Home » Eclipse Projects » Eclipse Platform » Eclipse 3.3.1 does not generate java1.5 class files
Eclipse 3.3.1 does not generate java1.5 class files [message #325510] Wed, 20 February 2008 12:21 Go to next message
Hi ,
I have build eclipse 3.3.1.1 with Java 6.0 on HP-UX. When I try to
generate a class file with this eclipse with preference for java
compliance set to 5.0 , it not generating 5.0 class files. It’s
generating 6.0 class files.
Do we need to do any special configuration changes to make this working?
Gowri
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325511 is a reply to message #325510] Wed, 20 February 2008 12:29 Go to previous messageGo to next message
You might have overridden the global settings in your Project
- Prakash
Eclipse Tips: http://blog.cypal-solutions.com
Eclipse Search: http://www.cypal.in/eclipsesearch
Gowri Kandasamy wrote:
> Hi ,
> compliance set to 5.0 , it not generating 5.0 class files. It?s
> Thanks
> Gowri
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325512 is a reply to message #325511] Wed, 20 February 2008 12:36 Go to previous messageGo to next message
The compliance level works in other platforms ( Linux / Windows).
I have issue with the eclipe IDE that I built on HP-UX. Do we need to
update the config.ini file to make this working ?
> - Prakash
>> Hi ,
>> Thanks
>> Gowri
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325513 is a reply to message #325512] Wed, 20 February 2008 12:42 Go to previous messageGo to next message
So your problem is that PDE-build doesn't respect your compilance
settings right? You need to set a target environment in your MANIFEST.MF
this is used to inform the PDE-build which compilance level has to be used.
Tom
>> - Prakash
>>> Hi ,
>>> Thanks
>>> Gowri
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325515 is a reply to message #325513] Wed, 20 February 2008 13:31 Go to previous messageGo to next message
Could you please explain your solution. Do we need to change manifest file
in project level or Eclipse level. I checked the MANIFEST.MF file in the
eclipse/plugins/org.eclipse.pde.build_3.3.1.v20070828/META-I NF
This has " Bundle-RequiredExecutionEnvironment: J2SE-1.4 "
> Tom
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325516 is a reply to message #325515] Wed, 20 February 2008 13:40 Go to previous messageGo to next message
Well I think PDE uses the information present in the MANIFEST.MF of the
plugin it builds. If no information is found there it runs the compiler
with no information and if you are on a JDK-6 system the default
..class-Format created by PDE-builds will be 1.6.
The simplest solution would be to simply tell eclipse to use another
JDK. I'm not 100% sure about all this but I think I can remember that
PDE doesn't respect compiler settings defined in the
project-preferences. Maybe someone with more knowledge about PDE can
give a better answer.
Tom
> file in project level or Eclipse level. I checked the MANIFEST.MF file
> in the eclipse/plugins/org.eclipse.pde.build_3.3.1.v20070828/META-I NF
>> MANIFEST.MF this is used to inform the PDE-build which compilance
>> Tom
Re: Eclipse 3.3.1 does not generate java1.5 class files [message #325517 is a reply to message #325515] Wed, 20 February 2008 13:41 Go to previous message
Originally posted by: zx.us.ibm.com
If you're bundle is intended to run on 5.0 and higher, it should be
J2SE-1.5. PDE Build uses the first BREE entry to decide what to
build/compile on plug-in export.
http://wiki.eclipse.org/Execution_Environments
~ Chris
Previous Topic:Correct way to get at values in plugin.properties?
Next Topic:Preferences for activeEditor Plugin
Current Time: Tue Jul 22 00:01:39 EDT 2025
Powered by FUDForum. Page generated in 0.03617 seconds
