Home » Eclipse Projects » Eclipse Platform » External JAR, NoClassDefFoundError
External JAR, NoClassDefFoundError [message #325850] Thu, 28 February 2008 17:13 Go to next message
Originally posted by: andy.auyeung.3ds.com
I have an external jar that I use in my Plug-in project. I added the jar
from "Config class path/Libraries/Add External JARs". The compile errors
went away after that.
However, when I test launch the Plug-in, I ran into an error. Those
classes in the external jar gave me NoClassDefFoundError.
Anyone knows the solution ?
Re: External JAR, NoClassDefFoundError [message #325860 is a reply to message #325850] Fri, 29 February 2008 06:26 Go to previous messageGo to next message
--------------020208080804000502030305
Andy,
This is a classic mistake when developing plugins (and something that
the tools should either prevent or warn you about). At runtime, the
information in the MANIFEST.MF is used to find jars. That's also what's
used a development time to indirectly determine the classpath of the
project. But if you directly modify the properties of the project to
configure the classpath, you'll find the same problem comes back at
runtime. So when developing plugins, *always *use the Dependencies
tab of the MANIFEST.MF editor to fix classpath problems. Use the popup
PDE Tools->Update classpath if the changes to the MANIFEST.MF don't seem
to kick in; if you do this before making any changes there, you should
see your compilation error come back and that will help you verify
you've fixed that properly via changes to the dependencies.
> jar from "Config class path/Libraries/Add External JARs". The compile
> errors went away after that.
<html>
<head>
http-equiv="Content-Type">
</head>
Andy,<br>
<br>
Re: External JAR, NoClassDefFoundError [message #325877 is a reply to message #325860] Fri, 29 February 2008 09:43 Go to previous messageGo to next message
I am at the Dependencies page, but still a bit unclear where to add my.jar
to the classpath. Is it "Imported Packages" ? I don't seem to find the
right place here. Please help.
Re: External JAR, NoClassDefFoundError [message #325878 is a reply to message #325877] Fri, 29 February 2008 09:53 Go to previous messageGo to next message
Andy,
I'd assumed the jar was another plugin. If it's a jar in your plugin,
you'd use the Runtime tab's Classpath section to add it to the plugin's
classpath.
> my.jar to the classpath. Is it "Imported Packages" ? I don't seem to
> find the right place here. Please help.
Re: External JAR, NoClassDefFoundError [message #325882 is a reply to message #325860] Fri, 29 February 2008 11:15 Go to previous message
Ed Merks wrote:
> Andy,
There is a Bugzilla about this somewhere, but I can't seem to find it now.
Previous Topic:How to contribute to Eclipse's Properties view?
Next Topic:Wizard Dialog as a View
Current Time: Tue Jul 22 09:04:06 EDT 2025
Powered by FUDForum. Page generated in 1.08452 seconds
