Use LPEX as default editor for any file type? [message #32864] |
Fri, 17 May 2002 10:40  |
Originally posted by: herbert.spamcop.net
is there any way to setup LPEX as default editor for other
file types, like Makefiles?
Herbert
It was hard to code, so it should be hard to understand!
Dipl.Ing. Martin "Herbert" Dietze -=-=- The University of Buckingham -=-=-
Re: Use LPEX as default editor for any file type? [message #33034 is a reply to message #32864] |
Fri, 17 May 2002 10:42  |
Just to be more comprehensive in my previous answer:
if you do have some file extension, you can associate lpex with it by
clicking on Window -> Preferences, select Workbench -> File Editors
and there you will see a bunch of file type associations. You can
add / remove etc.
Try no extension, and you will be disappointed.
This issue might be better raised in the eclipse.tools forum.
Robert.
FUDForum. Page generated in 0.09135 seconds
