Home » Eclipse Projects » Eclipse Platform » Can I program to delete project in workspace without showing the confirm dialog?
Can I program to delete project in workspace without showing the confirm dialog? [message #324043] Wed, 16 January 2008 22:36 Go to next message
Hi all,
My project has a working directory, when user set the dir , I will
delete projects in the workspace and
create a project with the dir name and then import the dir's files into the
project.
When I delete project, the confirm dialog appears.
As user no need to see this process , is there a way to not show this
dialog?
Or is there better way to implement this function?
Thanks .
Anthony Lee
Re: Can I program to delete project in workspace without showing the confirm dialog? [message #324047 is a reply to message #324043] Thu, 17 January 2008 01:11 Go to previous message
Are you using IResource.delete(true, null)? That should work without
popping up a dialog. You can find the project resource by:
IProject project =
ResourcesPlugin.getWorkspace().getRoot().getProject("projectName ");
Anthony Lee wrote:
> Hi all,
> project.
> dialog?
> Thanks .
> Anthony Lee
Previous Topic:Title Image in Section
Next Topic:Libraries vanish
Current Time: Wed Jul 16 20:11:42 EDT 2025
Powered by FUDForum. Page generated in 0.10296 seconds
