n<info extension\="htm" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info extension\="html" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor id\="de.byteaction.velocity.editor.Editor"/>\r\n</info>\r\n <info extension\="km3" name\="*">\r\n<editor id\="org.eclipse.am3.tools.tge"/>\r\n<defaultEditor id\="org.eclipse.am3.tools.tge"/>\r\n</info>\r\n<info extension\="xsd" name\="*">\r\n<editor id\="org.eclipse.xsd.presentation.XSDEditorID"/>\r\n</info >\r\n<info extension\="esd" name\="*">\r\n<editor id\="com.omondo.uml.emf.SequenceDiagramEditor"/>\r\n</info >\r\n<info extension\="xmi" name\="*">\r\n<editor id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n<editor id\="org.eclipse.uml2.uml.editor.presentation.UMLEditorID"/ >\r\n</info>\r\n<info extension\="vm" name\="*">\r\n<editor id\=" com.hudson.velocityweb.editors.velocity.VelocityMultiPageEdi tor "/>\r\n<editor id\="de.byteaction.velocity.
editor.Editor"/>\r\n</info>\r\n<info extension\="eud" name\="*">\r\n<editor id\="com.omondo.uml.emf.UseCaseDiagramEditor"/>\r\n</info >\r\n<info extension\="edd" name\="*">\r\n<editor id\="com.omondo.uml.emf.DeploymentDiagramEditor"/>\r\n</info >\r\n<info extension\="datagraph" name\="*">\r\n<editor id\="org.e
Re: [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFMod [message #325959 is a reply to message #325954] |
Tue, 04 March 2008 06:49   |
--------------030304000305070206030700
Rene,
To me it looks likely that it's simply blocked on an input or output to=20
the stream, though how that's possible for a ByteArray version, I don't=20
know.
What's the code doing at line 86 of Transform.doATLTransformation?
> Does anyone have a solution for the random hangs described in the=20
> attached message?
> Rene
> awt.toolkit=3Dsun.awt.windows.WToolkit
> eclipse.buildId=3DM20071023-1652
> eclipse.commands=3D-os
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> C:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.bm=
p
> -launcher
> -name
> Eclipse
> --launcher.library
> C:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3.R=
33x_v20080118\eclipse_1023.dll=20
> -startup
> C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.ja=
r
> -vm
> eclipse.ee.install.verify=3Dfalse
> eclipse.product=3Dorg.eclipse.platform.ide
> eclipse.startTime=3D1204618361408
> eclipse.vm=3DC:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
> eclipse.vmargs=3D-Dosgi.requiredJavaVersion=3D1.5
> -Xms40m
> -Xmx256m
> -XX:MaxPermSize=3D256M
> -Djava.class.path=3DC:\eclipse\plugins\org.eclipse.equinox.l auncher_1.0=
=2E1.R33x_v20080118.jar=20
> eof=3Deof
> file.encoding=3DCp1252
> file.encoding.pkg=3Dsun.io
> file.separator=3D\
> java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
> java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
> java.class.path=3DC:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1=
=2ER33x_v20080118.jar=20
> java.class.version=3D50.0
> java.endorsed.dirs=3DC:\Program Files\Java\jre1.6.0_03\lib\endorsed
> java.ext.dirs=3DC:\Program=20
> java.home=3DC:\Program Files\Java\jre1.6.0_03
> java.io.tmpdir=3DC:\DOCUME~1\rladan\LOCALS~1\Temp\
> java.library.path=3DC:\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\ WINDOWS\sys=
tem32;C:\WINDOWS;C:\Program=20
> Files\Java\jre1.6.0_03\bin\client;C:\Program=20
> Files\Java\jre1.6.0_03\bin;c:\ruby\bin;C:\PROGRA~1\RATIONAL\ RATION~1\NU=
TCROOT\bin;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT\bin\x11;C: \PROGRA~1\RAT=
IONAL\RATION~1\NUTCROOT\mksnt;C:\Perl\bin\;C:\texmf\miktex\b in;C:\WINDOWS=
\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program=20
> Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common=20
> Files\GTK\2.0\bin;C:\Program Files\Common=20
> Files\Compuware\NMShared;C:\Program Files\MySQL\MySQL Server=20
> 5.0\bin;c:\perl\bin;C:\Program Files\Rational\ClearQuest;C:\Program=20
> Files\Unisys\Unisys Rose XML Tools\MOF;C:\Program=20
> Files\QuickTime\QTSystem\;C:\Program Files\Unisys\Unisys Rose XML=20
> Tools\UML;C:\Program Files\Rational\common;C:\Program Files\Common=20
> Files\Compuware\;C:\Program Files\Rational\Rose\TopLink\;C:\Program=20
> Files\Rational\Rational Test;C:\PROGRA~1\ATT\Graphviz\bin;C:\Program=20
> Files\doxygen\bin
> ;C:\Program Files\GNU\GnuPG\pub;c:\Program Files\Microsoft SQL=20
> Server\90\Tools\binn\;C:\Program Files\SSH Communications Security\SSH =
> java.runtime.name=3DJava(TM) SE Runtime Environment
> java.runtime.version=3D1.6.0_03-b05
> java.specification.name=3DJava Platform API Specification
> java.specification.vendor=3DSun Microsystems Inc.
> java.specification.version=3D1.6
> java.vendor=3DSun Microsystems Inc.
> java.vendor.url=3Dhttp://java.sun.com/
> java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
> java.version=3D1.6.0_03
> java.vm.info=3Dmixed mode
> java.vm.name=3DJava HotSpot(TM) Client VM
> java.vm.specification.name=3DJava Virtual Machine Specification
> java.vm.specification.vendor=3DSun Microsystems Inc.
> java.vm.specification.version=3D1.0
> java.vm.vendor=3DSun Microsystems Inc.
> java.vm.version=3D1.6.0_03-b05
> line.separator=3D
> org.eclipse.equinox.launcher.splash.location=3DC:\eclipse\\p lugins\org.=
eclipse.platform_3.3.3.r33x_r20080129\splash.bmp=20
> org.eclipse.update.resolution_url=3D
> org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum=
-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6= 20
> org.osgi.framework.language=3Dnl
> org.osgi.framework.os.name=3DWindowsXP
> org.osgi.framework.os.version=3D5.1
> org.osgi.framework.processor=3Dx86
> org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activati=
on,javax.activity,javax.annotation,javax.annotation.processi ng,javax.cryp=
to,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,j avax.imageio.=
event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax .imageio.plug=
ins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,ja vax.jws.soap,=
javax.lang.model,javax.lang.model.element,javax.lang.model.t ype,javax.lan=
g.model.util,javax.management,javax.management.loading,javax .management.m=
odelmbean,javax.management.monitor,javax.management.openmbea n,javax.manag=
ement.relation,javax.management.remote,javax.management.remo te.rmi,javax.=
management.timer,javax.naming,javax.naming.directory,javax.n aming.event,j=
avax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,ja vax.print,jav=
ax.print.attribute,javax.print.attribute.standard,javax.prin t.event,javax=
=2Ermi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.secu rity.auth,jav=
ax.security.auth.callback,javax.security.auth.=20
> kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.securi=
ty.auth.x500,javax.security.cert,javax.security.sasl,javax.s ound.midi,jav=
ax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.sp i,javax.sql,j=
avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,=
javax.swing.border,javax.swing.colorchooser,javax.swing.even t,javax.swing=
=2Efilechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,ja vax.transacti=
on,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.b ind.annotatio=
n,javax.xml.bind.annotation.adapters,javax.xml.bind.attachme nt,javax.xml.=
bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml. crypto.dom,ja=
vax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cryp to.dsig.keyin=
fo,javax.xml.crypto.dsig.spec,javax.xml.datat=20
> ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stre=
am,javax.xml.stream.events,javax.xml.stream.util,javax.xml.t ransform,java=
x.xml.transform.dom,javax.xml.transform.sax,javax.xml.transf orm.stax,java=
x.xml.transform.stream,javax.xml.validation,javax.xml.ws,jav ax.xml.ws.han=
dler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.w s.soap,javax.=
xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.o mg.CORBA_2_3,=
org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.o mg.CORBA.ORBP=
ackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage, org.omg.CosNa=
ming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNa ming.NamingCo=
ntextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.Dyna micAny.DynAny=
FactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP, org.omg.IOP.C=
odecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messagin g,org.omg.Por=
tableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPack age,org.omg.P=
ortableServer,org.omg.PortableServer.Curren=20
> tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServe=
r.POAPackage,org.omg.PortableServer.portable,org.omg.Portabl eServer.Serva=
ntLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rm i,org.w3c.dom=
,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,or g.w3c.dom.htm=
l,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets, org.w3c.dom.t=
raversal,org.w3c.dom.views=20
> org.osgi.framework.vendor=3DEclipse
> org.osgi.framework.version=3D1.4.0
> org.osgi.supports.framework.extension=3Dtrue
> org.osgi.supports.framework.fragment=3Dtrue
> org.osgi.supports.framework.requirebundle=3Dtrue
> os.arch=3Dx86
> os.name=3DWindows XP
> os.version=3D5.1
> osgi.arch=3Dx86
> osgi.bundles=3Dorg.eclipse.equinox.common@2:start,=20
> org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start=
> osgi.bundlestore=3DC:\eclipse\configuration\org.eclipse.osgi \bundles
> osgi.compatibility.bootdelegation=3Dtrue
> osgi.configuration.area=3Dfile:/C:/eclipse/configuration/
> osgi.framework=3Dfile:/c:/eclipse/plugins/org.eclipse.osgi_3 .3.2.R33x_v=
20080105.jar=20
> osgi.framework.beginningstartlevel=3D1
> osgi.framework.shape=3Djar
> osgi.framework.version=3D3.3.2.R33x_v20080105
> osgi.install.area=3Dfile:/C:/eclipse/
> osgi.instance.area=3Dfile:/C:/Documents and Settings/rladan/workspace/
> osgi.instance.area.default=3Dfile:/C:/Documents and=20
> osgi.logfile=3DC:\Documents and Settings\rladan\workspace\.metadata\.lo=
g
> osgi.manifest.cache=3DC:\eclipse\configuration\org.eclipse.o sgi\manifes=
ts
> osgi.nl=3Dnl_NL
> osgi.os=3Dwin32
> osgi.splashLocation=3DC:\eclipse\\plugins\org.eclipse.platfo rm_3.3.3.r3=
> osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
> osgi.syspath=3Dc:\eclipse\plugins
> osgi.ws=3Dwin32
> path.separator=3D;
> sun.arch.data.model=3D32
> sun.boot.class.path=3DC:\Program=20
> Files\Java\jre1.6.0_03\lib\resources.jar;C:\Program=20
> Files\Java\jre1.6.0_03\lib\rt.jar;C:\Program=20
> Files\Java\jre1.6.0_03\lib\sunrsasign.jar;C:\Program=20
> Files\Java\jre1.6.0_03\lib\jsse.jar;C:\Program=20
> Files\Java\jre1.6.0_03\lib\jce.jar;C:\Program=20
> Files\Java\jre1.6.0_03\lib\charsets.jar;C:\Program=20
> sun.boot.library.path=3DC:\Program Files\Java\jre1.6.0_03\bin
> sun.cpu.endian=3Dlittle
> sun.cpu.isalist=3D
> sun.desktop=3Dwindows
> sun.io.unicode.encoding=3DUnicodeLittle
> sun.jnu.encoding=3DCp1252
> sun.management.compiler=3DHotSpot Client Compiler
> sun.net.client.defaultConnectTimeout=3D60000
> sun.net.client.defaultReadTimeout=3D60000
> sun.os.patch.level=3DService Pack 2
> user.country=3DNL
> user.dir=3DC:\eclipse
> user.home=3DC:\Documents and Settings\rladan
> user.language=3Dnl
> user.name=3Drladan
> user.timezone=3DEurope/Berlin
> user.variant=3D
> *** Features:
> org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Eclipse=20
> CVS Client"
> org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)=
> org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code=20
> Generator"
> org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code=20
> Generation"
> org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code =
> Generation UI"
> org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code=20
> Generator UI"
> org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert=20
> Support"
> org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework=20
> org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Suppor=
t"
> org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor=
> org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling=20
> org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse=20
> org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object=20
> org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF=20
> Model Query"
> org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF =
> org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling=20
> org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88)=20
> org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_)=20
> org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88)=20
> org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7)=20
> org.eclipse.ocl (1.1.2.v200711262212-3219oA55P6H8I9HDE) "Object=20
> org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse=20
> org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft)=20
> "Eclipse Platform"
> org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc)=20
> "Eclipse RCP"
> com.ibm.icu (3.6.1.v20070906) "International Components for Unicode=20
> javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle" =
> [Resolved]
> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge=20
> LPG" [Resolved]
> org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0=20
> org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons=20
> org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"=20
> [Resolved]
> org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene=20
> org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"=20
> [Resolved]
> org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Startin=
g]
> org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content=20
> Mechanism" [Active]
> org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data=20
> Binding" [Resolved]
> org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data =
> org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression=20
> Language" [Active]
> org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers"=20
> [Active]
> org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems"=20
> [Active]
> org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File=20
> org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"=20
> [Active]
> org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection=20
> org.eclipse.core.resources (3.3.1.R33x_v20080205) "Core Resource=20
> org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core=20
> org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource=20
> org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core=20
> org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)=20
