Home » Newcomers » Newcomers » Plug-Ins Installation
Plug-Ins Installation [message #32802] Fri, 11 March 2005 10:17 Go to next message
Originally posted by: h.alizieri.fsilatinamerica.com.ar
How to install plugins manually?
I want to install visual editor and uml2 plugins
but when I try to update inside aclipse it can't
connect because of a network problem.
I can download the plugins from the download
site but when I copy the folders in the plugins
folder nothing happens.
How to install plug-ins manually?
Thank you
Re: Plug-Ins Installation [message #32893 is a reply to message #32802] Fri, 11 March 2005 12:48 Go to previous messageGo to next message
Originally posted by: smcnena.yahoo.com
Are you unzipping the plugins directly into the plugins folder?
"Hern
Re: Plug-Ins Installation [message #32927 is a reply to message #32893] Fri, 11 March 2005 13:33 Go to previous messageGo to next message
I unzip i.e. VE-runtime-1.0.1.1 and it generates 2 folders:
features and plugins
I copy the subfolders in the eclipse\features and eclipse\plugins.
It Sounds bad? :)
Re: Plug-Ins Installation [message #32961 is a reply to message #32927] Fri, 11 March 2005 14:08 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Hernán,
Run Eclipse once with the -clean command line option. For example on
Windows: Start->Run-> "C:\path_to_eclipse\eclipse.exe" -clean
Also you should be using VE 1.0.2 :)
Hope this helps,
- Jeff
> It Sounds bad? :)
Re: Plug-Ins Installation [message #33345 is a reply to message #32961] Fri, 11 March 2005 19:54 Go to previous message
yep jeff s advice sounds good.
"Jeff Myers" <myersj@gmail.com> wrote in message
news:d0sqb4$mvm$1@www.eclipse.org...
> Hern
Previous Topic:Eclipse 3.1M5a dont starts at Conectiva Linux 10
Next Topic:Eclipse 3.1M5a does not start on Mac OS X
Current Time: Fri May 09 20:54:43 EDT 2025
Powered by FUDForum. Page generated in 0.14926 seconds
