Home » Eclipse Projects » Eclipse Platform » custom content provider not automatically activated
custom content provider not automatically activated [message #325760] Tue, 26 February 2008 09:48 Go to next message
I've got a relatively simple custom content provider for a CommonNavigator
view. The provider itself seems to work quite fine, but I can't seem to
find out why it displays the content only after I've disabled and
re-enabled the content provider under the Customize View dialog. After the
re-enabling I see the two nodes, but not when initially showing the view.
Any ideas?
Andreas
The content provider code is as follows and its just bound to a plain
CommonNavigator view.
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IFolder;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.resources.IResourceChangeEvent;
import org.eclipse.core.resources.IResourceChangeListener;
import org.eclipse.core.resources.IResourceDelta;
import org.eclipse.core.resources.IResourceDeltaVisitor;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.StructuredViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.ui.progress.UIJob;
public class MyTreeContentProvider implements ITreeContentProvider,
IResourceChangeListener, IResourceDeltaVisitor
private String root;
private String[] childs = { "foo", "bar" };
private StructuredViewer viewer;
public MyTreeContentProvider()
System.err.println("content tree provider");
System.out.println( "Using squish content provider" );
ResourcesPlugin.getWorkspace().addResourceChangeListener( this,
IResourceChangeEvent.POST_CHANGE );
public Object[] getChildren( Object parentElement )
// TODO Auto-generated method stub
System.err.println( "TreeProvider.getChildren:" +
parentElement+"|"+parentElement.getClass() );
if ( parentElement instanceof String ) {
return new String[0];
} else {
return childs;
public Object getParent( Object element )
if( element.equals( childs[0] ) || element.equals( childs[1] ) )
return root;
System.err.println( "TreeProvider.getParent" + element
+"|"+element.getClass() );
return null;
public boolean hasChildren( Object element )
System.err.println( "TreeProvider.hasChildren:"+element+"|"+
return getChildren( element ).length > 0;
public Object[] getElements( Object inputElement )
System.err.println( "TreeProvider.getElements:" +
inputElement+"|"+inputElement.getClass() );
return getChildren( inputElement );
public void dispose()
System.err.println( "TreeProvider.dispose" );
ResourcesPlugin.getWorkspace().removeResourceChangeListener( this );
public void inputChanged( Viewer aviewer, Object oldInput, Object
newInput )
System.err.println( "TreeProvider.inputChanged" );
viewer = (StructuredViewer)aviewer;
* (non-Javadoc)
public void resourceChanged( IResourceChangeEvent event )
System.out.println("TreeProvider.resourceChagned");
IResourceDelta delta = event.getDelta();
try {
delta.accept( this );
} catch ( CoreException e ) {
e.printStackTrace();
* (non-Javadoc)
public boolean visit( IResourceDelta delta )
IResource source = delta.getResource();
System.out.println("TreeProvider.visit:"+source.getType() );
switch ( source.getType() ) {
case IResource.FOLDER:
System.err.println("folder change");
final IFolder f = (IFolder)source;
System.err.println("updating view");
new UIJob("Update Properties Model in CommonViewer") {
public IStatus runInUIThread(IProgressMonitor monitor) {
if (viewer != null
&& !viewer.getControl().isDisposed()) {
System.err.println("refreshing viewer for
project");
viewer.refresh(f);
return Status.OK_STATUS;
}.schedule();
case IResource.ROOT:
System.err.println("root change:");
final IResource root = (IResource)source;
if (viewer != null
project");
viewer.refresh(root);
}.schedule();
case IResource.PROJECT:
System.err.println("project change");
final IProject project = (IProject)source;
if (viewer != null
project");
viewer.refresh(project);
}.schedule();
return false;
case IResource.FILE:
System.err.println("got file");
final IFile file = (IFile) source;
// if (PROPERTIES_EXT.equals(file.getFileExtension())) {
// updateModel(file);
if (viewer != null
file");
viewer.refresh(file);
}.schedule();
return false;
default:
System.err.println("unknown change");
return true;
Re: custom content provider not automatically activated [message #325777 is a reply to message #325760] Tue, 26 February 2008 14:20 Go to previous messageGo to next message
The content provider must be set before that viewer call setInput method.
Is this?
Xiangya
Andreas Pakulat 写道:
> Any ideas?
> Andreas
> @Override
> } else {
> return childs;
> @Override
> return root;
> return null;
> @Override
> @Override
> @Override
> @Override
> newInput )
> * (non-Javadoc)
> try {
> * (non-Javadoc)
> if (viewer != null
> project");
> viewer.refresh(f);
> }.schedule();
> if (viewer != null
> project");
> }.schedule();
> if (viewer != null
> project");
> }.schedule();
> return false;
> if (viewer != null
> file");
> }.schedule();
> return false;
> default:
> return true;
Re: custom content provider not automatically activated [message #325778 is a reply to message #325777] Tue, 26 February 2008 14:35 Go to previous messageGo to next message
Qinxian wrote:
> Is this?
I don't do either, I just have the needed extension point declarations in my
plugin.xml.
org.eclipse.ui.navigator.CommonNavigator does seem to set at least the
filter and sorter before setting the input. I can't find any place where
the content provider is set though.
Andreas
Re: custom content provider not automatically activated [message #325784 is a reply to message #325778] Tue, 26 February 2008 22:20 Go to previous messageGo to next message
Yes, It seems be setInput.
Do you checked activeByDefault attribute of navigatorContent be true?
Xiangya
Andreas Pakulat 写道:
> Qinxian wrote:
>> Is this?
> plugin.xml.
> Andreas
Re: custom content provider not automatically activated [message #325806 is a reply to message #325784] Wed, 27 February 2008 11:52 Go to previous messageGo to next message
Yes thats set to true. Also the item has a checkmark in the Customize View..
dialog.
Maybe noteworthy: The content provider works on the project/folder/file
stuff from the workspace, just displays it a bit different. And the problem
is that after creating a new project it isn't shown until I disable and
re-enable the custom content provider.
Andreas
Re: custom content provider not automatically activated [message #325813 is a reply to message #325806] Wed, 27 February 2008 20:10 Go to previous messageGo to next message
Now It looks same as bug 156357: [CommonNavigator] Project Explorer does
not show contributed view menu actions unless opened on startup
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156357
Which version yours?
Xiangya
Andreas Pakulat 写道:
> dialog.
> Andreas
Re: custom content provider not automatically activated [message #325856 is a reply to message #325813] Fri, 29 February 2008 03:32 Go to previous messageGo to next message
Qinxian wrote:
I'm using:
org.eclipse.ui_3.3.1.M20070910-0800b.jar
org.eclipse.ui.navigator_3.3.2.M20071022-1600a.jar
org.eclipse.ui.navigator.resources_3.3.1.M20070831-2000.jar
so that should be fixed as far as I understand...
Andreas
Re: custom content provider not automatically activated [message #921719 is a reply to message #325856] Mon, 24 September 2012 07:21 Go to previous message
LearnMax offers Custom Content Development, a custom courseware developed to meet the unique training development needs of the clients. It is an end to end training solution starting from content design and development enabling you to upgrade and enhance your training requirements.
Kochar Infotech Pvt Ltd
learnmax(dot)co(dot)in
Previous Topic:Shutdown process and builder with UI-Dependencies
Next Topic:Race conditions in AnnotationModel? Error annotations lost in Reconciler
Current Time: Thu Jul 24 10:37:47 EDT 2025
Powered by FUDForum. Page generated in 0.03911 seconds