> org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)=20
> org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting=
> org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework=20
> Draw2d" [Starting]
> org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework=20
> (EMF)" [Starting]
> org.eclipse.emf.cheatsheets (2.3.0.v200802051830) "EMF Cheat Sheets"=20
> [Starting]
> org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore Code =
> org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code=20
> org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"=20
> [Starting]
> org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert=20
> Support" [Starting]
> org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change=20
> Model" [Starting]
> org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore=20
> org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit=20
> Support" [Starting]
> org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore=20
> Editor" [Starting]
> org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export=20
> Support" [Starting]
> org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import=20
> Support" [Starting]
> org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore=20
> org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated=20
> org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose=20
> org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse Modeling=20
> org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse=20
> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"=20
> [Starting]
> org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to=20
> org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830)=20
> org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to XML=20
> Mapping" [Starting]
> org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to=20
> org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI"=20
> [Starting]
> org.eclipse.emf.ocl (1.1.1.v200709121956) "Object Constraint Language=20
> org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query" [Starting=
> org.eclipse.emf.query.ocl (1.1.0.v200706071712) "EMF Model Query OCL=20
> org.eclipse.emf.transaction (1.1.2.v200712061832) "EMF Model=20
> org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model=20
> org.eclipse.emf.validation (1.1.1.v200708161445) "EMF Validation=20
> org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation=20
> org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF=20
> org.eclipse.emf.workspace (1.1.2.v200712061832) "EMF Model Transaction =
> org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model=20
> org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application=20
> Container" [Active]
> org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"=20
> [Active]
> org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http=20
> Service" [Starting]
> org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) "Http Service =
> org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services =
> Servlet" [Starting]
> org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp=20
> org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp=20
> org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) "Equinox Launcher" =
> [Resolved]
> org.eclipse.equinox.launcher.win32.win32.x86 (1.0.3.R33x_v20080118)=20
> org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) "Eclipse=20
> org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension=20
> org.eclipse.gef (3.2.102.v20080116) "Graphical Editing Framework"=20
> [Starting]
> org.eclipse.help.appserver (3.1.200.v20070510) "Help Application=20
> Server" [Starting]
> org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Startin=
g]
> org.eclipse.help.webapp (3.3.2.v20071102_33x) "Help System Webapp"=20
> [Starting]
> org.eclipse.jdt (3.3.1.r332_v20080131) "Eclipse Java Development=20
> Tools" [Resolved]
> org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) "Java Annotation=20
> org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) "Java=20
> org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) "Java Annotation=20
> org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) "Java=20
> org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) "Java Compiler Tool=20
> Support" [Resolved]
> org.eclipse.jdt.core (3.3.3.v_793_R33x) "Java Development Tools Core"=20
> [Active]
> org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code=20
> org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]=
> org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) "JDI Debug UI"=20
> [Starting]
> org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) "Eclipse Java=20
> org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) "Java Development=20
> org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development =
> org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java=20
> org.eclipse.jdt.launching (3.3.2.v20080115_r332) "Java Development=20
> org.eclipse.jdt.ui (3.3.2.r332_20080128) "Java Development Tools UI"=20
> [Active]
> org.eclipse.jem.util (2.0.2.v200802192030) "Java EMF Model Utilities"=20
> [Starting]
> org.eclipse.jface.databinding (1.1.1.M20080207-0800) "JFace Data=20
> org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text" [Resolve=
d]
> org.eclipse.ltk.core.refactoring (3.3.1.r332_20080128) "Refactoring=20
> Core" [Active]
> org.eclipse.ltk.ui.refactoring (3.3.1.r332_20080128) "Refactoring UI"=20
> [Starting]
> org.eclipse.m2m.atl.adt.builder (2.0.0.200802251526) "ATL Builder"=20
> [Starting]
> org.eclipse.m2m.atl.adt.debug (2.0.0.200802251526) "ATL Debugger"=20
> [Starting]
> org.eclipse.m2m.atl.adt.editor (2.0.0.200802251526) "ATL Editor" [Activ=
e]
> org.eclipse.m2m.atl.adt.perspective (2.0.0.200802251526) "ATL=20
> org.eclipse.m2m.atl.adt.wizard (2.0.0.200802251526) "ATL Wizard" [Activ=
e]
> org.eclipse.m2m.atl.compilers.atl2006 (2.0.0.200802251526) "ATL=20
> org.eclipse.m2m.atl.drivers.emf4atl (2.0.0.200802251526) "EMF4ATL=20
> Plug-in" [Resolved]
> org.eclipse.m2m.atl.drivers.mdr4atl (2.0.0.200802251526) "MDR4ATL=20
> Plug-in" [Starting]
> org.eclipse.m2m.atl.drivers.uml24atl (2.0.0.200802251526) "UML24ATL=20
> Plug-in" [Resolved]
> org.eclipse.m2m.atl.engine (2.0.0.200802251526) "ATLAS Transformation=20
> org.eclipse.m2m.atl.engine.emfvm (2.0.0.200802251526) "ATL EMF Virtual =
> Machine" [Starting]
> org.eclipse.m2m.atl.engine.vm (2.0.0.200802251526) "ATL VM Plug-in"=20
> [Active]
> org.eclipse.m2m.atl.ocl.core (2.0.0.200802251526) "Ocl Core Plug-in"=20
> [Starting]
> org.eclipse.ocl (1.1.2.v200711262212) "Object Constraint Language=20
> org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for=20
> Ecore" [Starting]
> org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1=20
> org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility=20
> Classes" [Resolved]
> org.eclipse.pde (3.3.1.r33x_r20080129) "Eclipse Plug-in Development=20
> org.eclipse.pde.build (3.3.2.v20071019) "Plug-in Development=20
> org.eclipse.pde.core (3.3.2.v20071121-0800) "Plug-in Development Core" =
> [Active]
> org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in=20
> org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit=20
> org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development=20
> org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI"=20
> [Starting]
> org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"=20
> [Starting]
> org.eclipse.platform (3.3.3.r33x_r20080129) "Eclipse Platform" [Startin=
g]
> org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse=20
> org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support"=20
> [Starting]
> org.eclipse.swt.win32.win32.x86 (3.3.3.v3349) "Standard Widget Toolkit =
> org.eclipse.team.core (3.3.1.r33x_20080128) "Team Support Core" [Active=
> org.eclipse.team.cvs.core (3.3.2.r33x_20080128) "CVS Team Provider=20
> Core" [Starting]
> org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI"=20
> [Starting]
> org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting=
> org.eclipse.ui.cheatsheets (3.3.1.v20080125_33x) "Cheat Sheets"=20
> [Starting]
> org.eclipse.ui.editors (3.3.2.r332_20080109-0800) "Default Text=20
> Editor" [Active]
> org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools"=20
> [Active]
> org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI=20
> org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework"=20
> [Starting]
> org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal=20
> Welcome" [Starting]
> org.eclipse.ui.navigator (3.3.2.M20080207-0800) "Common Navigator=20
> View" [Starting]
> org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator=20
> org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management=20
> UI" [Active]
> org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21=20
> org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) "Tabbed=20
> org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32=20
> org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010)=20
> org.eclipse.ui.workbench.texteditor (3.3.2.r332_20080109-0800) "Text=20
> org.eclipse.uml2.codegen.ecore (1.3.0.v200708221323) "UML2 Ecore Code=20
> org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore=20
> org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit=20
> Support" [Starting]
> org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML=20
> org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML=20
> org.eclipse.uml2.uml.edit (2.1.0.v200708301222) "UML2 UML Edit=20
> Support" [Starting]
> org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor"=20
> [Starting]
> org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML=20
> org.eclipse.update.configurator (3.2.101.R33x_v20070810)=20
> org.eclipse.update.core (3.2.101.R33x_v20070911) "Install/Update Core" =
> [Active]
> org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core =
> org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates=20
> org.eclipse.wst.command.env (1.0.205.v200710161954) "Environment=20
> org.eclipse.wst.command.env.core (1.0.203.v200707302047) "Environment=20
> org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web=20
> org.eclipse.wst.command.env.ui (1.0.203.v200709052219) "Environment=20
> org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core=20
> Plug-in" [Starting]
> org.eclipse.wst.common.emf (1.1.104.v200709131115) "EMF Utilities"=20
> [Starting]
> org.eclipse.wst.common.emfworkbench.integration=20
> org.eclipse.wst.common.environment (1.0.200.v200705302225)=20
> org.eclipse.wst.common.frameworks (1.1.103.v200802192030) "Common=20
> org.eclipse.wst.common.frameworks.ui (1.1.101.v200709122200) "WTP UI=20
> Plug-in" [Starting]
> org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST=20
> org.eclipse.wst.common.modulecore (1.1.104.v200802192030) "Modulecore=20
> Plug-in" [Starting]
> org.eclipse.wst.common.project.facet.core (1.2.2.v200802200327)=20
> org.eclipse.wst.common.project.facet.ui (1.2.1.v200708232226) "Project =
> org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets=20
> View" [Starting]
> org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI=20
> org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common=20
> org.eclipse.wst.common.uriresolver (1.1.203.v200802200327) "Common URI =
> org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source=20
> org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source Editor" =
> [Starting]
> org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor=20
> org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD Editor =
> org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI=20
> org.eclipse.wst.sse.core (1.1.203.v200802140626) "Structured Text=20
> Model" [Starting]
> org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured text=20
> org.eclipse.wst.sse.ui (1.0.305.v200802142230) "Structured Source=20
> Editor" [Starting]
> org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) "SSE infopops"=20
> [Resolved]
> org.eclipse.wst.standard.schemas (1.0.1.v200705302225) "Standard=20
> org.eclipse.wst.validation (1.1.102.v200709122200) "Validation=20
> org.eclipse.wst.validation.infopop (1.0.202.v200706110217) "WST=20
> org.eclipse.wst.validation.ui (1.1.102.v200706071630) "Validation=20
> org.eclipse.wst.xml.core (1.1.202.v200802140626) "Structured Source=20
> org.eclipse.wst.xml.ui (1.0.302.v200802140626) "XML UI Plugin" [Startin=
g]
> org.eclipse.wst.xml.ui.infopop (1.0.2.v200706110217) "XML infopops"=20
> [Resolved]
> org.eclipse.wst.xmleditor.doc.user (1.0.300.v200705302225) "XML=20
> editor" [Resolved]
> org.eclipse.wst.xsd.core (1.1.202.v200710011705) "XSD Core Plugin"=20
> [Starting]
> org.eclipse.wst.xsd.ui (1.2.2.v200802141800) "XML Schema Editor"=20
> [Starting]
> org.eclipse.wst.xsdeditor.doc.user (1.0.300.v200705302225) "XML schema =
> editor" [Resolved]
> org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)" =
> [Starting]
> org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework" =
> [Starting]
> /instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_annotati ons=3Dtrue
> /project/mt-test/org.eclipse.core.resources/encoding//model/ meta.ecore_=
diagram=3DUTF-8=20
> @org.eclipse.ui.editors=3D3.3.2.r332_20080109-0800
> /instance/org.topcased.web.server/urlValue0=3D127.0.0.1
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.in=
validJavadocTags=3Denabled=20
> @org.eclipse.debug.ui=3D3.3.2.v20080117_r332
> @org.eclipse.core.net=3D1.0.1.r33x_20070709
> /instance/org.eclipse.jdt.ui/cleanup_profile=3D_rene
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.J=
UNIT_HOME=3D/usr/local/eclipse-devel/plugins/org.junit_3.8.2 .v20070611173=
8=20
> /instance/eclipseme.core/auto_launch_migration=3Dfalse
> /instance/org.atl.eclipse.adt.editor/Atl.Typing.CloseBraces= 3Dfalse
> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unnecessary_c asts=3Dtrue=
> /instance/org.eclipse.gmf.ecore.editor/rulergrid.gridlevel=3 Dtrue
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.cleanupprofi les=3D <?xml=
=20
> version\=3D"1.0" encoding\=3D"UTF-8" standalone\=3D"no"?>\r\n<profiles =
> version\=3D"2">\r\n<profile kind\=3D"CleanUpProfile" name\=3D"rene"=20
> version\=3D"2">\r\n<setting id\=3D"cleanup.add_missing_nls_tags"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.format_source_code"=20
> value\=3D"true"/>\r\n<setting=20
> id\=3D"cleanup.add_missing_override_annotations"=20
