Home » Language IDEs » Java Development Tools (JDT) » compiler bug
compiler bug [message #32925] Tue, 20 May 2003 22:19 Go to next message
Originally posted by: yongw2.21cn.com
Platform: Eclipse/JDT 2.1.0, Windows 2000.
The following code is a simplified version of a machine-generated java code,
it is compiled successfully with JDT's internal Java compiler, but when
runs, it produces error message:
java.lang.VerifyError: (class: Bug, method: bug signature: (I)I) Illegal
default target in switch
Exception in thread "main"
However, I can compile and run it without any problem using Sun's JDK 1.4, I
think it is an internal bug, anyone who can help ?
----------------------bug code---------------
public class Bug
public static void main(String[] args)
int i = bug(123);
System.out.println(i);
public static int bug(int ppp)
switch(ppp) {
case 1:
case 2:
if (true) return(3);
break;
case 4:
break;
default :
break;
return(-1);
Re: compiler bug [message #32960 is a reply to message #32925] Wed, 21 May 2003 01:07 Go to previous messageGo to next message
Sorry for the incomplete error message, the correct error message is :
java.lang.VerifyError: (class: jasn/parser/AsnParser, method: integerValue
signature: (Ljasn/parser/IntegerTypeInfo;)Ljasn/parser/BaseValueInfo;)
Illegal target of jump or branch
Exception in thread "main" make: Error code 1
code,
I
> public class Bug
> int i = bug(123);
> switch(ppp) {
> case 1:
> case 2:
> break;
> case 4:
> break;
> default :
> break;
> return(-1);
Re: compiler bug [message #33467 is a reply to message #32960] Wed, 21 May 2003 09:23 Go to previous messageGo to next message
It sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=37621 which is
fixed in the latest 3.0 integration build and that will be in a next 2.1.1
maintenance build.
If you find that this is a different problem, do not hesitate to enter a bug
against JDT/Core.
Jerome
"Yong WANG" <yongw2@21cn.com> wrote in message
news:baf1j8$ljt$1@rogue.oti.com...
> code,
1.4,
> I
> > public class Bug
> > int i = bug(123);
> > switch(ppp) {
> > case 1:
> > case 2:
> > break;
> > case 4:
> > break;
> > default :
> > break;
> > return(-1);
Re: compiler bug [message #33639 is a reply to message #33467] Wed, 21 May 2003 10:10 Go to previous message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Wed, 21 May 2003 15:23:57 +0200, "Jerome Lanneluc"
>maintenance build.
>against JDT/Core.
I checked that this problem is fixed in integration build 0520.
Olivier
Previous Topic:Launching the system default web browser
Next Topic:Debugging with HotSwap No Longer Working...
Current Time: Wed Jul 16 21:48:12 EDT 2025
Powered by FUDForum. Page generated in 0.09410 seconds
