Home » Eclipse Projects » Eclipse Platform » need help tweaking a layout on preference page
need help tweaking a layout on preference page [message #325394] |
Sat, 16 February 2008 18:47  |
Originally posted by: marc_e.ye.olde.spam.buster.cablespeed.com
Greetings all. I've got a preference page that extends
FieldEditorPreferencePage.
I'm have only a few preferences, but they naturally fit into groups so I'd
like to group them with a Group().
Everything works fine when I use stringfieldeditor. That is to say, the
label lines up nicely on the left and the string field sits to the right..
Everything appears to be a nice 2-column grid layout.
However, I have one group that takes a DirectoryFieldEditor. When I call
addField() with this editor, it completely screws up the layout for the
previous field editors. What happens is that the label for those previous
ones now sits on top of the string fields. So instead of:
Username: -------------------------
Password: -------------------------
Directory: ----------------------------------------------- Browse
I now get
Username:
Password:
Directory -------------------------------------------------Browse
I'm admittedly still just learning layouts, and I'm hoping its that n00b
misunderstanding that's causing me to miss something obvious. I've tried
all kinds of combinations with spans and Layout cols, but to no avail.
Any help is MOST appreciated!!!
Thanks so much.
Here's my code:
public void createFieldEditors() {
Composite container = new
Composite(this.getFieldEditorParent(),SWT.NONE);
GridData containerData = new
GridData(GridData.FILL,GridData.FILL,true,false);
containerData.horizontalSpan = 1;
container.setLayoutData(containerData);
GridLayout layout = new GridLayout(1,false);
container.setLayout(layout);
//first group
Group urlGroup = new Group(container,SWT.NONE);
urlGroup.setText("Test Runner URL");
GridData gd = new GridData(GridData.FILL,GridData.FILL,true,false);
gd.horizontalSpan = 2;
urlGroup.setLayoutData(gd);
urlGroup.setLayout(new GridLayout(2,false));
addField(new StringFieldEditor(MXUnitPreferenceConstants.P_USERNAME, "
&Username:", 20, urlGroup));
addField(new StringFieldEditor(MXUnitPreferenceConstants.P_PASSWORD, "
&Password:", 20, urlGroup));
//second group
Group webrootGroup = new Group(container, SWT.NONE);
webrootGroup.setText("Your web root");
GridData gd3 = new GridData(GridData.FILL,GridData.FILL,true,false);
gd3.horizontalSpan = 3;
webrootGroup.setLayoutData(gd3);
webrootGroup.setLayout(new GridLayout(3,false));
DirectoryFieldEditor webrootDir = new
DirectoryFieldEditor(MXUnitPreferenceConstants.P_WEBROOTPATH ,
" &Web root directory:", webrootGroup);
addField(webrootDir);
Re: need help tweaking a layout on preference page [message #325395 is a reply to message #325394] |
Sun, 17 February 2008 15:07   |
Originally posted by: tskaufma.gmail.com
Hey Marc,
It appears there is some magic going on.
When you create the FieldEditors, they are setting the layout on the
parent. Your layouts get ignored. Also, after the createFieldEditors method
another method is called in which all the field editors adjust their size to
fill the space.
I am not sure what the best possible solution is, but in your specific case,
getting the layout from group and adjusting its numColumns got the result
you were looking for.
After adding the two StringFieldEditors do this:
GridLayout urlLayout = (GridLayout) urlGroup.getLayout();
urlLayout.numColumns = 3;
This works, but I am not sure its the best way to go about this. If anyone
else has a better solution, please comment, I am interested in seeing the
answer.
Hope this helps,
Trevor Kaufman
"Marc E" <marc_e@ye.olde.spam.buster.cablespeed.com> wrote in message
news:fp7snm$uih$1@build.eclipse.org...
> I now get
> Username:
> Password:
> Thanks so much.
> Here's my code:
> //first group
> //second group
Re: need help tweaking a layout on preference page [message #325406 is a reply to message #325395] |
Mon, 18 February 2008 04:54   |
Un-be-liev-able.
dude, i spent hours monkeying with this. trying to set the griddata
separately on the label and text fields, etc. your two lines did the trick.
funny thing is i had added that exact code *before* the addField but never
thought to try adding it after. Duh.