> id\=3D"cleanup.qualify_static_method_accesses_with_declaring_class "=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.remove_unused_private_typ=
es"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unused_private_fiel=
ds"=20
> id\=3D"cleanup.always_use_parentheses_in_expressions"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.never_use_blocks"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.make_local_variable_final"=
=20
> id\=3D"cleanup.add_missing_deprecated_annotations"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unused_private_meth=
ods" v
> alue\=3D"true"/>\r\n<setting id\=3D"cleanup.convert_to_enhanced_for_loo=
p"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unnecessary_nls_tag=
s"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unused_imports"=20
> id\=3D"cleanup.remove_trailing_whitespaces_ignore_empty"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.sort_members"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.make_private_fields_final=
"=20
> id\=3D"cleanup.add_generated_serial_version_id"=20
> value\=3D"false"/>\r\n<setting=20
> id\=3D"cleanup.remove_unused_local_variables"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.organize_imports"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.sort_members_all"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.remove_trailing_whitespac=
es"=20
> id\=3D"cleanup.never_use_parentheses_in_expressions"=20
> id\=3D"cleanup.remove_unused_private_members"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unnecessary_casts" =
> ing id\=3D"cleanup.make_parameters_final" value\=3D"true"/>\r\n<setting=
=20
> id\=3D"cleanup.use_this_for_non_static_field_access"=20
> id\=3D"cleanup.use_blocks_only_for_return_and_throw"=20
> value\=3D"false"/>\r\n<setting id\=3D"cleanup.remove_private_constructo=
rs"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.use_blocks"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.add_missing_annotations"=20
> id\=3D"cleanup.always_use_this_for_non_static_method_access "=20
> id\=3D"cleanup.use_parentheses_in_expressions"=20
> id\=3D"cleanup.remove_trailing_whitespaces_all"=20
> id\=3D"cleanup.always_use_this_for_non_static_field_access"=20
> id\=3D"cleanup.qualify_static_field_accesses_with_declaring_class "=20
> id\=3D" cleanup.use_this_for_non_static_field_access_only_if_necessa ry " =
> id\=3D"cleanup.add_default_serial_version_id" value\=3D"true"/>\r\
> n<setting=20
> id\=3D" cleanup.use_this_for_non_static_method_access_only_if_necess ary "=
=20
> id\=3D"cleanup.use_this_for_non_static_method_access"=20
> id\=3D" cleanup.qualify_static_member_accesses_through_instances_wit h_de=
claring_class"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.add_serial_version_id"=20
> id\=3D" cleanup.qualify_static_member_accesses_through_subtypes_with _dec=
laring_class"=20
> id\=3D"cleanup.make_variable_declarations_final"=20
> value\=3D"true"/>\r\n<setting id\=3D"cleanup.always_use_blocks"=20
> id\=3D"cleanup.qualify_static_member_accesses_with_declaring_class "=20
> value\=3D"true"/>\r\n</profile>\r\n</profiles>\r\n
> /instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.or=
g.eclipse.jdt.debug.ui.show_null_entries=3Dtrue=20
> /project/mt-test/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.sou=
rce=3D1.6=20
> /project/mt-test.editor/org.eclipse.gmf.bridge.ui.dashboard/ gmf_dashboa=
rd/domainGenerationModel=3Dplatform\:/resource/mt-test/model /meta.genmode=
l=20
> /instance/org.eclipse.gmf.runtime.emf.core/referenced.path.v ariables=3D=
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.un=
usedDeclaredThrownException=3Dwarning=20
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates=3D=
<?xml=20
> version\=3D"1.0" encoding\=3D"UTF-8" standalone\=3D"no"?><templates/>
=3D1.6=20
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.E=
MF_CODEGEN_ECORE=3DC\:/eclipse-3/plugins/org.eclipse.emf.cod egen.ecore_2.=
2.1.v200609210005.jar=20
> /instance/org.eclipse.ui.editors/lineNumberRuler=3Dtrue
> /instance/org.eclipse.jdt.ui/cleanup.use_this_for_non_static _method_acc=
ess=3Dtrue=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.convert_to_enhanced_ for_loop=3D=
false=20
> /instance/org.eclipse.ui.browser/internalWebBrowserHistory=3 Dfile\:/C\:=
/DOCUME~1/rladan/LOCALS~1/Temp/eclipse/.update/1184139572802 /118413957320=
9/pde_schema_mt_test-diagram-custom-1_preview.html|*|=20
MF_CODEGEN=3DC\:/eclipse-3/plugins/org.eclipse.emf.codegen_2 .2.1.v2006092=
10005.jar=20
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=3Dtr=
ue
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .debug.loca=
lVariable=3Dgenerate=20
> /instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=3Dalways
> /configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=3Dfal=
se
> @org.eclipse.core.runtime=3D3.3.100.v20070530
> /instance/fr.tm.elibel.smartqvt.qvteditor/ENABLE_AUTOPARSE=3 Dtrue
> /instance/org.eclipse.pde.runtime/orderType=3D2
> /instance/org.eclipse.jdt.ui/cleanup.use_blocks=3Dtrue
> /instance/org.eclipse.jdt.ui/cleanup.qualify_static_member_a ccesses_thr=
ough_subtypes_with_declaring_class=3Dtrue=20
> /instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=3D1| Courier=20
> /instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.=
ExpressionView=3D<?xml=20
> version\=3D"1.0" encoding\=3D"UTF-8"?>\r\n<VariablesViewMemento=20
> org.eclipse.debug.ui.SASH_DETAILS_PART\=3D"315"=20
> org.eclipse.debug.ui.SASH_VIEW_PART\=3D"684"/>
> /instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_=
perspective_to_show=3Dalways=20
> /instance/org.eclipse.gmf.bridge.ui/ignore_mapmodel_validati on=3Dtrue
> /instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=3Dtrue
> /instance/org.eclipse.core.resources/version=3D1
> /instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=3Dtr ue
> @org.eclipse.ui=3D3.3.1.M20071128-0800
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.exception.na me=3De
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.un=
usedLocal=3Doptimize=20
> out
> /instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_nls_tags =3Dfalse
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.in=
lineJsrBytecode=3Denabled=20
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.mi=
ssingJavadocCommentsOverriding=3Denabled=20
> /instance/org.eclipse.jdt.ui/cleanup.qualify_static_method_a ccesses_wit=
h_declaring_class=3Dfalse=20
> /instance/org.eclipse.pde.runtime/orderValue=3D-1
> /instance/fr.tm.elibel.smartqvt.qvtparser/PYTHON_EXE_PATH=3D C\:\\Python=
25\\python.exe=20
> /instance/org.atl.eclipse.adt.editor/Atl.Typing.ClolseBracke ts=3Dfalse
participant_sec_id=3D1203937481556=20
> /instance/org.eclipse.update.scheduler/day=3DEvery day
> /instance/org.eclipse.jdt.ui/sp_cleanup.use_this_for_non_sta tic_method_=
access=3Dfalse=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.add_serial_version_i d=3Dfalse
MF_ECORE=3DC\:/eclipse-3/plugins/org.eclipse.emf.ecore_2.2.1 .v20060921000=
5.jar=20
> /project/mt-test.edit/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compile=
r.problem.assertIdentifier=3Derror=20
> /instance/org.eclipse.ui.intro/org.eclipse.sdk.ide_INTRO_THE ME=3Dorg.ec=
lipse.ui.intro.universal.circles=20
> /instance/org.eclipse.jdt.ui/cleanup.make_variable_declarati ons_final=3D=
true=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_privat e_types=3Dt=
rue
> /instance/org.eclipse.jdt.ui/cleanup.sort_members=3Dfalse
r.problem.enumIdentifier=3Derror=20
> /instance/org.eclipse.jdt.ui/cleanup.remove_trailing_whitesp aces_ignore=
_empty=3Dfalse=20
ssingJavadocTags=3Dwarning=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.make_local_variable_ final=3Dfal=
se
> /instance/org.eclipse.jdt.ui/cleanup.add_default_serial_vers ion_id=3Dtr=
ue
> /instance/org.eclipse.jdt.ui/cleanup.add_missing_annotations =3Dtrue
> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_trailing_whit espaces_ign=
ore_empty=3Dfalse=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.always_use_this_for_ non_static_=
field_access=3Dfalse=20
> /instance/org.eclipse.ui.editors/overviewRuler_migration=3Dm igrated_3.1=
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.de=
precationInDeprecatedCode=3Denabled=20
> /instance/org.eclipse.jdt.ui/sp_cleanup.organize_imports=3Dt rue
validJavadoc=3Dwarning=20
> /instance/org.eclipse.help.ui/browser.maximized=3Dfalse
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.sy=
ntheticAccessEmulation=3Dwarning=20
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.gettersetter .use.is=3Dt=
rue
> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_import s=3Dfalse
> /instance/org.eclipse.update.scheduler/enabled=3Dtrue
> /instance/org.eclipse.gmf.bridge.ui/show_dashboard=3Dtrue
> /instance/org.eclipse.jdt.ui/MemberFilterActionGroup.org.ecl ipse.jdt.ui=
=2EJavaOutlinePage.4=3Dtrue=20
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.A=
NTLR_HOME=3DC\:/eclipse/plugins/org.antlr_2.7.6=20
> @org.eclipse.jdt.debug.ui=3D3.2.102.v20071002_r332
> /instance/org.eclipse.update.core/org.eclipse.update.core.au tomatically=
ChooseMirror=3Dtrue=20
=3Dtrue=20
> /project/mt-test.editor/org.eclipse.jdt.core/org.eclipse.jdt .core.compi=
ler.codegen.targetPlatform=3D1.6=20
=3D<?xml=20
> version\=3D"1.0" encoding\=3D"utf-8" ?>\r\n<extensions>\r\n <page=20
> id\=3D"tutorials">\r\n <group path\=3D"page-content/bottom-left"=20
> default\=3D"true">\r\n </group>\r\n <group=20
> path\=3D"page-content/bottom-right" default\=3D"true">\r\n =20
> </group>\r\n <group path\=3D"page-content/top-left">\r\n =20
> <extension id\=3D"org.eclipse.jdt" importance\=3D"low"/>\r\n =20
> <extension id\=3D"org.eclipse.team" importance\=3D"low"/>\r\n =20
> </group>\r\n <group path\=3D"page-content/top-right">\r\n =
> <extension id\=3D"org.eclipse.pde" importance\=3D"low"/>\r\n =20
> </group>\r\n </page>\r\n <page id\=3D"samples">\r\n <group=20
> path\=3D"page-content/bottom-left" default\=3D"true">\r\n =20
> </group>\r\n <group path\=3D"page-content/bottom-right"=20
> path\=3D"page-content/top-left">\r\n <extension=20
> id\=3D"org.eclipse.pde.workbench" importance\=3D"low"/>\r\
> path\=3D"page-content/top-right">\r\n <extension=20
> id\=3D"org.eclipse.jdt" importance\=3D"low"/>\r\n <extension=20
> id\=3D"org.eclipse.pde.swt" importance\=3D"low"/>\r\n </group>\r\n=
=20
> </page>\r\n <page id\=3D"whatsnew">\r\n <group=20
> path\=3D&
Re: [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFMod [message #325961 is a reply to message #325959] |
Tue, 04 March 2008 06:59   |
Originally posted by: r.c.ladan.tue.nl
Ed Merks wrote:
> Rene,
> know.
Line 86 is :
this.amh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF); // FIXME hangs
where this.amh is declared as:
AtlModelHandler amh;
Input is from a number of ByteArrayInputStreams,
output is to a number of ByteArrayOutputStreams.
> Rene Ladan wrote:
>> This seems Eclipse-specific, not really ATL-specific....
>> attached message?
>> Thanks,
>> Rene
>> Configuration details:
>> *** Date: dinsdag 4 maart 2008 10:17:57 Duitsland
>> *** Platform Details:
>> *** System properties:
>> awt.toolkit=sun.awt.windows.WToolkit
>> eclipse.buildId=M20071023-1652
>> eclipse.commands=-os
>> win32
>> -ws
>> win32
>> -arch
>> x86
>> -showsplash
>> C:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.bmp
>> -launcher
>> C:\eclipse\eclipse.exe
>> -name
>> Eclipse
>> --launcher.library
>> C:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3.R33x_v20080118\eclipse_1023.dll
>> -startup
>> C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.jar
>> -vm
>> eclipse.ee.install.verify=false
>> eclipse.product=org.eclipse.platform.ide
>> eclipse.startTime=1204618361408
>> eclipse.vm=C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
>> eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
>> -Xms40m
>> -Xmx256m
>> -XX:MaxPermSize=256M
>> -Djava.class.path=C:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
>> eof=eof
>> file.encoding=Cp1252
>> file.encoding.pkg=sun.io
>> file.separator=\
>> java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
>> java.awt.printerjob=sun.awt.windows.WPrinterJob
>> java.class.path=C:\eclipse\plugins\org.eclipse.equinox.launc her_1.0.1.R33x_v20080118.jar
>> java.class.version=50.0
>> java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_03\lib\endorsed
>> java.ext.dirs=C:\Program
>> Files\Java\jre1.6.0_03\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
>> java.home=C:\Program Files\Java\jre1.6.0_03
>> java.io.tmpdir=C:\DOCUME~1\rladan\LOCALS~1\Temp\
>> java.library.path=C:\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\WI NDOWS\system32;C:\WINDOWS;C:\Program
>> Files\Java\jre1.6.0_03\bin;c:\ruby\bin;C:\PROGRA~1\RATIONAL\ RATION~1\NUTCROOT\bin;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT \bin\x11;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT\mksnt;C:\Per l\bin\;C:\texmf\miktex\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program
>> Files\doxygen\bin
>> Secure Shell;C:\Program Files\LQN Solvers;C:\Program Files\Nmap
>> java.runtime.name=Java(TM) SE Runtime Environment
>> java.runtime.version=1.6.0_03-b05
>> java.specification.name=Java Platform API Specification
>> java.specification.vendor=Sun Microsystems Inc.
>> java.specification.version=1.6
>> java.vendor=Sun Microsystems Inc.
>> java.vendor.url=http://java.sun.com/
>> java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
>> java.version=1.6.0_03
>> java.vm.info=mixed mode
>> java.vm.name=Java HotSpot(TM) Client VM
>> java.vm.specification.name=Java Virtual Machine Specification
>> java.vm.specification.vendor=Sun Microsystems Inc.
>> java.vm.specification.version=1.0
>> java.vm.vendor=Sun Microsystems Inc.
>> java.vm.version=1.6.0_03-b05
>> line.separator=
>> org.eclipse.equinox.launcher.splash.location=C:\eclipse\\plu gins\org.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp
>> org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
>> org.osgi.framework.language=nl
>> org.osgi.framework.os.name=WindowsXP
>> org.osgi.framework.os.version=5.1
>> org.osgi.framework.processor=x86
>> org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management..remote,javax.management.remote.rmi,javax.manage ment.timer,javax.naming,javax.naming.directory,javax.naming. event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net .ssl,javax.print,javax.print.attribute,javax.print.attribute ..standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax .rmi.ssl,javax.script,javax.security.auth,javax.security.aut h.callback,javax.security.a
uth.
>> kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.d
ata
>> t
>> ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Cu
rre
>> n
>> tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c. dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.do m.traversal,org.w3c.dom.views
>> ,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
>> org.osgi.framework.vendor=Eclipse
>> org.osgi.framework.version=1.4.0
>> org.osgi.supports.framework.extension=true
>> org.osgi.supports.framework.fragment=true
>> org.osgi.supports.framework.requirebundle=true
>> os.arch=x86
>> os.name=Windows XP
>> os.version=5.1
>> osgi.arch=x86
>> osgi.bundles=org.eclipse.equinox.common@2:start,
>> osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
>> osgi.compatibility.bootdelegation=true
>> osgi.configuration.area=file:/C:/eclipse/configuration/
>> osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.3 .2.R33x_v20080105.jar
>> osgi.framework.beginningstartlevel=1
>> osgi.framework.shape=jar
>> osgi.framework.version=3.3.2.R33x_v20080105
>> osgi.install.area=file:/C:/eclipse/
>> osgi.instance.area=file:/C:/Documents and Settings/rladan/workspace/
>> osgi.instance.area.default=file:/C:/Documents and
>> osgi.logfile=C:\Documents and Settings\rladan\workspace\.metadata\.log
>> osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
>> osgi.nl=nl_NL
>> osgi.os=win32
>> osgi.splashLocation=C:\eclipse\\plugins\org.eclipse.platform _3.3.3.r33x_r20080129\splash.bmp
>> osgi.splashPath=platform:/base/plugins/org.eclipse.platform
>> osgi.syspath=c:\eclipse\plugins
>> osgi.ws=win32
>> path.separator=;
>> sun.arch.data.model=32
>> sun.boot.class.path=C:\Program
>> Files\Java\jre1.6.0_03\classes
>> sun.boot.library.path=C:\Program Files\Java\jre1.6.0_03\bin
>> sun.cpu.endian=little
>> sun.cpu.isalist=
>> sun.desktop=windows
>> sun.io.unicode.encoding=UnicodeLittle
>> sun.jnu.encoding=Cp1252
>> sun.management.compiler=HotSpot Client Compiler
>> sun.net.client.defaultConnectTimeout=60000
>> sun.net.client.defaultReadTimeout=60000
>> sun.os.patch.level=Service Pack 2
>> user.country=NL
>> user.dir=C:\eclipse
>> user.home=C:\Documents and Settings\rladan
>> user.language=nl
>> user.name=rladan
>> user.timezone=Europe/Berlin
>> user.variant=
>> *** Features:
>> CVS Client"
>> org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
>> Generator"
>> Generation"
>> Generation UI"
>> Generator UI"
>> org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
>> Support"
>> (EMF) Programmers Guide"
>> org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore"
>> org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"
>> org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
>> org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit"
>> org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
>> org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
>> Framework (EMF) - org.eclipse.emf.mapping.ecore"
>> org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
>> Constraint Language (OCL) 2.0 Compatibility API"
>> Model Query"
>> Model Query OCL Integration"
>> Framework (EMF) Source"
>> "EMF Model Transaction Core"
>> "EMF Validation Framework Core"
>> "EMF Model Transaction Workbench Integration Core"
>> org.eclipse.gef (3.3.2.v20080129) "Graphical Editing Framework"
>> "Eclipse Java Development Tools"
>> Constraint Language (OCL) 2.0 Parser/Interpreter"
>> Plug-in Development Environment"
>> "Eclipse Platform"
>> "Eclipse RCP"
>> org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
>> *** Plug-in Registry:
>> for Java (ICU4J)" [Active]
>> com.jcraft.jsch (0.1.31) "JSch" [Resolved]
>> javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
>> [Resolved]
>> LPG" [Resolved]
>> org.antlr.runtime (3.0.0.200802121151) "ANTLR Runtime" [Resolved]
>> org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
>> Expression Language Interpreter" [Resolved]
>> Logging Plug-in" [Resolved]
>> [Resolved]
>> org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
>> Analysis" [Resolved]
>> org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
>> [Resolved]
>> org.atl.eclipse.adt.builder (2.0.0) "ATL Builder" [Starting]
>> org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
>> org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Starting]
>> org.eclipse.compare (3.3.2.r33x_20080128) "Compare Support" [Active]
>> org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
>> org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
>> Mechanism" [Active]
>> Binding" [Resolved]
>> Binding for JavaBeans" [Resolved]
>> Language" [Active]
>> [Active]
>> [Active]
>> System for Windows" [Resolved]
>> [Active]
>> Management" [Active]
>> Resource Management Compatibility Fragment" [Resolved]
>> Management Win32 Fragment" [Resolved]
>> org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
>> Runtime Plug-in Compatibility" [Active]
>> "Authorization Compatibility Plug-in" [Active]
>> "Eclipse Registry Compatibility Fragment" [Resolved]
>> org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
>> org.eclipse.cvs (1.0.2.r33x_r20080129) "Eclipse CVS Client" [Starting]
>> org.eclipse.debug.core (3.3.2.v20080117_r332) "Debug Core" [Active]
>> org.eclipse.debug.ui (3.3.2.v20080117_r332) "Debug UI" [Active]
>> Draw2d" [Starting]
>> (EMF)" [Starting]
>> org.eclipse.emf.ant (2.3.1.v200802051830) "EMF Ant Tasks" [Starting]
>> [Starting]
>> Generator" [Starting]
>> Generation" [Starting]
>> Generation UI" [Starting]
>> Generator UI" [Starting]
>> org.eclipse.emf.common (2.3.2.v200802051830) "EMF Common" [Starting]
>> [Starting]
>> Support" [Starting]
>> (EMF) Programmers Guide" [Starting]
>> org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore" [Starting]
>> Model" [Starting]
>> Change Edit Support" [Starting]
>> Support" [Starting]
>> Editor" [Starting]
>> org.eclipse.emf.ecore.xmi (2.3.2.v200802051830) "EMF XMI" [Starting]
>> org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit" [Starting]
>> org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Starting]
>> Support" [Starting]
>> Support" [Starting]
>> Importer" [Starting]
>> Java Importer" [Starting]
>> org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting]
>> Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
>> [Starting]
>> Ecore Mapping" [Starting]
>> "Ecore to Ecore Mapping Editor" [Starting]
>> Mapping" [Starting]
>> XML Mapping UI" [Starting]
>> [Starting]
>> (OCL) 2.0 Compatibility API" [Starting]
>> org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query" [Starting]
>> Integration" [Starting]
>> Framework (EMF) Source" [Resolved]
>> Transaction Core" [Starting]
>> Transaction UI" [Starting]
>> Framework Core" [Starting]
>> Framework UI" [Starting]
>> Validation Framework UI IDE" [Starting]
>> Workbench Integration Core" [Starting]
>> Transaction Workbench Integration UI" [Starting]
>> Container" [Active]
>> [Active]
>> Service" [Starting]
>> Registry Extensions" [Resolved]
>> Servlet" [Starting]
>> Support Bundle" [Starting]
>> Registry Support Plug-in" [Starting]
>> [Resolved]
>> "Equinox Launcher Win32 X86 Fragment" [Resolved]
>> Preferences Mechanism" [Active]
>> Registry Support" [Active]
>> [Starting]
>> org.eclipse.help (3.3.2.v20071126_33x) "Help System Core" [Active]
>> Server" [Starting]
>> org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]
>> org.eclipse.help.ui (3.3.2.v20071126_33x) "Help System UI" [Starting]
>> [Starting]
>> Tools" [Resolved]
>> Processing Core" [Active]
>> Compiler Apt IDE" [Active]
>> Processing UI" [Starting]
>> Compiler Apt" [Resolved]
>> Support" [Resolved]
>> [Active]
>> Manipulation Functionality" [Active]
>> [Starting]
>> Development User Guide" [Starting]
>> Tools JUnit support" [Starting]
>> Tools JUnit runtime support" [Resolved]
>> Development Tools JUnit4 runtime support" [Resolved]
>> Tools Launching Support" [Active]
>> [Active]
>> [Starting]
>> org.eclipse.jface (3.3.2.M20080207-0800) "JFace" [Active]
>> Binding for SWT and JFace" [Resolved]
>> org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text" [Resolved]
>> org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Starting]
>> org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
>> Core" [Active]
>> [Starting]
>> [Starting]
>> [Starting]
>> org.eclipse.m2m.atl.adt.editor (2.0.0.200802251526) "ATL Editor" [Active]
>> Perspective" [Starting]
>> org.eclipse.m2m.atl.adt.wizard (2.0.0.200802251526) "ATL Wizard" [Active]
>> Compiler 2006 Plug-in" [Starting]
>> Plug-in" [Resolved]
>> Plug-in" [Starting]
>> Plug-in" [Resolved]
>> Language (ATL)" [Starting]
>> Machine" [Starting]
>> [Active]
>> [Starting]
>> (OCL) 2.0 Parser/Interpreter" [Starting]
>> Ecore" [Starting]
>> org.eclipse.osgi (3.3.2.R33x_v20080105) "OSGi System Bundle" [Active]
>> Services" [Resolved]
>> Classes" [Resolved]
>> Environment" [Active]
>> Environment Build Support" [Starting]
>> [Active]
>> Development User Guide" [Resolved]
>> Plug-in Test" [Resolved]
>> Environment Runtime" [Starting]
>> [Starting]
>> [Starting]
>> org.eclipse.platform (3.3.3.r33x_r20080129) "Eclipse Platform" [Starting]
>> Workbench User Guide" [Starting]
>> org.eclipse.rcp (3.2.1.r33x_r20080131) "Eclipse RCP" [Starting]
>> [Starting]
>> org.eclipse.swt (3.3.2.v3349d) "Standard Widget Toolkit" [Resolved]
>> org.eclipse.team.core (3.3.1.r33x_20080128) "Team Support Core" [Active]
>> Core" [Starting]
>> org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
>> org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Starting]
>> [Starting]
>> org.eclipse.team.ui (3.3.2.r33x_20080128) "Team Support UI" [Active]
>> org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
>> org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
>> org.eclipse.ui (3.3.1.M20071128-0800) "Eclipse UI" [Active]
>> org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
>> [Starting]
>> org.eclipse.ui.console (3.2.2.v20071031_r332) "Console" [Active]
>> Editor" [Active]
>> [Active]
>> org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
>> org.eclipse.ui.ide (3.3.2.M20080207-0800) "Eclipse IDE UI" [Active]
>> Application" [Resolved]
>> [Starting]
>> Welcome" [Starting]
>> View" [Starting]
>> Workbench Components" [Starting]
>> UI" [Active]
>> Presentation Plug-in" [Starting]
>> org.eclipse.ui.views (3.2.101.M20080207-0800) "Views" [Active]
>> Properties View" [Starting]
>> Enhancements" [Resolved]
>> org.eclipse.ui.workbench (3.3.2.M20080207-0800) "Workbench" [Active]
>> "Workbench Compatibility" [Resolved]
>> Editor Framework" [Active]
>> org.eclipse.uml2 (2.1.0.v200706251652) "UML2" [Resolved]
>> Code Generation UI" [Starting]
>> org.eclipse.uml2.common (1.3.1.v200707311200) "UML2 Common" [Starting]
>> Support" [Starting]
>> org.eclipse.uml2.uml (2.1.1.v200707311200) "UML2 UML Model" [Starting]
>> Exporter for EMF" [Starting]
>> Importer for EMF" [Starting]
>> Support" [Starting]
>> [Starting]
>> Resources" [Resolved]
>> "Install/Update Configurator" [Active]
>> [Active]
>> Scheduler" [Starting]
>> org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Active]
>> Command Framework (headless)" [Starting]
>> Command Framework (core)" [Resolved]
>> services UI" [Starting]
>> Command Framework (GUI)" [Starting]
>> Plug-in" [Starting]
>> [Starting]
>> (1.1.105.v200802192030) "EMF Workbench Edit Plug-in" [Starting]
>> "Enviornment Plug-in" [Starting]
>> Frameworks" [Starting]
>> Plug-in" [Starting]
>> infopops" [Starting]
>> Plug-in" [Starting]
>> "Project Facet Core" [Starting]
>> Facet UI" [Starting]
>> View" [Starting]
>> extensions" [Starting]
>> Properties UI" [Starting]
>> Resolver Framework" [Starting]
>> DTD Core" [Starting]
>> [Starting]
>> infopops" [Resolved]
>> documentation" [Resolved]
>> Resolver Plug-in" [Starting]
>> Model" [Starting]
>> editor and snippets documentation" [Resolved]
>> Editor" [Starting]
>> [Resolved]
>> Schemas and DTDs" [Resolved]
>> validation infopop plug-in" [Resolved]
>> XML Model" [Starting]
>> org.eclipse.wst.xml.ui (1.0.302.v200802140626) "XML UI Plugin" [Starting]
>> [Resolved]
>> editor" [Resolved]
>> [Starting]
>> [Starting]
>> editor" [Resolved]
>> [Starting]
>> [Starting]
>> org.junit (3.8.2.v200706111738) "JUnit Testing Framework" [Resolved]
>> org.junit4 (4.3.1) "JUnit Testing Framework Version 4" [Resolved]
>> org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]
>> *** User Preferences:
>> #Tue Mar 04 10:18:00 CET 2008
>> /instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_annotati ons=true
>> /project/mt-test/org.eclipse.core.resources/encoding//model/ meta.ecore_diagram=UTF-8
>> @org.eclipse.ui.editors=3.3.2.r332_20080109-0800
>> /instance/org.topcased.web.server/urlValue0=127.0.0.1
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.invalidJavadocTags=enabled
>> @org.eclipse.debug.ui=3.3.2.v20080117_r332
>> @org.eclipse.core.net=1.0.1.r33x_20070709
>> /instance/org.eclipse.jdt.ui/cleanup_profile=_rene
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=/usr/local/eclipse-devel/plugins/org.ju nit_3.8.2.v200706111738
>> /instance/eclipseme.core/auto_launch_migration=false
>> /instance/org.atl.eclipse.adt.editor/Atl.Typing.CloseBraces= false
>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unnecessary_c asts=true
>> /instance/org.eclipse.gmf.ecore.editor/rulergrid.gridlevel=t rue
>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.cleanupprofi les= <?xml
>> version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<profiles
>> version\="2">\r\n<profile kind\="CleanUpProfile" name\="rene"
>> version\="2">\r\n<setting id\="cleanup.add_missing_nls_tags"
>> value\="false"/>\r\n<setting id\="cleanup.format_source_code"
>> value\="true"/>\r\n<setting
>> id\="cleanup.add_missing_override_annotations"
>> id\="cleanup.qualify_static_method_accesses_with_declaring_class "
>> value\="false"/>\r\n<setting id\="cleanup.remove_unused_private_types"
>> value\="true"/>\r\n<setting id\="cleanup.remove_unused_private_fields"
>> id\="cleanup.always_use_parentheses_in_expressions"
>> value\="false"/>\r\n<setting id\="cleanup.never_use_blocks"
>> value\="true"/>\r\n<setting id\="cleanup.make_local_variable_final"
>> id\="cleanup.add_missing_deprecated_annotations"
>> value\="true"/>\r\n<setting id\="cleanup.remove_unused_private_methods" v
>> alue\="true"/>\r\n<setting id\="cleanup.convert_to_enhanced_for_loop"
>> value\="true"/>\r\n<setting id\="cleanup.remove_unnecessary_nls_tags"
>> value\="true"/>\r\n<setting id\="cleanup.remove_unused_imports"
>> id\="cleanup.remove_trailing_whitespaces_ignore_empty"
>> value\="false"/>\r\n<setting id\="cleanup.sort_members"
>> value\="false"/>\r\n<setting id\="cleanup.make_private_fields_final"
>> id\="cleanup.add_generated_serial_version_id"
>> id\="cleanup.remove_unused_local_variables"
>> value\="true"/>\r\n<setting id\="cleanup.organize_imports"
