Home » Eclipse Projects » Eclipse Platform » help not working?
help not working? [message #325826] Thu, 28 February 2008 05:30 Go to next message
I was trying to look up some info in eclipse's help system but for some
strange reason, when I click Help => Help Contents then simply nothing
happens. Same for Help => Search.
The system log only shows a
"org.eclipse.core.runtime.CoreException: Unable to retrieve system
properties" (which it does since ages i.e. that's an exception I keep
getting since at least eclipse 3.0 if not longer)
and a
" org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException "
in some Mylyn bundle - again something that I have seen already since
longer - so I doubt that this is the reason.
Any idea, what could cause this?
I'm using eclipse 3.3.1.1 on Win XP.
Michael
Re: help not working? [message #325828 is a reply to message #325826] Thu, 28 February 2008 05:55 Go to previous messageGo to next message
Michael,
Maybe there is a system property that specifies which browser to use and
that's not being found. Maybe you could start up a runtime workspace
and set a breakpoint in the code that's throwing this exception to learn
more... I wonder if a fresh install of Eclipse with nothing else
installed even has this problem?
> some strange reason, when I click Help => Help Contents then simply
> nothing happens. Same for Help => Search.
> and a
> Michael
Re: help not working? [message #325879 is a reply to message #325828] Fri, 29 February 2008 10:23 Go to previous messageGo to next message
http://download.eclipse.org/webtools/downloads/
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fq63vi$8gg$2@build.eclipse.org...
> Michael,
> and that's not being found. Maybe you could start up a runtime
> workspace and set a breakpoint in the code that's throwing this
> exception to learn more... I wonder if a fresh install of Eclipse
> with nothing else installed even has this problem?
I changed Pref's => Help to use the internal browser, but no change.
I then installed an eclipse 3.3.1.1 "proper", i.e. without a single
add-on and fair enough here the help comes up. But of course that help
doesn't contain the info I am seeking... :-(
Is there a way to control the port on which the built-in tomcat listens?
I would like to see if the problem is in the help server or in starting
the browser and/or passing the URL (which one could - I guess -
differentiate by directing a browser "manually" to the help port).
Michael
Re: help not working? [message #325881 is a reply to message #325879] Fri, 29 February 2008 10:54 Go to previous messageGo to next message
Michael,
I don't know much about it. Maybe someone else knows... Are there any
logged problems in the installation that's failing?
>> Michael,
> listens? I would like to see if the problem is in the help server or
> in starting the browser and/or passing the URL (which one could - I
> guess - differentiate by directing a browser "manually" to the help
> port).
> Michael
Re: help not working? [message #325884 is a reply to message #325881] Fri, 29 February 2008 11:19 Go to previous message
Hi Ed,
Ed Merks wrote:
> Michael,
> any logged problems in the installation that's failing?
Only the two exceptions I described in the initial append.
Michael
Previous Topic:Wizard Dialog as a View
Next Topic:PDE Build and Cruise Control
Current Time: Sun Oct 26 21:06:18 EDT 2025
Powered by FUDForum. Page generated in 0.05495 seconds
