Home » Eclipse Projects » Eclipse Platform » Remove button from TableViewer Item
Remove button from TableViewer Item [message #325501] Wed, 20 February 2008 08:54 Go to next message
i have an TableViewer with Button on some cells. The following code
creates them for me.
for(int i =0; i<items.length;i++) {
TableItem item = items[i];
TableEditor editor = new TableEditor(table);
Button button = new Button(table, SWT.PUSH);
button.setText("add");
button.pack();
editor.minimumWidth = button.getSize().x;
editor.horizontalAlignment = SWT.LEFT;
editor.setEditor(button, item, Layer.getMaxColumn());
buttonListener BL = new buttonListener(i);
button.addSelectionListener(BL);
Now i change the number of columns in my view. Here i want to remove
these "old" buttons from the cells. How can i do this?
viewer.getTable.clearAll() removes only the text from the cells, but not
the buttons. And the javadoc from item and table doesn't really helped
me here.
Greetrings
Re: Remove button from TableViewer Item [message #325503 is a reply to message #325501] Wed, 20 February 2008 10:05 Go to previous messageGo to next message
You need to dispose the editor for the item. The best idea IMHO is to
install a dispose listener on the item and dispose the Editor if the
item is diposed.
Activating multiple editors will eat up your native handles you are
running into resource problems. That's why I normally suggest not to use
multiple editors at once but fake the button using an image which can be
reused. It by the way doesn't look good if your application runs on OS-X
because buttons there can not be made small than a certain size!
Tom
Jörg schrieb:
> Hello,
> button.pack();
> me here.
> Greetrings
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Remove button from TableViewer Item [message #325524 is a reply to message #325503] Thu, 21 February 2008 00:28 Go to previous messageGo to next message
Originally posted by: chinfo.michiganreview.org
--------------070201090400040805010609
I'm having a similar problem, but disposing of the editor didn't seem to
do the trick. Any thoughts on what I'm missing?
In my case, I remove elements from the model, refresh the TableViewer,
get a reduced number of cell labels, but the original set of native
controls remain in the viewer.
I've copied the pertinent code below, and attached the full class
(adapted from the ExampleTableViewerWithNativeControls snippet).
Thanks in advance for your help.
-Christoph
final TableEditor editor = new TableEditor(item.getParent());
Composite comp = new Composite(item.getParent(),SWT.NONE);
comp.setBackground(item.getParent().getBackground());
comp.setBackgroundMode(SWT.INHERIT_DEFAULT);
RowLayout l = new RowLayout();
l.marginHeight=0;
l.marginWidth=0;
l.marginTop=0;
l.marginBottom=0;
comp.setLayout(l);
Button button = new Button(comp, SWT.PUSH);
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
System.out.println("Selection Event on: " + item);
button.setText("Push Me");
item.addDisposeListener(new DisposeListener() {
public void widgetDisposed(DisposeEvent event) {
editor.dispose();
editor.grabHorizontal=true;
editor.setEditor(comp, item, 1);
> item is diposed.
> Tom
> J
Re: Remove button from TableViewer Item [message #325531 is a reply to message #325524] Thu, 21 February 2008 03:43 Go to previous messageGo to next message
It seems that you also have to dipose the underlying control:
editor.getEditor().dispose();
Tom
Christoph Hoashi-Erhardt schrieb:
> Hello,
> -Christoph
> l.marginHeight=0;
> l.marginWidth=0;
> l.marginTop=0;
> l.marginBottom=0;
> comp.setLayout(l);
> editor.dispose();
>> item is diposed.
>> use multiple editors at once but fake the button using an image which
>> can be reused. It by the way doesn't look good if your application
>> runs on OS-X because buttons there can not be made small than a
>> certain size!
>> Tom
>> Jörg schrieb:
>>> Hello,
>>> button.pack();
>>> not the buttons. And the javadoc from item and table doesn't really
>>> helped me here.
>>> Greetrings
Re: Remove button from TableViewer Item [message #325535 is a reply to message #325531] Thu, 21 February 2008 05:21 Go to previous messageGo to next message
I've updated the snippet to dispose the created editors when needed.
Tom
> Tom
>> Hello,
>> to do the trick. Any thoughts on what I'm missing?
>> -Christoph
>> l.marginHeight=0;
>> l.marginWidth=0;
>> l.marginTop=0;
>> l.marginBottom=0;
>> comp.setLayout(l);
>> editor.dispose();
>>> item is diposed.
>>> certain size!
>>> Tom
>>> Jörg schrieb:
>>>> Hello,
>>>> button.pack();
>>>> helped me here.
>>>> Greetrings
Re: Remove button from TableViewer Item [message #325537 is a reply to message #325503] Thu, 21 February 2008 05:56 Go to previous messageGo to next message
I need only five editors at maximum maybe ten. So now i take those
editors in a array and set them to the new TableItem. Thanks for your
help again. It helps a lot :)
> item is diposed.
> Tom
> Jörg schrieb:
>> Hello,
>> button.pack();
>> helped me here.
>> Greetrings
Re: Remove button from TableViewer Item [message #325563 is a reply to message #325535] Thu, 21 February 2008 22:48 Go to previous message
Thanks so much for your help.
-Christoph
Tom Schindl wrote:
> Tom
>> Tom
>>> Hello,
>>> TableViewer, get a reduced number of cell labels, but the original
>>> set of native controls remain in the viewer.
>>> -Christoph
>>> l.marginHeight=0;
>>> l.marginWidth=0;
>>> l.marginTop=0;
>>> l.marginBottom=0;
>>> comp.setLayout(l);
>>> editor.dispose();
>>>> to install a dispose listener on the item and dispose the Editor if
>>>> the item is diposed.
>>>> which can be reused. It by the way doesn't look good if your
>>>> application runs on OS-X because buttons there can not be made small
>>>> Tom
>>>> Jörg schrieb:
>>>>> Hello,
>>>>> button.pack();
>>>>> remove these "old" buttons from the cells. How can i do this?
>>>>> but not the buttons. And the javadoc from item and table doesn't
>>>>> really helped me here.
>>>>> Greetrings
Previous Topic:Irregular expressions?
Next Topic:getting IResource objects for all files in an IResource directory
Current Time: Wed Jul 16 14:08:16 EDT 2025
Powered by FUDForum. Page generated in 0.27462 seconds