>> value\="true"/>\r\n<setting id\="cleanup.sort_members_all"
>> value\="false"/>\r\n<setting id\="cleanup.remove_trailing_whitespaces"
>> id\="cleanup.never_use_parentheses_in_expressions"
>> id\="cleanup.remove_unused_private_members"
>> value\="true"/>\r\n<setting id\="cleanup.remove_unnecessary_casts"
>> ing id\="cleanup.make_parameters_final" value\="true"/>\r\n<setting
>> id\="cleanup.use_this_for_non_static_field_access"
>> id\="cleanup.use_blocks_only_for_return_and_throw"
>> value\="false"/>\r\n<setting id\="cleanup.remove_private_constructors"
>> value\="true"/>\r\n<setting id\="cleanup.use_blocks"
>> value\="true"/>\r\n<setting id\="cleanup.add_missing_annotations"
>> id\="cleanup.always_use_this_for_non_static_method_access"
>> id\="cleanup.use_parentheses_in_expressions"
>> id\="cleanup.remove_trailing_whitespaces_all"
>> id\="cleanup.always_use_this_for_non_static_field_access"
>> id\="cleanup.qualify_static_field_accesses_with_declaring_class "
>> id\=" cleanup.use_this_for_non_static_field_access_only_if_necessa ry "
>> id\="cleanup.add_default_serial_version_id" value\="true"/>\r\
>> n<setting
>> id\=" cleanup.use_this_for_non_static_method_access_only_if_necess ary "
>> id\="cleanup.use_this_for_non_static_method_access"
>> id\=" cleanup.qualify_static_member_accesses_through_instances_wit h_declaring_class "
>> value\="true"/>\r\n<setting id\="cleanup.add_serial_version_id"
>> id\=" cleanup.qualify_static_member_accesses_through_subtypes_with _declaring_class "
>> id\="cleanup.make_variable_declarations_final"
>> value\="true"/>\r\n<setting id\="cleanup.always_use_blocks"
>> id\="cleanup.qualify_static_member_accesses_with_declaring_class "
>> value\="true"/>\r\n</profile>\r\n</profiles>\r\n
>> /instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
>> /project/mt-test/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.source=1.6
>> /project/mt-test.editor/org.eclipse.gmf.bridge.ui.dashboard/ gmf_dashboard/domainGenerationModel=platform\:/resource/mt-t est/model/meta.genmodel
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unusedDeclaredThrownException=warning
>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
>> version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.6
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_CODEGEN_ECORE=C\:/eclipse-3/plugins/org.eclips e.emf.codegen.ecore_2.2.1.v200609210005.jar
>> /instance/org.eclipse.ui.editors/lineNumberRuler=true
>> /instance/org.eclipse.jdt.ui/cleanup.use_this_for_non_static _method_access=true
>> /instance/org.eclipse.jdt.ui/sp_cleanup.convert_to_enhanced_ for_loop=false
>> /instance/org.eclipse.ui.browser/internalWebBrowserHistory=f ile\:/C\:/DOCUME~1/rladan/LOCALS~1/Temp/eclipse/.update/1184 139572802/1184139573209/pde_schema_mt_test-diagram-custom-1_ preview.html|*|
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_CODEGEN=C\:/eclipse-3/plugins/org.eclipse.emf. codegen_2.2.1.v200609210005.jar
>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=true
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .debug.localVariable=generate
>> /instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=always
>> /configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
>> @org.eclipse.core.runtime=3.3.100.v20070530
>> /instance/fr.tm.elibel.smartqvt.qvteditor/ENABLE_AUTOPARSE=t rue
>> /instance/org.eclipse.pde.runtime/orderType=2
>> /instance/org.eclipse.jdt.ui/cleanup.use_blocks=true
>> /instance/org.eclipse.jdt.ui/cleanup.qualify_static_member_a ccesses_through_subtypes_with_declaring_class=true
>> /instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
>> New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
>> /instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.ExpressionView= <?xml
>> version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento
>> org.eclipse.debug.ui.SASH_DETAILS_PART\="315"
>> org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
>> /instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_perspective_to_show=always
>> /instance/org.eclipse.gmf.bridge.ui/ignore_mapmodel_validati on=true
>> /instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
>> /instance/org.eclipse.core.resources/version=1
>> /instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
>> @org.eclipse.ui=3.3.1.M20071128-0800
>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.exception.na me=e
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.unusedLocal=optimize
>> out
>> /instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_nls_tags =false
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJsrBytecode=enabled
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.missingJavadocCommentsOverriding=enabled
>> /instance/org.eclipse.jdt.ui/cleanup.qualify_static_method_a ccesses_with_declaring_class=false
>> /instance/org.eclipse.pde.runtime/orderValue=-1
>> /instance/fr.tm.elibel.smartqvt.qvtparser/PYTHON_EXE_PATH=C\ :\\Python25\\python.exe
>> /instance/org.atl.eclipse.adt.editor/Atl.Typing.ClolseBracke ts=false
>> /instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1203937481556
>> /instance/org.eclipse.update.scheduler/day=Every day
>> /instance/org.eclipse.jdt.ui/sp_cleanup.use_this_for_non_sta tic_method_access=false
>> /instance/org.eclipse.jdt.ui/sp_cleanup.add_serial_version_i d=false
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_ECORE=C\:/eclipse-3/plugins/org.eclipse.emf.ec ore_2.2.1.v200609210005.jar
>> /project/mt-test.edit/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.assertIdentifier=error
>> /instance/org.eclipse.ui.intro/org.eclipse.sdk.ide_INTRO_THE ME=org.eclipse.ui.intro.universal.circles
>> /instance/org.eclipse.jdt.ui/cleanup.make_variable_declarati ons_final=true
>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_privat e_types=true
>> /instance/org.eclipse.jdt.ui/cleanup.sort_members=false
>> /project/mt-test.edit/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.enumIdentifier=error
>> /instance/org.eclipse.jdt.ui/cleanup.remove_trailing_whitesp aces_ignore_empty=false
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.missingJavadocTags=warning
>> /instance/org.eclipse.jdt.ui/sp_cleanup.make_local_variable_ final=false
>> /instance/org.eclipse.jdt.ui/cleanup.add_default_serial_vers ion_id=true
>> /instance/org.eclipse.jdt.ui/cleanup.add_missing_annotations =true
>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_trailing_whit espaces_ignore_empty=false
>> /instance/org.eclipse.jdt.ui/sp_cleanup.always_use_this_for_ non_static_field_access=false
>> /instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.deprecationInDeprecatedCode=enabled
>> /instance/org.eclipse.jdt.ui/sp_cleanup.organize_imports=tru e
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.invalidJavadoc=warning
>> /instance/org.eclipse.help.ui/browser.maximized=false
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.syntheticAccessEmulation=warning
>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.gettersetter .use.is=true
>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unused_import s=false
>> /instance/org.eclipse.update.scheduler/enabled=true
>> /instance/org.eclipse.gmf.bridge.ui/show_dashboard=true
>> /instance/org.eclipse.jdt.ui/MemberFilterActionGroup.org.ecl ipse.jdt.ui.JavaOutlinePage.4=true
>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ANTLR_HOME=C\:/eclipse/plugins/org.antlr_2.7.6
>> @org.eclipse.jdt.debug.ui=3.2.102.v20071002_r332
>> /instance/org.eclipse.update.core/org.eclipse.update.core.au tomaticallyChooseMirror=true
>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_trailing_whit espaces_all=true
>> /project/mt-test.editor/org.eclipse.jdt.core/org.eclipse.jdt .core.compiler.codegen.targetPlatform=1.6
>> /instance/org.eclipse.ui.intro.universal/org.eclipse.sdk.ide _INTRO_DATA= <?xml
>> version\="1.0" encoding\="utf-8" ?>\r\n<extensions>\r\n <page
>> id\="tutorials">\r\n <group path\="page-content/bottom-left"
>> default\="true">\r\n </group>\r\n <group
>> path\="page-content/bottom-right" default\="true">\r\n
>> </group>\r\n <group path\="page-content/top-left">\r\n
>> <extension id\="org.eclipse.jdt" importance\="low"/>\r\n
>> <extension id\="org.eclipse.team" importance\="low"/>\r\n
>> </group>\r\n <group path\="page-content/top-right">\r\n
>> <extension id\="org.eclipse.pde" importance\="low"/>\r\n
>> </group>\r\n </page>\r\n <page id\="samples">\r\n <group
>> path\="page-content/bottom-left" default\="true">\r\n
>> </group>\r\n <group path\="page-content/botto
Re: [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFMod [message #325962 is a reply to message #325961] |
Tue, 04 March 2008 07:11   |
--------------090006070203080102080802
Rene,
I can't imagine the assignment statement itself would hang, so either=20
initialing the AtlModelHandler's AMH_EMF field is handling or the call=20
to getDefault, but both those things would create additional stack=20
frames. I notice looking more closely that the stack frame says the=20
process is stopped at a breakpoint. If you actually let it run and then =
pause the process, what's the stack frame that actually hangs? The=20
information here might be useful:
http://wiki.eclipse.org/How_to_report_a_deadlock
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> To me it looks likely that it's simply blocked on an input or output=20
>> to the stream, though how that's possible for a ByteArray version, I=20
>> don't know.
>> What's the code doing at line 86 of Transform.doATLTransformation?
> Line 86 is :
> this.amh =3D AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF); //=20
> FIXME hangs
>>> Does anyone have a solution for the random hangs described in the=20
>>> attached message?
>>> Thanks,
>>> Rene
>>> awt.toolkit=3Dsun.awt.windows.WToolkit
>>> eclipse.buildId=3DM20071023-1652
>>> eclipse.commands=3D-os
>>> win32
>>> -ws
>>> win32
>>> -arch
>>> x86
>>> -showsplash
>>> C:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.=
bmp=20
>>> -launcher
>>> -name
>>> Eclipse
>>> --launcher.library
>>> C:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3=
=2ER33x_v20080118\eclipse_1023.dll=20
>>> -startup
>>> C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.=
jar=20
>>> -vm
>>> eclipse.ee.install.verify=3Dfalse
>>> eclipse.product=3Dorg.eclipse.platform.ide
>>> eclipse.startTime=3D1204618361408
>>> eclipse.vm=3DC:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
>>> eclipse.vmargs=3D-Dosgi.requiredJavaVersion=3D1.5
>>> -Xms40m
>>> -Xmx256m
>>> -XX:MaxPermSize=3D256M
>>> -Djava.class.path=3DC:\eclipse\plugins\org.eclipse.equinox.l auncher_1=
=2E0.1.R33x_v20080118.jar=20
>>> eof=3Deof
>>> file.encoding=3DCp1252
>>> file.encoding.pkg=3Dsun.io
>>> file.separator=3D\
>>> java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
>>> java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
>>> java.class.path=3DC:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0=
=2E1.R33x_v20080118.jar=20
>>> java.class.version=3D50.0
>>> java.endorsed.dirs=3DC:\Program Files\Java\jre1.6.0_03\lib\endorsed
>>> java.ext.dirs=3DC:\Program=20
>>> java.home=3DC:\Program Files\Java\jre1.6.0_03
>>> java.io.tmpdir=3DC:\DOCUME~1\rladan\LOCALS~1\Temp\
>>> java.library.path=3DC:\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\ WINDOWS\s=
ystem32;C:\WINDOWS;C:\Program=20
>>> Files\Java\jre1.6.0_03\bin\client;C:\Program=20
>>> Files\Java\jre1.6.0_03\bin;c:\ruby\bin;C:\PROGRA~1\RATIONAL\ RATION~1\=
NUTCROOT\bin;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT\bin\x11; C:\PROGRA~1\R=
ATIONAL\RATION~1\NUTCROOT\mksnt;C:\Perl\bin\;C:\texmf\miktex \bin;C:\WINDO=
WS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program=2 0
>>> Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common=20
>>> Files\GTK\2.0\bin;C:\Program Files\Common=20
>>> Files\Compuware\NMShared;C:\Program Files\MySQL\MySQL Server=20
>>> 5.0\bin;c:\perl\bin;C:\Program Files\Rational\ClearQuest;C:\Program=20
>>> Files\Unisys\Unisys Rose XML Tools\MOF;C:\Program=20
>>> Files\QuickTime\QTSystem\;C:\Program Files\Unisys\Unisys Rose XML=20
>>> Tools\UML;C:\Program Files\Rational\common;C:\Program Files\Common=20
>>> Files\Compuware\;C:\Program Files\Rational\Rose\TopLink\;C:\Program=20
>>> Files\Rational\Rational Test;C:\PROGRA~1\ATT\Graphviz\bin;C:\Program =
>>> Files\doxygen\bin
>>> ;C:\Program Files\GNU\GnuPG\pub;c:\Program Files\Microsoft SQL=20
>>> Server\90\Tools\binn\;C:\Program Files\SSH Communications=20
>>> Security\SSH Secure Shell;C:\Program Files\LQN Solvers;C:\Program=20
>>> Files\Nmap
>>> java.runtime.name=3DJava(TM) SE Runtime Environment
>>> java.runtime.version=3D1.6.0_03-b05
>>> java.specification.name=3DJava Platform API Specification
>>> java.specification.vendor=3DSun Microsystems Inc.
>>> java.specification.version=3D1.6
>>> java.vendor=3DSun Microsystems Inc.
>>> java.vendor.url=3Dhttp://java.sun.com/
>>> java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
>>> java.version=3D1.6.0_03
>>> java.vm.info=3Dmixed mode
>>> java.vm.name=3DJava HotSpot(TM) Client VM
>>> java.vm.specification.name=3DJava Virtual Machine Specification
>>> java.vm.specification.vendor=3DSun Microsystems Inc.
>>> java.vm.specification.version=3D1.0
>>> java.vm.vendor=3DSun Microsystems Inc.
>>> java.vm.version=3D1.6.0_03-b05
>>> line.separator=3D
>>> org.eclipse.equinox.launcher.splash.location=3DC:\eclipse\\p lugins\or=
g.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp=20
>>> org.eclipse.update.resolution_url=3D
>>> org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minim=
um-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1. 6=20
>>> org.osgi.framework.language=3Dnl
>>> org.osgi.framework.os.name=3DWindowsXP
>>> org.osgi.framework.os.version=3D5.1
>>> org.osgi.framework.processor=3Dx86
>>> org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activa=
tion,javax.activity,javax.annotation,javax.annotation.proces sing,javax.cr=
ypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio ,javax.imagei=
o.event,javax.imageio.metadata,javax.imageio.plugins.bmp,jav ax.imageio.pl=
ugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws, javax.jws.soa=
p,javax.lang.model,javax.lang.model.element,javax.lang.model .type,javax.l=
ang.model.util,javax.management,javax.management.loading,jav ax.management=
=2Emodelmbean,javax.management.monitor,javax.management.open mbean,javax.m=
anagement.relation,javax.management..remote,javax.management .remote.rmi,j=
avax.management.timer,javax.naming,javax.naming.directory,ja vax.naming.ev=
ent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.s sl,javax.prin=
t,javax.print.attribute,javax.print.attribute..standard,java x.print.event=
,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax. security.auth=
,javax.security.auth.callback,javax.security.a=20
> uth.
