Home » Eclipse Projects » Eclipse Platform » Snippet036FocusBorderCellHighlighter
| Snippet036FocusBorderCellHighlighter [message #324715] |
Thu, 31 January 2008 02:28  |
Hi there,
I am using a DialogCellEditor in the 3rd column instead of a
TextCellEditor. So, when I double-click on the column the cell enters into
an editable mode; which display the label + the button; which is perfect!
However, if I single-click on any other cell/column, then the previous
cell loses its focus; but it is still displaying the button instead of
returning to its original editor value.
If you edit the Snippet036FocusBorderCellHighlighter class and add the
code below (replace DatePickerDialog with any dummy dialog since you don't
need to launch the dialog), you will see the problem.
Is there a workaround for this or is this a bug? Thanks in advance!
protected class DateDialogCellEditor extends DialogCellEditor {
public DateDialogCellEditor(Composite parent) {
super(parent);
protected Object openDialogBox(Control cellEditorWindow) {
DatePickerDialog dialog = new
DatePickerDialog(cellEditorWindow.getShell());
return dialog.open();
public Snippet036FocusBorderCellHighlighter(Shell shell) {
v.setCellEditors(new CellEditor[] { new TextCellEditor(v.getTable()),
new TextCellEditor(v.getTable()), new DateDialogCellEditor(v.getTable())
| Re: Snippet036FocusBorderCellHighlighter [message #324716 is a reply to message #324715] |
Thu, 31 January 2008 02:43   |
--------------020304090608090103090109
Is there an exception logged (I ask because the return value from
DatePickerDialog is a Date, right)? Isn't there any exception in your
console logged?
I've just tested on OS-X with JFace from HEAD (+ SWT from I20080122)
with the snippet attached and the Editor is correctly disabled. I
replaced your DatePicker (which is not available on my installation with
a standard dialog).
Tom
AJ schrieb:
> Hi there,
> into an editable mode; which display the label + the button; which is
> perfect!
> don't need to launch the dialog), you will see the problem.
> super(parent);
> @Override
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
name="Snippet036FocusBorderCellHighlighter.java"
Content-Disposition: inline;
filename="Snippet036FocusBorderCellHighlighter.java"
* Copyright (c) 2006 Tom Schindl and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Tom Schindl - initial API and implementation
package org.eclipse.jface.snippets.viewers;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.jface.resource.FontRegistry;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableColorProvider;
import org.eclipse.jface.viewers.ITableFontProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerEditor;
import org.eclipse.jface.viewers.TableViewerFocusCellManager;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TableColumn;
* Example of a different focus cell rendering with a simply focus border
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class Snippet036FocusBorderCellHighlighter {
private class MyContentProvider implements IStructuredContentProvider {
* (non-Javadoc)
* @see org.eclipse.jface.viewers.IStructuredContentProvider#getElem ents(java.lang.Object)
public Object[] getElements(Object inputElement) {
return (MyModel[]) inputElement;
* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#dispose()
public void dispose() {
* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#inputChanged(org. eclipse.jface.viewers.Viewer,
* java.lang.Object, java.lang.Object)
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
public static boolean flag = true;
public class MyModel {
public int counter;
public MyModel(int counter) {
this.counter = counter;
public String toString() {
return "Item " + this.counter;
public class MyLabelProvider extends LabelProvider implements
ITableLabelProvider, ITableFontProvider, ITableColorProvider {
FontRegistry registry = new FontRegistry();
public Image getColumnImage(Object element, int columnIndex) {
return null;
public String getColumnText(Object element, int columnIndex) {
return "Column " + columnIndex + " => " + element.toString();
public Font getFont(Object element, int columnIndex) {
return null;
public Color getBackground(Object element, int columnIndex) {
return null;
public Color getForeground(Object element, int columnIndex) {
return null;
protected class DateDialogCellEditor extends org.eclipse.jface.viewers.DialogCellEditor {
super(parent);
TitleAreaDialog dialog = new TitleAreaDialog(cellEditorWindow.getShell());
return new Integer(dialog.open());
final TableViewer v = new TableViewer(shell, SWT.BORDER|SWT.FULL_SELECTION);
v.setLabelProvider(new MyLabelProvider());
v.setContentProvider(new MyContentProvider());
v.setCellEditors(new CellEditor[] { new TextCellEditor(v.getTable()), new TextCellEditor(v.getTable()), new DateDialogCellEditor(v.getTable()) });
v.setCellModifier(new ICellModifier() {
public boolean canModify(Object element, String property) {
return true;
public Object getValue(Object element, String property) {
return "Column " + property + " => " + element.toString();
public void modify(Object element, String property, Object value) {
v.setColumnProperties(new String[] {"1","2","3"});
TableViewerFocusCellManager focusCellManager = new TableViewerFocusCellManager(v,new FocusBorderCellHighlighter(v));
ColumnViewerEditorActivationStrategy actSupport = new ColumnViewerEditorActivationStrategy(v) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType == ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR)
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
TableViewerEditor.create(v, focusCellManager, actSupport, ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL | ColumnViewerEditor.KEYBOARD_ACTIVATION);
TableColumn column = new TableColumn(v.getTable(), SWT.NONE);
column.setWidth(200);
column.setMoveable(true);
column.setText("Column 1");
column.setText("Column 2");
column.setText("Column 3");
MyModel[] model = createModel();
v.setInput(model);
v.getTable().setLinesVisible(true);
v.getTable().setHeaderVisible(true);
private MyModel[] createModel() {
MyModel[] elements = new MyModel[10];
for (int i = 0; i < 10; i++) {
elements[i] = new MyModel(i);
return elements;
* @param args
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet036FocusBorderCellHighlighter(shell);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
--------------020304090608090103090109--
| Re: Snippet036FocusBorderCellHighlighter [message #324742 is a reply to message #324734] |
Thu, 31 January 2008 10:18   |
--------------040006030805080001020802
Ah. I see. This is an OS-X only problem! If you run this snippet on
win32 where a Button can receive the focus the editor is deactivated
when the cell blurs (by the way the Cursor-Implementation only looks
nice on OS-X and on OS-X I get an NPE when shutting down :-(.
