Reg: Unable to view Dataset- Urgent Help Required [message #1692095] |
Mon, 13 April 2015 12:12 |
kshirod mishra Messages: 50 Registered: March 2015 |
Member |
Hi Jeese,
I hava datatable. I am trying to prepair one line with 2 series of Y-Axis. In the first Y-series i filtered the data and same i used in X-Axis and Y -Axis. Once again I am selecting another Y series to show some graphs. Then i am trying to filter another item to show in 2nd Y-series but data is not showing in datapreview to use the data. I have limited numbers dataset: say 20 Columns.
How i have approached to this problem has been attached in the screenshot step-by-step. Please guide me.
and one more thing i am trying to put a filter in units in between "74" and "138" and then tried creating line chart, in chart i found one value "183" which is not in DataTable. Surprising me and whole Team. Detail screen shot attached for references.
Thanks & Regards
kshirod Mishra
[Updated on: Mon, 13 April 2015 12:53] Report message to a moderator
Re: Reg: Unable to view Dataset- Urgent Help Required [message #1694658 is a reply to message #1693348] |
Thu, 07 May 2015 01:30 |
You're not adding the filter to the individual series. For what you're wanting to do, you should filter the chart with "Item" in ["Binder", "Pencil"], then put "Reps" and "Units" how you have them in the chart builder. Finally, use your "Item" field as the optional y-series grouping. This should give you a chart with your two series you're wanting to compare.
Hope this helps. Sorry I'm not Jesse.
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.03070 seconds
