Home » Eclipse Projects » Eclipse Platform » Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null?
Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null? [message #325914] Mon, 03 March 2008 03:01 Go to next message
How is it possible that HandlerUtil.getActiveWorkbenchWindow
occasionally returns null? (Or equivalently that
getActiveWorkbenchWindowChecked throws an Exception?)
We've observed that this happens sometimes, but it's unpredictable. Best
shot at reproducing it is repetitive wild clicking such that command
handlers calling these methods are invoked.
Thanks all,
Jasper.
Re: Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null? [message #325930 is a reply to message #325914] Mon, 03 March 2008 09:28 Go to previous messageGo to next message
HandlerUtil#getActiveWorkbenchWindow(*) will return null most
consistently when a dialog is up (the active Shell is a dialog).
What usecases are you seeing where that happens? Just opening or just
closing a dialog and then executing a command? Shell based popups (like
the F2 javadoc window)?
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null? [message #325950 is a reply to message #325930] Mon, 03 March 2008 22:54 Go to previous messageGo to next message
Paul,
We've seen this happen when executing handlers for commands associated
with toolbar items. The code is typically something like:
public Object execute(ExecutionEvent event) throws ExecutionException {
try {
// Spawn a dialog
IWorkbenchWindow window =
HandlerUtil.getActiveWorkbenchWindowChecked(event);
SomeDialog dialog = new SomeDialog(window.getShell());
dialog.open();
catch (Throwable t) {
Is it possible that a user invokes the handler once, closes the spawned
dialog, and then invokes the handler a second time fast enough that the
framework didn't yet get around to re-assigning the active workbench
window to ISources.ACTIVE_WORKBENCH_WINDOW_NAME ?
Jasper.
> Later,
> PW
Re: Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null? [message #325982 is a reply to message #325914] Tue, 04 March 2008 21:35 Go to previous messageGo to next message
In 3.3 I used this
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
Re: Why does HandlerUtil.getActiveWorkbenchWindow sometimes return null? [message #326082 is a reply to message #325950] Thu, 06 March 2008 19:33 Go to previous message
That's entirely possible. Some of the work is driven by OS events and
some by asyncExec(*) calls ... but OS events are usually processed
before asyncExec(*) runnables.
It would be good to narrow it down to a specific use case (dialog closes
and then another dialog or window takes focus before the command can
work a second time).
PW
Paul Webster
Previous Topic:Help needed writing a custom expression for visibleWhen of a command menuContribution
Next Topic:Customizing cheat sheets
Current Time: Tue Jul 22 13:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.15523 seconds