That said, i still don't understand exactly what was going on. I understand
addField was modifying the layout, but i don't understand specifically why
it was creating the effect it did, i.e. why the label was taking up the
entire row and pushing my text fields down a row.
Could you take a few minutes and explain that?
Thanks!
Marc
"Trevor Kaufman" <tskaufma@gmail.com> wrote in message
news:fpa45l$8kl$1@build.eclipse.org...
> Hey Marc,
> method another method is called in which all the field editors adjust
> their size to fill the space.
> case, getting the layout from group and adjusting its numColumns got the
> result you were looking for.
> answer.
> Hope this helps,
> Trevor Kaufman
>> I'd like to group them with a Group().
>> right.. Everything appears to be a nice 2-column grid layout.
>> I now get
>> Username:
>> Password:
>> Thanks so much.
>> Here's my code:
>> //first group
>> //second group
Re: need help tweaking a layout on preference page [message #325433 is a reply to message #325406] |
Mon, 18 February 2008 12:36   |
Hey Marc,
I'll do my best to explain it here.
When you create and add your FieldEditors they set the layout on their
parent. In your case, that is the group. After createFieldEditor returns,
another method gets called if the layout style is GRID. This method
readjusts all the FieldEditors to fit given the largest FieldEditor. In your
case, the largest has 3 controls, which is the DirectoryFieldEditor. This
information is passed to your StringFieldEditors and they decide to make the
text control have a horizontal span of 2 columns. Since your group
containing the StringFieldEditors only has 2 columns, the text control jumps
down to the next line to satisfy its column span of 2.
There appears to be an assumption that ALL the FieldEditors share a common
parent, namely the one returned by getFieldEditorParent(), and so the
automatic layout adjustments are all tuned for that. This assumption is not
true in your case and is causing odd behaviour.
I hope this clarifies what is going on,
Trevor Kaufman
news:fpbkkd$fu2$1@build.eclipse.org...
> Un-be-liev-able.
> trick. funny thing is i had added that exact code *before* the addField
> but never thought to try adding it after. Duh.
> understand addField was modifying the layout, but i don't understand
> specifically why it was creating the effect it did, i.e. why the label was
> taking up the entire row and pushing my text fields down a row.
> Thanks!
> Marc
>> Hey Marc,
>> anyone else has a better solution, please comment, I am interested in
>> seeing the answer.
>> Hope this helps,
>> Trevor Kaufman
>>> previous ones now sits on top of the string fields. So instead of:
>>> I now get
>>> Username:
>>> Password:
>>> tried all kinds of combinations with spans and Layout cols, but to no
>>> avail.
>>> Thanks so much.
>>> Here's my code:
>>> //first group
>>> " &Username:", 20, urlGroup));
>>> " &Password:", 20, urlGroup));
>>> //second group
Re: need help tweaking a layout on preference page [message #325436 is a reply to message #325433] |
Mon, 18 February 2008 15:12  |
perfect. thanks!
news:fpcfne$ljb$1@build.eclipse.org...
> Hey Marc,
> your case, the largest has 3 controls, which is the DirectoryFieldEditor.
> This information is passed to your StringFieldEditors and they decide to
> make the text control have a horizontal span of 2 columns. Since your
> group containing the StringFieldEditors only has 2 columns, the text
> control jumps down to the next line to satisfy its column span of 2.
> not true in your case and is causing odd behaviour.
> Trevor Kaufman
>> Un-be-liev-able.
>> was taking up the entire row and pushing my text fields down a row.
>> Thanks!
>> Marc
>>> Hey Marc,
>>> seeing the answer.
>>> Hope this helps,
>>> Trevor Kaufman
>>>> call addField() with this editor, it completely screws up the layout
>>>> for the previous field editors. What happens is that the label for
>>>> those previous ones now sits on top of the string fields. So instead
>>>> of:
>>>> I now get
>>>> Username:
>>>> Password:
>>>> n00b misunderstanding that's causing me to miss something obvious.
>>>> I've tried all kinds of combinations with spans and Layout cols, but to
>>>> no avail.
>>>> Thanks so much.
>>>> Here's my code:
>>>> //first group
>>>> //second group
Current Time: Tue Jul 22 15:46:03 EDT 2025
Powered by FUDForum. Page generated in 0.03666 seconds
