Home » Eclipse Projects » Eclipse Platform » [PDE] Externalizing Strings dialog and ignore pattern
[PDE] Externalizing Strings dialog and ignore pattern [message #323986] Tue, 15 January 2008 09:27 Go to next message
Originally posted by: atoulme.intalio.com
Hi all,
when typing //$NON-NLS-1$ to ignore a string, the PDE dialog to help
externalizing does not recognize that pattern when adding a space
between // and $NON-NLS-1$. Is it a bug, or just a limit ?
On the whole, is it possible to have someone type:
System.out.print("Hello"); // blablabla $NON-NLS-1$
If that is not permitted, I'd like to open a request for enhancement to
chase such patterns and mark them as errors, or at least warnings, so
people don't mess up NLS patterns.
Antoine
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: [PDE] Externalizing Strings dialog and ignore pattern [message #324019 is a reply to message #323986] Wed, 16 January 2008 10:28 Go to previous messageGo to next message
Antoine Toulme wrote:
> Hi all,
Intended behavior.
> to chase such patterns and mark them as errors, or at least warnings,
> so people don't mess up NLS patterns.
You do get a warning on the string and hence you detect the mistake.
Dani
> Antoine
Re: [PDE] Externalizing Strings dialog and ignore pattern [message #324025 is a reply to message #323986] Wed, 16 January 2008 12:37 Go to previous messageGo to next message
It seems I'm better off filing a bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215466
Antoine
> Hi all,
> Antoine
Re: [PDE] Externalizing Strings dialog and ignore pattern [message #324714 is a reply to message #324019] Wed, 30 January 2008 21:50 Go to previous messageGo to next message
>> Hi all,
> Intended behavior.
Maybe implementing a quick fix would do good there, then ?
What do you think ?
Antoine
> Dani
>> Thanks,
>> Antoine
Re: [PDE] Externalizing Strings dialog and ignore pattern [message #324723 is a reply to message #324714] Thu, 31 January 2008 04:41 Go to previous message
>>> Hi all,
>> Intended behavior.
>>> warnings, so people don't mess up NLS patterns.
There's a quick fix to add it but we can't guess that you just missed
the //. What if you wrote $NO-NLS$, or $NO-NL$? Should we offer a quick
fix to remove those? I don't think so.
Dani
> What do you think ?
> Cheers,
> Antoine
>> Dani
>>> Thanks,
>>> Antoine
Previous Topic:Changing color of text in editor
Next Topic:Plugin export generates "logs.zip", notifying errors in a error-free workbench
Current Time: Thu Jul 17 23:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.09523 seconds
