Instantiation of blocks does not show ports in Papyrus [message #1688403] |
Fri, 20 March 2015 12:29  |
When I instantiate a block from the block definition diagram in the internal block diagram, it just creates the part without the ports.
Can this be changed?
Also as I am creating an instance, I want to make a definition of variables. The instantiation should show this or at least the declaration.
Thank you,
Frank
Re: Instantiation of blocks does not show ports in Papyrus [message #1690872 is a reply to message #1688403] |
Tue, 31 March 2015 12:40  |
Hi, Frank,
I don't know anything about the semantics of SysML or how the diagrams
differ from UML, but perhaps something like the canonical view
synchronization available in M6 of the Mars release will help. In
particular, the integration with CSS for enablement of the canonical
style:
https://youtu.be/uo2jpPd-n2s
HTH,
Christian
On 2015-03-20 16:29:30 +0000, Frank W. said:
> declaration.
> Thank you,
> Frank
FUDForum. Page generated in 0.27030 seconds