>>> kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.secu=
rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,ja vax.transacti=
on,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.b ind.annotatio=
n,javax.xml.bind.annotation.adapters,javax.xml.bind.attachme nt,javax.xml.=
bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml. crypto.dom,ja=
vax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cryp to.dsig.keyin=
fo,javax.xml.crypto.dsig.spec,javax.xml.d=20
> ata
>>> t
>>> ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.st=
ream,javax.xml.stream.events,javax.xml.stream.util,javax.xml .transform,ja=
vax.xml.transform.dom,javax.xml.transform.sax,javax.xml.tran sform.stax,ja=
vax.xml.transform.stream,javax.xml.validation,javax.xml.ws,j avax.xml.ws.h=
andler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml .ws.soap,java=
x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_=
3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org .omg.CORBA.OR=
BPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackag e,org.omg.Cos=
Naming,org.omg.CosNaming.NamingContextExtPackage,org.omg.Cos Naming.Naming=
ContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.Dy namicAny.DynA=
nyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IO P,org.omg.IOP=
=2ECodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Mess aging,org.omg=
=2EPortableInterceptor,org.omg.PortableInterceptor.ORBInitIn foPackage,org=
=2Eomg.PortableServer,org.omg.PortableServer.Cu=20
> rre
>>> n
>>> tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableSer=
ver.POAPackage,org.omg.PortableServer.portable,org.omg.Porta bleServer.Ser=
vantLocatorPackage,org.omg.SendingContext,org.omg.stub.java. rmi,org.w3c.d=
om,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events, org.w3c.dom.h=
tml,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheet s,org.w3c.dom=
=2Etraversal,org.w3c.dom.views=20
>>> org.osgi.framework.vendor=3DEclipse
>>> org.osgi.framework.version=3D1.4.0
>>> org.osgi.supports.framework.extension=3Dtrue
>>> org.osgi.supports.framework.fragment=3Dtrue
>>> org.osgi.supports.framework.requirebundle=3Dtrue
>>> os.arch=3Dx86
>>> os.name=3DWindows XP
>>> os.version=3D5.1
>>> osgi.arch=3Dx86
>>> osgi.bundles=3Dorg.eclipse.equinox.common@2:start,=20
>>> org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@sta=
rt
>>> osgi.bundlestore=3DC:\eclipse\configuration\org.eclipse.osgi \bundles
>>> osgi.compatibility.bootdelegation=3Dtrue
>>> osgi.configuration.area=3Dfile:/C:/eclipse/configuration/
>>> osgi.framework=3Dfile:/c:/eclipse/plugins/org.eclipse.osgi_3 .3.2.R33x=
_v20080105.jar=20
>>> osgi.framework.beginningstartlevel=3D1
>>> osgi.framework.shape=3Djar
>>> osgi.framework.version=3D3.3.2.R33x_v20080105
>>> osgi.install.area=3Dfile:/C:/eclipse/
>>> osgi.instance.area=3Dfile:/C:/Documents and Settings/rladan/workspace=
>>> osgi.instance.area.default=3Dfile:/C:/Documents and=20
>>> osgi.logfile=3DC:\Documents and Settings\rladan\workspace\.metadata\.=
log
>>> osgi.manifest.cache=3DC:\eclipse\configuration\org.eclipse.o sgi\manif=
ests
>>> osgi.nl=3Dnl_NL
>>> osgi.os=3Dwin32
>>> osgi.splashLocation=3DC:\eclipse\\plugins\org.eclipse.platfo rm_3.3.3.=
>>> osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
>>> osgi.syspath=3Dc:\eclipse\plugins
>>> osgi.ws=3Dwin32
>>> path.separator=3D;
>>> sun.arch.data.model=3D32
>>> sun.boot.class.path=3DC:\Program=20
>>> Files\Java\jre1.6.0_03\lib\resources.jar;C:\Program=20
>>> Files\Java\jre1.6.0_03\lib\rt.jar;C:\Program=20
>>> Files\Java\jre1.6.0_03\lib\sunrsasign.jar;C:\Program=20
>>> Files\Java\jre1.6.0_03\lib\jsse.jar;C:\Program=20
>>> Files\Java\jre1.6.0_03\lib\jce.jar;C:\Program=20
>>> Files\Java\jre1.6.0_03\lib\charsets.jar;C:\Program=20
>>> sun.boot.library.path=3DC:\Program Files\Java\jre1.6.0_03\bin
>>> sun.cpu.endian=3Dlittle
>>> sun.cpu.isalist=3D
>>> sun.desktop=3Dwindows
>>> sun.io.unicode.encoding=3DUnicodeLittle
>>> sun.jnu.encoding=3DCp1252
>>> sun.management.compiler=3DHotSpot Client Compiler
>>> sun.net.client.defaultConnectTimeout=3D60000
>>> sun.net.client.defaultReadTimeout=3D60000
>>> sun.os.patch.level=3DService Pack 2
>>> user.country=3DNL
>>> user.dir=3DC:\eclipse
>>> user.home=3DC:\Documents and Settings\rladan
>>> user.language=3Dnl
>>> user.name=3Drladan
>>> user.timezone=3DEurope/Berlin
>>> user.variant=3D
>>> *** Features:
>>> org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_)=20
>>> org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework=20
>>> (EMF)"
>>> org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code=20
>>> Generator"
>>> org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code=20
>>> Generation"
>>> org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore=20
>>> Code Generation UI"
>>> org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code=20
>>> Generator UI"
>>> org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"
>>> org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert=20
>>> Support"
>>> org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling=20
>>> Framework (EMF) Programmers Guide"
>>> org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit=20
>>> Support"
>>> org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore=20
>>> Editor"
>>> org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse=20
>>> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore"
>>> org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse=20
>>> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
>>> org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object=20
>>> org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF=20
>>> Model Query"
>>> org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823)=20
>>> "EMF Model Query OCL Integration"
>>> org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling=20
>>> org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88) =
>>> org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_)=20
>>> org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88)=20
>>> org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7)=20
>>> org.eclipse.ocl (1.1.2.v200711262212-3219oA55P6H8I9HDE) "Object=20
>>> org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse =
>>> org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft)=20
>>> "Eclipse Platform"
>>> org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc)=20
>>> "Eclipse RCP"
>>> org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)=
>>> org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework=
>>> com.ibm.icu (3.6.1.v20070906) "International Components for Unicode=20
>>> javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API=20
>>> Bundle" [Resolved]
>>> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738)=20
>>> "SourceForge LPG" [Resolved]
>>> org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0=20
>>> org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons=20
>>> org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"=20
>>> [Resolved]
>>> org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene=20
>>> org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"=20
>>> [Resolved]
>>> org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core"=20
>>> [Starting]
>>> org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved=
>>> org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content=20
>>> Mechanism" [Active]
>>> org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data=20
>>> Binding" [Resolved]
>>> org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace=20
>>> Data Binding for JavaBeans" [Resolved]
>>> org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression=20
>>> Language" [Active]
>>> org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers"=20
>>> [Active]
>>> org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems"=20
>>> [Active]
>>> org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File=20
>>> org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs=20
>>> Mechanism" [Active]
>>> org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection=20
>>> org.eclipse.core.resources (3.3.1.R33x_v20080205) "Core Resource=20
>>> org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core=20
>>> org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource=20
>>> org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core=20
>>> org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)=20
>>> org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)=20
>>> org.eclipse.core.variables (3.2.0.v20070426) "Core Variables"=20
>>> [Starting]
>>> org.eclipse.cvs (1.0.2.r33x_r20080129) "Eclipse CVS Client" [Starting=
>>> org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework=20
>>> Draw2d" [Starting]
>>> org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework=20
>>> (EMF)" [Starting]
>>> org.eclipse.emf.cheatsheets (2.3.0.v200802051830) "EMF Cheat Sheets" =
>>> [Starting]
>>> org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore=20
>>> org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code=20
>>> org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"=20
>>> [Starting]
>>> org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert=20
>>> Support" [Starting]
>>> Framework (EMF) Programmers Guide" [Starting]
>>> org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change =
>>> Model" [Starting]
>>> org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore=20
>>> Support" [Starting]
>>> Editor" [Starting]
>>> org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Starting=
>>> org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export=20
>>> Support" [Starting]
>>> org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import
>>> Support" [Starting]
>>> org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore=20
>>> org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated=20
>>> org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose=20
>>> org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting=
>>> org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse=20
>>> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
>>> org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse=20
>>> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"=20
>>> [Starting]
>>> org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to=20
>>> org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830)=20
>>> org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to=20
>>> XML Mapping" [Starting]
>>> org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to =
>>> org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI"=20
>>> [Starting]
>>> org.eclipse.emf.ocl (1.1.1.v200709121956) "Object Constraint=20
>>> Language (OCL) 2.0 Compatibility API" [Starting]
>>> org.eclipse.emf.query (1.1.1.v200711281714) "EMF Model Query"=20
>>> [Starting]
>>> org.eclipse.emf.query.ocl (1.1.0.v200706071712) "EMF Model Query OCL =
>>> org.eclipse.emf.transaction (1.1.2.v200712061832) "EMF Model=20
>>> org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model=20
>>> org.eclipse.emf.validation (1.1.1.v200708161445) "EMF Validation=20
>>> org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation=20
>>> org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF=20
>>> org.eclipse.emf.workspace (1.1.2.v200712061832) "EMF Model=20
>>> Transaction Workbench Integration Core" [Starting]
>>> org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model=20
>>> org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application=20
>>> Container" [Active]
>>> org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse=20
>>> Runtime" [Active]
>>> org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http=20
>>> Service" [Starting]
>>> org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) "Http=20
>>> Service Registry Extensions" [Resolved]
>>> org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http=20
>>> Services Servlet" [Starting]
>>> org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp=20
>>> org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper=20
>>> Jsp Registry Support Plug-in" [Starting]
>>> org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) "Equinox=20
>>> Launcher" [Resolved]
>>> org.eclipse.equinox.launcher.win32.win32.x86 (1.0.3.R33x_v20080118)=20
>>> org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) "Eclipse=20
>>> org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension=20
>>> org.eclipse.gef (3.2.102.v20080116) "Graphical Editing Framework"=20
>>> [Starting]
>>> org.eclipse.help.appserver (3.1.200.v20070510) "Help Application=20
>>> Server" [Starting]
>>> org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base"=20
>>> [Starting]
>>> org.eclipse.help.ui (3.3.2.v20071126_33x) "Help System UI" [Starting]=
>>> org.eclipse.help.webapp (3.3.2.v20071102_33x) "Help System Webapp"=20
>>> [Starting]
>>> org.eclipse.jdt (3.3.1.r332_v20080131) "Eclipse Java Development=20
>>> Tools" [Resolved]
>>> org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) "Java=20
>>> Annotation Processing Core" [Active]
>>> org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) "Java =
>>> org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) "Java Annotation=20
>>> org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) "Java=20
>>> org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) "Java Compiler Tool =
>>> Support" [Resolved]
>>> org.eclipse.jdt.core (3.3.3.v_793_R33x) "Java Development Tools=20
>>> Core" [Active]
>>> org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code=20
>>> org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Activ=
e]
>>> org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) "JDI Debug UI"=20
>>> [Starting]
>>> org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) "Eclipse Java=20
>>> org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) "Java Development=20
>>> org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java=20
>>> Development Tools JUnit runtime support" [Resolved]
>>> org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java=20
>>> org.eclipse.jdt.launching (3.3.2.v20080115_r332) "Java Development=20
>>> org.eclipse.jdt.ui (3.3.2.r332_20080128) "Java Development Tools UI" =
>>> [Active]
>>> org.eclipse.jem.util (2.0.2.v200802192030) "Java EMF Model=20
>>> Utilities" [Starting]
>>> org.eclipse.jface.databinding (1.1.1.M20080207-0800) "JFace Data=20
>>> org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text"=20
>>> [Resolved]
>>> org.eclipse.ltk.core.refactoring (3.3.1.r332_20080128) "Refactoring=20
>>> Core" [Active]
>>> org.eclipse.ltk.ui.refactoring (3.3.1.r332_20080128) "Refactoring=20
>>> UI" [Starting]
>>> org.eclipse.m2m.atl.adt.builder (2.0.0.200802251526) "ATL Builder"=20
>>> [Starting]
>>> org.eclipse.m2m.atl.adt.debug (2.0.0.200802251526) "ATL Debugger"=20
>>> [Starting]
>>> org.eclipse.m2m.atl.adt.editor (2.0.0.200802251526) "ATL Editor"=20
>>> [Active]
>>> org.eclipse.m2m.atl.adt.perspective (2.0.0.200802251526) "ATL=20
>>> org.eclipse.m2m.atl.adt.wizard (2.0.0.200802251526) "ATL Wizard"=20
>>> [Active]
>>> org.eclipse.m2m.atl.compilers.atl2006 (2.0.0.200802251526) "ATL=20
>>> org.eclipse.m2m.atl.drivers.emf4atl (2.0.0.200802251526) "EMF4ATL=20
>>> Plug-in" [Resolved]
>>> org.eclipse.m2m.atl.drivers.mdr4atl (2.0.0.200802251526) "MDR4ATL=20
>>> Plug-in" [Starting]
>>> org.eclipse.m2m.atl.drivers.uml24atl (2.0.0.200802251526) "UML24ATL=20
>>> Plug-in" [Resolved]
>>> org.eclipse.m2m.atl.engine (2.0.0.200802251526) "ATLAS=20
>>> Transformation Language (ATL)" [Starting]
>>> org.eclipse.m2m.atl.engine.emfvm (2.0.0.200802251526) "ATL EMF=20
>>> Virtual Machine" [Starting]
>>> org.eclipse.m2m.atl.engine.vm (2.0.0.200802251526) "ATL VM Plug-in"=20
>>> [Active]
>>> org.eclipse.m2m.atl.ocl.core (2.0.0.200802251526) "Ocl Core Plug-in" =
>>> [Starting]
>>> org.eclipse.ocl (1.1.2.v200711262212) "Object Constraint Language=20
>>> org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for=20
