Home » Eclipse Projects » Eclipse Platform » ntlm authentication question
ntlm authentication question [message #325391] Sat, 16 February 2008 10:14 Go to next message
Originally posted by: marc_e.ye.olde.spam.buster.cablespeed.com
All,
I've got a plugin that uses axis 1.4 to make webservice calls. Things work
nicely for unauthenticated and basic authentication. But when I secure a
resource with NTLM (integrated windows authentication), I always get "401
unauthorized".
I've tried everything I could learn about how to get this to work with
Axis but I just can't figure it out. I see no reason why it shouldn't work.
The reason I'm posting to this group is that I know it can be done because
I can access the wsdl URL using the web services explorer in the web tools
project. And I can access the URL using the services browser in the
ColdFusion eclipse plugins.
So mainly what I'm hoping is that someone out there reads this who maybe
knows a bit about how the web tools project is doing this, or someone who
has tried to use axis inside an eclipse plugin before to communicate with an
ntlm-protected resource.
Thanks for any help!
Marc
Re: ntlm authentication question [message #325397 is a reply to message #325391] Sun, 17 February 2008 21:16 Go to previous messageGo to next message
The HTTP authentication using Axis is done using the Apache HTTPClient.
Though it supports NTLM authentication, it does not support NTLM v2
authentication. That's probably the problem you are running into.
This might help:
http://www.oaklandsoftware.com/papers/ntlm.html
Francis
Marc E wrote:
> All,
> unauthorized".
> Marc
Re: ntlm authentication question [message #325407 is a reply to message #325397] Mon, 18 February 2008 04:58 Go to previous messageGo to next message
Thanks Francis. So would you say that if I followed all the instructions for
using httpclient, and I see the NTLM credentials being passed in tcpmon,
that it *should* be working, and that provided I'm seeing the credentials
being passed, then it's something outside of code, i.e. machine setup, etc
that's causing it not to work? Does that seem most likely?
Thanks again.
Marc
"Francis Upton" <francisu@ieee.org> wrote in message
news:47B8EA97.4090709@ieee.org...
> This might help:
> Francis
> Marc E wrote:
>> All,
>> work nicely for unauthenticated and basic authentication. But when I
>> secure a resource with NTLM (integrated windows authentication), I always
>> get "401 unauthorized".
>> work.
>> because I can access the wsdl URL using the web services explorer in the
>> web tools project. And I can access the URL using the services browser in
>> the ColdFusion eclipse plugins.
>> an ntlm-protected resource.
>> Marc
Re: ntlm authentication question [message #325429 is a reply to message #325407] Mon, 18 February 2008 11:11 Go to previous messageGo to next message
Yes, exactly, you are probably communication with a Windows Server 2003
with the default configuration, it insists on NTLM V2. Unfortunately,
NTLM is not very helpful when it does not work out, it just repeats the
401 without saying why. You could try installing the eval version of
the Oakland Software HTTP client (which works with Axis) and see if the
problem goes away.
> Thanks again.
> Marc
>> This might help:
>> Francis
>> Marc E wrote:
>>> All,
>>> work.
>>> Marc
Re: ntlm authentication question [message #325435 is a reply to message #325429] Mon, 18 February 2008 15:11 Go to previous message
Cool. Thanks a lot, Francis.
news:47B9AE49.5050608@ieee.org...
> 401 without saying why. You could try installing the eval version of the
> problem goes away.
>> for using httpclient, and I see the NTLM credentials being passed in
>> tcpmon, that it *should* be working, and that provided I'm seeing the
>> credentials being passed, then it's something outside of code, i.e.
>> machine setup, etc that's causing it not to work? Does that seem most
>> likely?
>> Thanks again.
>> Marc
>>> This might help:
>>> Francis
>>> Marc E wrote:
>>>> All,
>>>> always get "401 unauthorized".
>>>> with Axis but I just can't figure it out. I see no reason why it
>>>> shouldn't work.
>>>> the web tools project. And I can access the URL using the services
>>>> browser in the ColdFusion eclipse plugins.
>>>> maybe knows a bit about how the web tools project is doing this, or
>>>> someone who has tried to use axis inside an eclipse plugin before to
>>>> communicate with an ntlm-protected resource.
>>>> Marc
Previous Topic:Can one define the target platform as a project specific setting?
Next Topic:need help tweaking a layout on preference page
Current Time: Sat Nov 08 23:19:29 EST 2025
Powered by FUDForum. Page generated in 0.04786 seconds