This seems to be a problem nobody ever had when. IMHO the
DialogCellEditor always looks scrambled in OS-X because the button
doesn't fit into the cell.
My suggestion would be fork the current DialogCellEditor remove the
SWT-Button-Stuff and directly open the editor on DoubleClick.
If you want to use the DialogCellEditor as it comes from JFace I think
you have only one chance :-)
You need to cancle an active editor when ever your the focus-cell
changes and an editor is active!
I've attached a patched cursor cell highlighter.
Tom
Tom Schindl schrieb:
> Does my snippet produce the same behaviour? Can you give me a detailed
> list how to reproduce (1. Click here 2. ...) our send me a completely
> runnable snippet with the all code I need (if you don't want to send it
> to the list you can send it to me privately).
> As said I have tested with JFace from CVS-HEAD 3.4 and SWT from an
> integration build. We have fixed many bugs in 3.4 so it could be that
> this is why I'm not seeing the problem.
> Tom
> AJ schrieb:
>> Hi Tom,
>> The dialog returns a formatted string, however, you don't have to
>> click on the button or launch the dialog to see the problem.
>> There are not exceptions reported in the .log file or on the console
>> or error log views.
>> I am also running it on OS/X, but I am using the 3.3.1.1 release build.
>> Sorry, but are you saying that it works fine with the latest 3.4
>> integration build?
>> Thanks!
name="CursorCellHighlighter.java"
filename="CursorCellHighlighter.java"
* Copyright (c) 2007 IBM Corporation and others.
* Contributors:
* IBM Corporation - initial API and implementation
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationListen er;
import org.eclipse.jface.viewers.ColumnViewerEditorDeactivationEven t;
import org.eclipse.jface.viewers.FocusCellHighlighter;
import org.eclipse.jface.viewers.ViewerCell;
* @since 3.3
public class CursorCellHighlighter extends FocusCellHighlighter {
private ColumnViewer viewer;
private AbstractCellCursor cursor;
* @param viewer
* @param cursor
public CursorCellHighlighter(ColumnViewer viewer,
AbstractCellCursor cursor) {
super(viewer);
this.viewer = viewer;
this.cursor = cursor;
protected void focusCellChanged(ViewerCell cell) {
super.focusCellChanged(cell);
if( ! viewer.isCellEditorActive() ) {
cursor.setSelection(cell, 0); //TODO THE TIME
cursor.setVisible(true);
} else {
viewer.cancelEditing();
protected void init() {
hookListener();
private void hookListener() {
ColumnViewerEditorActivationListener listener = new ColumnViewerEditorActivationListener() {
public void afterEditorActivated(
public void afterEditorDeactivated(
ColumnViewerEditorDeactivationEvent event) {
cursor.setSelection(getFocusCell(), 0); //TODO THE TIME
public void beforeEditorActivated(
cursor.setVisible(false);
public void beforeEditorDeactivated(
viewer.getColumnViewerEditor().addEditorActivationListener(l istener);
--------------040006030805080001020802--
| Re: Snippet036FocusBorderCellHighlighter [message #324888 is a reply to message #324882] |
Mon, 04 February 2008 03:27   |
Well I'd open the Dialog when CellEditor#activate() is called.
Tom
AJ schrieb:
> Hey Tom,
> As per your suggestion, I forked the current DialogCellEditor, removed
> the SWT-Button-Stuff, and set to open the editor on DoubleClick.
> However, it does it after 2 set of DoubleClicks. The first one switches
> the cell to edit mode, then I have to double-click again to open the
> dialog.
> I tried to open the dialog (via focusGained), but it does not seem to
> work. So, is there a way to launch the dialog with the first
> DoubleClick on the cell?
> Thanks!
| Re: Snippet036FocusBorderCellHighlighter [message #324906 is a reply to message #324904] |
Mon, 04 February 2008 07:34  |
You could even only open when (double)clicked (e.g. not when user tabs
into the cell) by overloading
CellEditor#activate(ColumnViewerEditorActivationEvent).
In case the user tabs into the control he/she would e.g. need to press
space to open the editor.
Tom
AJ schrieb:
> Perfect, that did it. Thanks Tom!
Current Time: Wed Nov 05 06:49:52 EST 2025
Powered by FUDForum. Page generated in 0.04914 seconds