>>> Ecore" [Starting]
>>> org.eclipse.osgi (3.3.2.R33x_v20080105) "OSGi System Bundle" [Active]=
>>> org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1=20
>>> org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1=20
>>> Utility Classes" [Resolved]
>>> org.eclipse.pde (3.3.1.r33x_r20080129) "Eclipse Plug-in Development=20
>>> org.eclipse.pde.build (3.3.2.v20071019) "Plug-in Development=20
>>> org.eclipse.pde.core (3.3.2.v20071121-0800) "Plug-in Development=20
>>> Core" [Active]
>>> org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in=20
>>> org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit=20
>>> org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development=20
>>> org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI"=20
>>> [Starting]
>>> org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"=20
>>> [Starting]
>>> org.eclipse.platform (3.3.3.r33x_r20080129) "Eclipse Platform"=20
>>> [Starting]
>>> org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse=20
>>> org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support"=20
>>> [Starting]
>>> org.eclipse.swt.win32.win32.x86 (3.3.3.v3349) "Standard Widget=20
>>> Toolkit for Windows" [Resolved]
>>> org.eclipse.team.core (3.3.1.r33x_20080128) "Team Support Core"=20
>>> [Active]
>>> org.eclipse.team.cvs.core (3.3.2.r33x_20080128) "CVS Team Provider=20
>>> Core" [Starting]
>>> org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting=
>>> org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI" =
>>> [Starting]
>>> org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support"=20
>>> [Starting]
>>> org.eclipse.ui.cheatsheets (3.3.1.v20080125_33x) "Cheat Sheets"=20
>>> [Starting]
>>> org.eclipse.ui.editors (3.3.2.r332_20080109-0800) "Default Text=20
>>> Editor" [Active]
>>> org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools"=20
>>> [Active]
>>> org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE=20
>>> UI Application" [Resolved]
>>> org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework"=20
>>> [Starting]
>>> org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal=20
>>> Welcome" [Starting]
>>> org.eclipse.ui.navigator (3.3.2.M20080207-0800) "Common Navigator=20
>>> View" [Starting]
>>> org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator =
>>> org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management =
>>> UI" [Active]
>>> org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21=20
>>> org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800)=20
>>> "Tabbed Properties View" [Starting]
>>> org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32=20
>>> org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010)=20
>>> org.eclipse.ui.workbench.texteditor (3.3.2.r332_20080109-0800) "Text =
>>> org.eclipse.uml2.codegen.ecore (1.3.0.v200708221323) "UML2 Ecore=20
>>> Code Generation" [Starting]
>>> org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore=20
>>> org.eclipse.uml2.common (1.3.1.v200707311200) "UML2 Common" [Starting=
>>> org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit =
>>> Support" [Starting]
>>> org.eclipse.uml2.uml (2.1.1.v200707311200) "UML2 UML Model" [Starting=
>>> org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML=20
>>> org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML=20
>>> org.eclipse.uml2.uml.edit (2.1.0.v200708301222) "UML2 UML Edit=20
>>> Support" [Starting]
>>> org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor"=20
>>> [Starting]
>>> org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML=20
>>> org.eclipse.update.configurator (3.2.101.R33x_v20070810)=20
>>> org.eclipse.update.core (3.2.101.R33x_v20070911) "Install/Update=20
>>> Core" [Active]
>>> org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update=20
>>> Core for Windows" [Resolved]
>>> org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates=20
>>> org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Active=
>>> org.eclipse.wst.command.env (1.0.205.v200710161954) "Environment=20
>>> org.eclipse.wst.command.env.core (1.0.203.v200707302047)=20
>>> "Environment Command Framework (core)" [Resolved]
>>> org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web=20
>>> org.eclipse.wst.command.env.ui (1.0.203.v200709052219) "Environment=20
>>> org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core =
>>> Plug-in" [Starting]
>>> org.eclipse.wst.common.emf (1.1.104.v200709131115) "EMF Utilities"=20
>>> [Starting]
>>> org.eclipse.wst.common.emfworkbench.integration=20
>>> org.eclipse.wst.common.environment (1.0.200.v200705302225)=20
>>> org.eclipse.wst.common.frameworks (1.1.103.v200802192030) "Common=20
>>> org.eclipse.wst.common.frameworks.ui (1.1.101.v200709122200) "WTP UI =
>>> Plug-in" [Starting]
>>> org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST=20
>>> org.eclipse.wst.common.modulecore (1.1.104.v200802192030)=20
>>> "Modulecore Plug-in" [Starting]
>>> org.eclipse.wst.common.project.facet.core (1.2.2.v200802200327)=20
>>> org.eclipse.wst.common.project.facet.ui (1.2.1.v200708232226)=20
>>> "Project Facet UI" [Starting]
>>> org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets=20
>>> View" [Starting]
>>> org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI=20
>>> org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common =
>>> org.eclipse.wst.common.uriresolver (1.1.203.v200802200327) "Common=20
>>> URI Resolver Framework" [Starting]
>>> org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source=20
>>> org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source=20
>>> Editor" [Starting]
>>> org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor=20
>>> org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD=20
>>> Editor documentation" [Resolved]
>>> org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI=20
>>> org.eclipse.wst.sse.core (1.1.203.v200802140626) "Structured Text=20
>>> Model" [Starting]
>>> org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured=20
>>> text editor and snippets documentation" [Resolved]
>>> org.eclipse.wst.sse.ui (1.0.305.v200802142230) "Structured Source=20
>>> Editor" [Starting]
>>> org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) "SSE=20
>>> org.eclipse.wst.standard.schemas (1.0.1.v200705302225) "Standard=20
>>> org.eclipse.wst.validation (1.1.102.v200709122200) "Validation=20
>>> org.eclipse.wst.validation.infopop (1.0.202.v200706110217) "WST=20
>>> org.eclipse.wst.validation.ui (1.1.102.v200706071630) "Validation=20
>>> org.eclipse.wst.xml.core (1.1.202.v200802140626) "Structured Source=20
>>> org.eclipse.wst.xml.ui (1.0.302.v200802140626) "XML UI Plugin"=20
>>> [Starting]
>>> org.eclipse.wst.xml.ui.infopop (1.0.2.v200706110217) "XML infopops"=20
>>> [Resolved]
>>> org.eclipse.wst.xmleditor.doc.user (1.0.300.v200705302225) "XML=20
>>> editor" [Resolved]
>>> org.eclipse.wst.xsd.core (1.1.202.v200710011705) "XSD Core Plugin"=20
>>> [Starting]
>>> org.eclipse.wst.xsd.ui (1.2.2.v200802141800) "XML Schema Editor"=20
>>> [Starting]
>>> org.eclipse.wst.xsdeditor.doc.user (1.0.300.v200705302225) "XML=20
>>> schema editor" [Resolved]
>>> org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model=20
>>> (XSD)" [Starting]
>>> org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit=20
>>> org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]=
>>> /instance/org.eclipse.jdt.ui/sp_cleanup.add_missing_annotati ons=3Dtru=
e
>>> /project/mt-test/org.eclipse.core.resources/encoding//model/ meta.ecor=
e_diagram=3DUTF-8=20
>>> @org.eclipse.ui.editors=3D3.3.2.r332_20080109-0800
>>> /instance/org.topcased.web.server/urlValue0=3D127.0.0.1
>>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.=
invalidJavadocTags=3Denabled=20
>>> @org.eclipse.debug.ui=3D3.3.2.v20080117_r332
>>> @org.eclipse.core.net=3D1.0.1.r33x_20070709
>>> /instance/org.eclipse.jdt.ui/cleanup_profile=3D_rene
>>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable=
=2EJUNIT_HOME=3D/usr/local/eclipse-devel/plugins/org.junit_3 .8.2.v2007061=
11738=20
>>> /instance/eclipseme.core/auto_launch_migration=3Dfalse
>>> /instance/org.atl.eclipse.adt.editor/Atl.Typing.CloseBraces= 3Dfalse
>>> /instance/org.eclipse.jdt.ui/sp_cleanup.remove_unnecessary_c asts=3Dtr=
ue
>>> /instance/org.eclipse.gmf.ecore.editor/rulergrid.gridlevel=3 Dtrue
>>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.cleanupprofi les=3D <?x=
ml=20
>>> version\=3D"1.0" encoding\=3D"UTF-8" standalone\=3D"no"?>\r\n<profile=
s=20
>>> version\=3D"2">\r\n<profile kind\=3D"CleanUpProfile" name\=3D"rene"=20
>>> version\=3D"2">\r\n<setting id\=3D"cleanup.add_missing_nls_tags"=20
>>> value\=3D"false"/>\r\n<setting id\=3D"cleanup.format_source_code"=20
>>> value\=3D"true"/>\r\n<setting=20
>>> id\=3D"cleanup.add_missing_override_annotations"=20
>>> id\=3D"cleanup.qualify_static_method_accesses_with_declaring_class "=20
>>> value\=3D"false"/>\r\n<setting=20
>>> id\=3D"cleanup.remove_unused_private_types"=20
>>> id\=3D"cleanup.remove_unused_private_fields"=20
>>> id\=3D"cleanup.always_use_parentheses_in_expressions"=20
>>> value\=3D"false"/>\r\n<setting id\=3D"cleanup.never_use_blocks"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.make_local_variable_fina=
l"=20
>>> id\=3D"cleanup.add_missing_deprecated_annotations"=20
>>> id\=3D"cleanup.remove_unused_private_methods" v
>>> id\=3D"cleanup.convert_to_enhanced_for_loop"=20
>>> id\=3D"cleanup.remove_unnecessary_nls_tags"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unused_imports"=20
>>> id\=3D"cleanup.remove_trailing_whitespaces_ignore_empty"=20
>>> value\=3D"false"/>\r\n<setting id\=3D"cleanup.sort_members"=20
>>> value\=3D"false"/>\r\n<setting id\=3D"cleanup.make_private_fields_fin=
al"=20
>>> id\=3D"cleanup.add_generated_serial_version_id"=20
>>> id\=3D"cleanup.remove_unused_local_variables"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.organize_imports"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.sort_members_all"=20
>>> id\=3D"cleanup.remove_trailing_whitespaces"=20
>>> id\=3D"cleanup.never_use_parentheses_in_expressions"=20
>>> id\=3D"cleanup.remove_unused_private_members"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.remove_unnecessary_casts=
"=20
>>> ing id\=3D"cleanup.make_parameters_final" value\=3D"true"/>\r\n<setti=
ng=20
>>> id\=3D"cleanup.use_this_for_non_static_field_access"=20
>>> id\=3D"cleanup.use_blocks_only_for_return_and_throw"=20
>>> id\=3D"cleanup.remove_private_constructors"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.use_blocks"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.add_missing_annotations"=
=20
>>> id\=3D"cleanup.always_use_this_for_non_static_method_access "=20
>>> id\=3D"cleanup.use_parentheses_in_expressions"=20
>>> id\=3D"cleanup.remove_trailing_whitespaces_all"=20
>>> id\=3D"cleanup.always_use_this_for_non_static_field_access"=20
>>> id\=3D"cleanup.qualify_static_field_accesses_with_declaring_class "=20
>>> id\=3D" cleanup.use_this_for_non_static_field_access_only_if_necessa ry=
"=20
>>> id\=3D"cleanup.add_default_serial_version_id" value\=3D"true"/>\r\
>>> n<setting=20
>>> id\=3D" cleanup.use_this_for_non_static_method_access_only_if_necess ar=
y"=20
>>> id\=3D"cleanup.use_this_for_non_static_method_access"=20
>>> id\=3D" cleanup.qualify_static_member_accesses_through_instances_wit h_=
declaring_class"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.add_serial_version_id"=20
>>> id\=3D" cleanup.qualify_static_member_accesses_through_subtypes_with _d=
eclaring_class"=20
>>> id\=3D"cleanup.make_variable_declarations_final"=20
>>> value\=3D"true"/>\r\n<setting id\=3D"cleanup.always_use_blocks"=20
>>> id\=3D"cleanup.qualify_static_member_accesses_with_declaring_class "=20
>>> value\=3D"true"/>\r\n</profile>\r\n</profiles>\r\n
>>> /instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.=
org.eclipse.jdt.debug.ui.show_null_entries=3Dtrue=20
>>> /project/mt-test/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.s=
ource=3D1.6=20
>>> /project/mt-test.editor/org.eclipse.gmf.bridge.ui.dashboard/ gmf_dashb=
oard/domainGenerationModel=3Dplatform\:/resource/mt-test/mod el/meta.genmo=
del=20
>>> /instance/org.eclipse.gmf.runtime.emf.core/referenced.path.v ariables=3D=
unusedDeclaredThrownException=3Dwarning=20
=3D<?xml=20
>>> version\=3D"1.0" encoding\=3D"UTF-8" standalone\=3D"no"?><templates/>=
>>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .complian=
ce=3D1.6=20
=2EEMF_CODEGEN_ECORE=3DC\:/eclipse-3/plugins/org.eclipse.emf .codegen.ecor=
e_2.2.1.v200609210005.jar=20
>>> /instance/org.eclipse.ui.editors/lineNumberRuler=3Dtrue
>>> /instance/org.eclipse.jdt.ui/cleanup.use_this_for_non_static _method_a=
ccess=3Dtrue=20
>>> /instance/org.eclipse.jdt.ui/sp_cleanup.convert_to_enhanced_ for_loop=3D=
false=20
>>> /instance/org.eclipse.ui.browser/internalWebBrowserHistory=3 Dfile\:/C=
\:/DOCUME~1/rladan/LOCALS~1/Temp/eclipse/.update/11841395728 02/1184139573=
209/pde_schema_mt_test-diagram-custom-1_preview.html|*|=20
=2EEMF_CODEGEN=3DC\:/eclipse-3/plugins/org.eclipse.emf.codeg en_2.2.1.v200=
609210005.jar=20
>>> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=3D=
true
>>> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .debug.lo=
calVariable=3Dgenerate=20
>>> /instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=3Dalways
>>> /configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=3Df=
alse
>>> @org.eclipse.core.runtime=3D3.3.100.v20070530
>>> /instance/fr.tm.elibel.smartqvt.qvteditor/ENABLE_AUTOPARSE=3 Dtrue
>>> /instance/org.eclipse.pde.runtime/orderType=3D2
>>> /instance/org.eclipse.jdt.ui/cleanup.use_blocks=3Dtrue
>>> /instance/org.e
Re: [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFMod [message #325969 is a reply to message #325962] |
Tue, 04 March 2008 09:03   |
--------------050508010200060107050202
Ed Merks wrote:
> Rene,
If I run the program in the Eclipse Debugger, suspend it when it hangs, and then use
StackTrace (see above link) to catch the frame the tool just responds with:
1640 javaw.exe ( Resource - models/crn.meta - Eclipse Platform ) session:0 threads:23 parent:1264
The system cannot find the file specified.
Cannot read the process output.
Try setting the TMP environment variable (prior to running the tool)
to a directory which can be used for working with temporary files
by both StackTrace and the target process.
However if I let the program running I get the attached stack trace.
> Rene Ladan wrote:
>> Ed Merks wrote:
>>> Rene,
>>> don't know.
>> Line 86 is :
>> this.amh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF); //
>> FIXME hangs
>> where this.amh is declared as:
>> AtlModelHandler amh;
>> Input is from a number of ByteArrayInputStreams,
>> output is to a number of ByteArrayOutputStreams.
>>> Rene Ladan wrote:
>>>> This seems Eclipse-specific, not really ATL-specific....
>>>> attached message?
>>>> Thanks,
>>>> Rene
>>>> Subject:
>>>> Re: [ATL] NPE at
>>>> org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:320)
>>>> From:
>>>> Rene Ladan <r.c.ladan@tue.nl>
>>>> Date:
>>>> Mon, 03 Mar 2008 16:19:19 +0100
>>>> Newsgroups:
>>>> eclipse.modeling.m2m
>>>> Rene Ladan wrote:
>>>>> Rene Ladan wrote:
>>>>>> After testing a version from August 2007, I updated to todays
>>>>>> HEAD. I cleaned
>>>>>> any remaining files/directories having 'm2m' in their name from my
>>>>>> Eclipse directory
>>>>>> and reinstalled. Now the issue seems to be solved, but the call
>>>>>> to getDefault() now
>>>>>> seems to hang on something :
>>>>>> FIXME hangs
>>>>> If I single-step debug this in the Eclipse debugger, the debugger
>>>>> hangs at a
>>>>> seemingly random point somewhere in this statement (i.e. two
>>>>> successive debugging
>>>>> sessions yield two different hanging points).
>>>>> Could this be an Eclipse / EMF problem? Updating to the latest EMF
>>>>> (2.3.2 20080228)
>>>>> doesn't help.
>>>> I've attached two stack traces (one from right before executing the
>>>> statement,
>>>> one where it seems to hang (F5-F7-F7 in the debugger).
