Home » Eclipse Projects » Eclipse Platform » Open IFile int the main window
Open IFile int the main window [message #325770] Tue, 26 February 2008 10:30 Go to next message
i have a tableviewer with some Ifiles as input. Now i wanted to open a
file by doubleclick this cell. How can i do this? i have allready the
listener and the IFile. I found code like this to open the editor:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(IFile);
but this method exist not in this way.
I think it is quite easy but i found nothing what really helped me.
Re: Open IFile int the main window [message #325772 is a reply to message #325770] Tue, 26 February 2008 10:39 Go to previous messageGo to next message
Jörg,
You'll need to create a FileEditorInput to what the IFile.
Jörg wrote:
> Hello,
Re: Open IFile int the main window [message #325775 is a reply to message #325772] Tue, 26 February 2008 10:59 Go to previous messageGo to next message
May be its a stupid question but i didn't found the editorID for the
normal default Editor in the main frame of eclipse. Can you say me this?
Ed Merks schrieb:
> Jörg,
> Jörg wrote:
>> Hello,
Re: Open IFile int the main window [message #325776 is a reply to message #325775] Tue, 26 February 2008 12:49 Go to previous messageGo to next message
--------------040109090603040407020009
J
Re: Open IFile int the main window [message #325795 is a reply to message #325776] Wed, 27 February 2008 07:59 Go to previous messageGo to next message
This helped allready a lot. How can i get the default editor based on
the IFile?
Ed Merks schrieb:
> Jörg,
> Normally you'd just let it open the default editor based on what's the
> default for the given IFile. Maybe you want this one.
> <extension
> point="org.eclipse.ui.editors">
> <editor
> name="%Editors.DefaultTextEditor"
> icon="$nl$/icons/full/obj16/file_obj.gif"
> class="org.eclipse.ui.editors.text.TextEditor"
> contributorClass="org.eclipse.ui.editors.text.TextEditorActionContributor "
> * id="org.eclipse.ui.DefaultTextEditor"*>
> <contentTypeBinding
> contentTypeId="org.eclipse.core.runtime.text"
> </editor>
> </extension>
>> Ed Merks schrieb:
>>> Jörg,
>>> Jörg wrote:
>>>> Hello,
>>>> a file by doubleclick this cell. How can i do this? i have allready
>>>> the listener and the IFile. I found code like this to open the editor:
Re: Open IFile int the main window [message #325796 is a reply to message #325795] Wed, 27 February 2008 08:28 Go to previous messageGo to next message
--------------090905040709080803010508
J
Re: Open IFile int the main window [message #325804 is a reply to message #325796] Wed, 27 February 2008 09:43 Go to previous message
No the showed does that not automatically, but the last codeline helped
a lot. Thanks
Ed Merks schrieb:
> Jörg,
> I think what you showed does that automatically. This type of approach
> is more explicit:
> PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or( "foo.txt");
>> the IFile?
>> Ed Merks schrieb:
>>> Jörg,
>>> the default for the given IFile. Maybe you want this one.
>>> <extension
>>> <editor
>>> <contentTypeBinding
>>> </editor>
>>> </extension>
>>>> this?
>>>> Ed Merks schrieb:
>>>>> Jörg,
>>>>> Jörg wrote:
>>>>>> Hello,
>>>>>> open a file by doubleclick this cell. How can i do this? i have
>>>>>> allready the listener and the IFile. I found code like this to
>>>>>> open the editor:
Previous Topic:Activator.getURLConverter crashes ImageRegistry
Next Topic:EclipseCon - BoF - UI Component Programming Best Practices (SWT, Nebula, JFace, Databinding ...)
Current Time: Thu Jul 17 23:48:35 EDT 2025
Powered by FUDForum. Page generated in 0.06660 seconds
