Home » Eclipse Projects » Eclipse Platform » extension points in org.eclipse.ltk.core.refactoring
extension points in org.eclipse.ltk.core.refactoring [message #325846] Thu, 28 February 2008 15:52 Go to next message
I need help understanding the refactoring API. I am concerned with
renaming, moving, deleting, and copying certain files in the navigator. I'm
not sure if I should be using the extension points in
org.eclipse.ltk.core.refactoring. When the user clicks one of our files in
the navigator, I want that file, and others, to have the operation performed
on them. Should I change the refactoring of rename, etc, or instead use
IResourceChangeListeners?
Is this type of refactoring documented or is the documentation in the code?
Re: extension points in org.eclipse.ltk.core.refactoring [message #325873 is a reply to message #325846] Fri, 29 February 2008 08:43 Go to previous messageGo to next message
You would use participants to update other files when you see
move/delete/rename. There is an article available at:
http://www.eclipse.org/articles/Article-LTK/ltk.html
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: extension points in org.eclipse.ltk.core.refactoring [message #325875 is a reply to message #325873] Fri, 29 February 2008 09:35 Go to previous messageGo to next message
What is the extension point org.eclipse.ltk.core.refactoring used for then?
I don't see that in the article.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:fq91vp$58e$1@build.eclipse.org...
> Later,
> PW
> Paul Webster
Re: extension points in org.eclipse.ltk.core.refactoring [message #325926 is a reply to message #325875] Mon, 03 March 2008 09:00 Go to previous message
It is mentioned (just in passing :-) in the "Refactoring Participants
(as of Eclipse 3.2M2)" box. Those extensions are how a plugin would
contribute new refactorings (and participants to existing refactorings).
There should be some information in the extension point description.
And as they mention, if you import the PDE plugins as source you should
see examples of the participants being used (so when a Java class is
renamed, the plugin.xml files can be updated to the new class name, etc).
i.e. so if you wanted to add a new MoveMyModel refactoring, you would
use org.eclipse.ltk.core.refactoring.refactoringContributions and if you
wanted to update some of your files on a Java Move refactoring you would
use org.eclipse.ltk.core.refactoring.moveParticipants.
As of 3.4 the navigator move, delete, and rename menu actions default to
using LTK refactorings. That means that adding a participant would
allow you to participate in those operations.
Later,
PW
Paul Webster
Previous Topic:Eclipse NLS class in non-osgi environment
Next Topic:Disposing listeners added to Selection service
Current Time: Mon Jul 21 21:38:42 EDT 2025
Powered by FUDForum. Page generated in 0.24756 seconds