>>>> Regards,
>>>> Rene
name="tool-before.txt"
Content-Disposition: inline;
filename="tool-before.txt"
3340 javaw.exe ( Resource - models/crn.meta - Eclipse Platform ) session:=
0 threads:18 parent:1264
2008-03-04 14:12:32
Full thread dump Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode):
"StackTrace Remote Thread" prio=3D6 tid=3D0x54a7a400 nid=3D0xc20 waiting =
on condition [0x00000000..0x5488fa7c]
java.lang.Thread.State: RUNNABLE
"Worker-4" prio=3D6 tid=3D0x549e6800 nid=3D0xc0c in Object.wait() [0x558e=
f000..0x558efa94]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
- waiting on <0x08961f18> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0x08961f18> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:21=
7)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
"Java indexing" daemon prio=3D4 tid=3D0x54a52400 nid=3D0xd74 in Object.wa=
it() [0x5587f000..0x5587fc94]
java.lang.Thread.State: WAITING (on object monitor)
- waiting on <0x08d98c80> (a org.eclipse.jdt.internal.core.search.indexi=
ng.IndexManager)
at java.lang.Object.wait(Object.java:485)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobMan=
ager.java:369)
- locked <0x08d98c80> (a org.eclipse.jdt.internal.core.search.indexing.I=
ndexManager)
at java.lang.Thread.run(Unknown Source)
"Worker-0" prio=3D6 tid=3D0x53fb6c00 nid=3D0x754 in Object.wait() [0x5479=
f000..0x5479fa14]
7)
"Start Level Event Dispatcher" daemon prio=3D6 tid=3D0x53ccb800 nid=3D0xf=
68 in Object.wait() [0x5419f000..0x5419fa94]
- waiting on <0x088df260> (a org.eclipse.osgi.framework.eventmgr.EventMa=
nager$EventThread)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextE=
vent(EventManager.java:355)
- locked <0x088df260> (a org.eclipse.osgi.framework.eventmgr.EventManage=
r$EventThread)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(Even=
tManager.java:293)
"Framework Event Dispatcher" daemon prio=3D6 tid=3D0x53d11c00 nid=3D0xa1c=
in Object.wait() [0x5414f000..0x5414fb14]
- waiting on <0x088df338> (a org.eclipse.osgi.framework.eventmgr.EventMa=
nager$EventThread)
- locked <0x088df338> (a org.eclipse.osgi.framework.eventmgr.EventManage=
r$EventThread)
tManager.java:293)
"State Data Manager" daemon prio=3D6 tid=3D0x53d0e400 nid=3D0xb40 waiting=
on condition [0x540ff000..0x540ffb94]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.j=
ava:297)
"Low Memory Detector" daemon prio=3D6 tid=3D0x536fc400 nid=3D0xf74 runnab=
le [0x00000000..0x00000000]
"CompilerThread0" daemon prio=3D10 tid=3D0x536f7800 nid=3D0xd48 waiting o=
n condition [0x00000000..0x5394f998]
"Attach Listener" daemon prio=3D10 tid=3D0x536f6400 nid=3D0x77c runnable =
"Signal Dispatcher" daemon prio=3D10 tid=3D0x536f5800 nid=3D0xc7c runnabl=
"Finalizer" daemon prio=3D8 tid=3D0x536e7800 nid=3D0x2c8 in Object.wait()=
[0x5385f000..0x5385fa94]
- waiting on <0x087d1c08> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x087d1c08> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=3D10 tid=3D0x536e3400 nid=3D0x7f8 in Obje=
ct.wait() [0x5380f000..0x5380fb14]
- waiting on <0x087d1c98> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x087d1c98> (a java.lang.ref.Reference$Lock)
"main" prio=3D6 tid=3D0x00397000 nid=3D0xecc runnable [0x003ff000..0x003f=
fe54]
at org.eclipse.swt.internal.win32.OS.WaitMessage(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:4070)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAd=
visor.java:362)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2390)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.ja=
va:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav=
a:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEAppli=
cation.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandl=
e.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runAppli=
cation(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ec=
lipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja=
va:363)
va:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
"VM Thread" prio=3D10 tid=3D0x536dec00 nid=3D0xe8 runnable=20
"VM Periodic Task Thread" prio=3D10 tid=3D0x536fdc00 nid=3D0xa2c waiting =
on condition=20
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
System Properties
osgi.bundles.defaultStartLevel=3D4
sun.java.launcher=3DSUN_STANDARD
sun.boot.class.path=3DC:\Program Files\Java\jre1.6.0_03\lib\resources.ja=
r;C:\Program Files\Java\jre1.6.0_03\lib\rt.jar;C:\Program Files\Java\jre1=
=2E6.0_03\lib\sunrsasign.jar;C:\Program Files\Java\jre1.6.0_03\lib\jsse.j=
ar;C:\Program Files\Java\jre1.6.0_03\lib\jce.jar;C:\Program Files\Java\jr=
e1.6.0_03\lib\charsets.jar;C:\Program Files\Java\jre1.6.0_03\classes
osgi.ws=3Dwin32
osgi.instance.area=3Dfile:/C:/Documents and Settings/rladan/workspace/ru=
ntime-workspace/
osgi.nl.user=3Dnl_NL
user.name=3Drladan
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activatio=
n,javax.activity,javax.annotation,javax.annotation.processin g,javax.crypt=
o,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,ja vax.imageio.e=
vent,javax.imageio.metadata,javax.imageio.plugins.bmp,javax. imageio.plugi=
ns.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,jav ax.jws.soap,j=
avax.lang.model,javax.lang.model.element,javax.lang.model.ty pe,javax.lang=
=2Emodel.util,javax.management,javax.management.loading,java x.management.=
modelmbean,javax.management.monitor,javax.management.openmbe an,javax.mana=
gement.relation,javax.management.remote,javax.management.rem ote.rmi,javax=
=2Emanagement.timer,javax.naming,javax.naming.directory,java x.naming.even=
t,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl ,javax.print,=
javax.print.attribute,javax.print.attribute.standard,javax.p rint.event,ja=
vax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.sec urity.auth,ja=
vax.security.auth.callback,javax.security.auth.kerberos,java x.security.au=
th.login,javax.security.auth.spi,javax.security.auth.x500,ja vax.security.=
cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.s pi,javax.soun=
d.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset ,javax.sql.ro=
wset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bor der,javax.swi=
ng.colorchooser,javax.swing.event,javax.swing.filechooser,ja vax.swing.pla=
f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,ja=
vax.swing.plaf.synth,javax.swing.table,javax.swing.text,java x.swing.text.=
html,javax.swing.text.html.parser,javax.swing.text.rtf,javax .swing.tree,j=
avax.swing.undo,javax.tools,javax.transaction,javax.transact ion.xa,javax.=
xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind. annotation.ad=
apters,javax.xml.bind.attachment,javax.xml.bind.helpers,java x.xml.bind.ut=
il,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.ds ig,javax.xml.=
crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cryp to.dsig.spec,=
javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,jav ax.xml.soap,j=
avax.xml.stream,javax.xml.stream.events,javax.xml.stream.uti l,javax.xml.t=
ransform,javax.xml.transform.dom,javax.xml.transform.sax,jav ax.xml.transf=
orm.stax,javax.xml.transform.stream,javax.xml.validation,jav ax.xml.ws,jav=
ax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.htt p,javax.xml.w=
s.soap,javax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.om g.CORBA,org.o=
mg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAny Package,org.o=
mg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.Typ eCodePackage,=
org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage, org.omg.CosNa=
ming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny ,org.omg.Dyna=
micAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage ,org.omg.IOP,=
org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org .omg.Messagin=
g,org.omg.PortableInterceptor,org.omg.PortableInterceptor.OR BInitInfoPack=
age,org.omg.PortableServer,org.omg.PortableServer.CurrentPac kage,org.omg.=
PortableServer.POAManagerPackage,org.omg.PortableServer.POAP ackage,org.om=
g.PortableServer.portable,org.omg.PortableServer.ServantLoca torPackage,or=
g.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w 3c.dom.bootst=
rap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org. w3c.dom.ls,or=
g.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.travers al,org.w3c.do=
m.views ,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
eclipse.pde.launch=3Dtrue
user.language=3Dnl
osgi.manifest.cache=3DC:\Documents and Settings\rladan\workspace\.metada=
ta\.plugins\org.eclipse.pde.core\mt2\org.eclipse.osgi\manife sts
eof=3Deof
osgi.bundles=3Dreference:file:C:/eclipse/plugins/org.eclipse .equinox.com=
mon_3.3.0.v20070426.jar@2:start,reference:file:C:/eclipse/plugins/org.ecl=
ipse.update.configurator_3.2.101.R33x_v20070810.jar@3:start,reference:fil=
e:C:/eclipse/plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar@start=
sun.cpu.isalist=3D
osgi.debug=3DC:\Documents and Settings\rladan\workspace\.metadata\.plugi=
ns\org.eclipse.pde.core\mt2/.options
file.separator=3D\
osgi.checkConfiguration=3Dtrue
user.country=3DNL
org.eclipse.equinox.launcher.splash.location=3DC:\eclipse\pl ugins\org.ec=
osgi.configuration.cascaded=3Dfalse
osgi.os=3Dwin32
eclipse.commands=3D-launcher
C:\eclipse\eclipse
-name
Eclipse
-showsplash
600
-product
-data
C:\Documents and Settings\rladan\workspace\runtime-workspace
-configuration
file:C:/Documents and Settings/rladan/workspace/.metadata/.plugins/org.ec=
lipse.pde.core/mt2/
-dev
lipse.pde.core/mt2/dev.properties
-debug
C:\Documents and Settings\rladan\workspace\.metadata\.plugins\org.eclipse=
=2Epde.core\mt2/.options
-os
win32
-ws
win32
-arch
x86
-nl
nl_NL
osgi.splashLocation=3DC:\eclipse\plugins\org.eclipse.platfor m_3.3.3.r33x=
os.version=3D5.1
osgi.arch=3Dx86
path.separator=3D;
user.variant=3D
osgi.instance.area.default=3Dfile:/C:/Documents and Settings/rladan/work=
space/
osgi.dev=3Dfile:C:/Documents and Settings/rladan/workspace/.metadata/.pl=
ugins/org.eclipse.pde.core/mt2/dev.properties
osgi.framework=3Dfile:/C:/eclipse/plugins/org.eclipse.osgi_3 .3.2.R33x_v2=
0080105.jar
osgi.bundlestore=3DC:\Documents and Settings\rladan\workspace\.metadata\=
=2Eplugins\org.eclipse.pde.core\mt2\org.eclipse.osgi\bundles
osgi.splashPath=3Dfile:C:/eclipse/plugins/org.eclipse.platfo rm_3.3.3.r33=
x_r20080129
osgi.nl=3Dnl_NL
java.library.path=3DC:\Program Files\Java\jre1.6.0_03\bin;.;C:\WINDOWS\S=
un\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\Java\jre1.6.0=
_03\bin\client;C:\Program Files\Java\jre1.6.0_03\bin;c:\ruby\bin;C:\PROGR=
A~1\RATIONAL\RATION~1\NUTCROOT\bin;C:\PROGRA~1\RATIONAL\RATI ON~1\NUTCROOT=
\bin\x11;C:\PROGRA~1\RATIONAL\RATION~1\NUTCROOT\mksnt;C:\Per l\bin\;C:\tex=
mf\miktex\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\Syst em32\Wbem;C:\=
Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common =
Files\GTK\2.0\bin;C:\Program Files\Common Files\Compuware\NMShared;C:\Pro=
gram Files\MySQL\MySQL Server 5.0\bin;c:\perl\bin;C:\Program Files\Ration=
al\ClearQuest;C:\Program Files\Unisys\Unisys Rose XML Tools\MOF;C:\Progra=
m Files\QuickTime\QTSystem\;C:\Program Files\Unisys\Unisys Rose XML Tools=
\UML;C:\Program Files\Rational\common;C:\Program Files\Common Files\Compu=
ware\;C:\Program Files\Rational\Rose\TopLink\;C:\Program Files\Rational\R=
ational Test;C:\PROGRA~1\ATT\Graphviz\bin;C:\Program Files\doxygen\bin;C:=
\Program Files\GNU\GnuPG\pub;c:\Program Files\Microsoft SQL Server\90\Too=
ls\binn\;C:\Program Files\SSH Communications Security\SSH Secure Shell;C:=
\Program Files\LQN Solvers;C:\Program Files\Nmap
eclipse.startTime=3D1204635305641
java.class.path=3DC:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.=
R33x_v20080118.jar
os.arch=3Dx86
java.ext.dirs=3DC:\Program Files\Java\jre1.6.0_03\lib\ext;C:\WINDOWS\Sun=
\Java\lib\ext
line.separator=3D
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-=
1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
osgi.logfile=3DC:\Documents and Settings\rladan\workspace\runtime-worksp=
ace\.metadata\.log
osgi.configuration.area=3Dfile:/C:/Documents and Settings/rladan/workspa=
ce/.metadata/.plugins/org.eclipse.pde.core/mt2/
Command line
"C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe" -Xmx1224M -Declipse.pde=
=2Elaunch=3Dtrue -classpath C:\eclipse\plugins\org.eclipse.equinox.launch=
er_1.0.1.R33x_v20080118.jar org.eclipse.equinox.launcher.Main -launcher C=
:\eclipse\eclipse -name Eclipse -showsplash 600 -product org.eclipse.plat=
form.ide -data "C:\Documents and Settings\rladan\workspace\runtime-worksp=
ace" -configuration "file:C:/Documents and Settings/rladan/workspace/.met=
adata/.plugins/org.eclipse.pde.core/mt2/" -dev "file:C:/Documents and Set=
tings/rladan/workspace/.metadata/.plugins/org.eclipse.pde.co re/mt2/dev.pr=
operties" -debug "C:\Documents and Settings\rladan\workspace\.metadata\.p=
lugins\org.eclipse.pde.core\mt2/.options" -os win32 -ws win32 -arch x86 -=
nl nl_NL
=3D=3D=3D=3D=3D=3D
Memory
=3D=3D=3D=3D=3D=3D
Used: 43229008 (~41MB)
Free: 35205296 (~34MB)
Total: 78434304 (~75MB)
Max: 1273626624 (~1215MB)
[###=3D=3D=3D............................................... .............=
=2E.................................]
Available Processors: 2
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D
// Error: Parser Error: Parse error at line 1, column 6. Encountered: ja=
vaw
Make a telnet connection to port 10000
Use quit(); to stop the BeanShell interpreter.
For help with BeanShell go to http://www.beanshell.org
--------------050508010200060107050202--
Re: [Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFMod [message #325970 is a reply to message #325969] |
Tue, 04 March 2008 09:28  |
Rene,
The stack trace you show doesn't indicate a hang to me. To me it looks
like the platform has only a single thread that's active and that thread
is waiting for a GUI event to prompt it into further action. If you
step over the method you say hangs, and then tell the debugger to pause
that thread after a while, you should see it stopped somewhere
meaningful to tell you what state that thread is in...
Rene Ladan wrote:
> Ed Merks wrote:
>> Rene,
>> call to getDefault, but both those things would create additional
>> stack frames. I notice looking more closely that the stack frame
>> says the process is stopped at a breakpoint. If you actually let it
>> run and then pause the process, what's the stack frame that actually
>> hangs? The information here might be useful:
> hangs, and then use
> with:
>> Rene Ladan wrote:
>>> Ed Merks wrote:
>>>> Rene,
>>>> output to the stream, though how that's possible for a ByteArray
>>>> version, I don't know.
>>> Line 86 is :
>>> FIXME hangs
>>>>> attached message?
>>>>> Thanks,
>>>>> Rene
>>>>> Subject:
>>>>> Re: [ATL] NPE at
>>>>> From:
>>>>> Date:
>>>>> Newsgroups:
>>>>> Rene Ladan wrote:
>>>>>>> HEAD. I cleaned
>>>>>>> my Eclipse directory
>>>>>>> to getDefault() now
>>>>>>> // FIXME hangs
>>>>>> hangs at a
>>>>>> EMF (2.3.2 20080228)
>>>>>> doesn't help.
>>>>> the statement,
>>>>> Regards,
>>>>> Rene
Current Time: Mon Jul 21 23:52:48 EDT 2025
Powered by FUDForum. Page generated in 0.45223 seconds
