Home » Eclipse Projects » Eclipse Platform » Cell editing in TreeViewer in 3.3
Cell editing in TreeViewer in 3.3 [message #323912] Sat, 12 January 2008 12:08 Go to next message
Hi folks,
Would love a hand from someone more familiar with cell editing in JFace.
I had a scheme where right-clicking on an item in a TreeViewer and
selecting "Rename" from the menu allows it to be edited in place. Moving
from 3.2 to 3.3 has broken this.
The canModify and getValue methods of my cell modifier are still called,
but modify is not called. On the screen, the user is not given the
chance to edit the cell - there is a flash, like a refresh, in which I
think the editor is activated and then deactivated (modify is not called
as the value hasn't been changed).
Yet, when I allow modification with a single mouse click - by adding the
event type to isEditorActivated - the whole thing works fine. The only
new code for 3.3 is the TreeViewerEditor.create call, the rest was
functioning in 3.2.
So I'm wondering - is there some flag to set or function call to make to
allow me to programmatically invoke the cell editor? Why does single
click editing work, but programmatic invocation result in the editor
simply opening and closing?
_Any_ help would be appreciated, I'm a little stuck.
Cheers
Marcel
Creating the viewer:
viewer = new TreeViewer(layout, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
viewer.setLabelProvider(new BrowsableTreeLabelProvider());
viewer.setContentProvider(new BrowsableTreeContentProvider());
viewer.setSorter(new BrowsableItemSorter());
viewer.setCellEditors(new CellEditor[] {new
TextCellEditor(viewer.getTree())});
viewer.setColumnProperties(new String[] { "name" });
viewer.setCellModifier(new BackupTreeCellModifier());
TreeViewerEditor.create(viewer, new
ColumnViewerEditorActivationStrategy(viewer) {
protected boolean
isEditorActivationEvent(ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
}, ColumnViewerEditor.DEFAULT);
In widgetSelected:
else if (e.getSource() == renameItem) {
if (selection != null) {
BackupTreeCellModifier modifier =
(BackupTreeCellModifier) viewer.getCellModifier();
modifier.allowModify(true);
viewer.editElement(selection.getFirstElement(), 0);
modifier.allowModify(false);
Re: Cell editing in TreeViewer in 3.3 [message #323913 is a reply to message #323912] Sat, 12 January 2008 13:03 Go to previous messageGo to next message
Look at the RenameResourceAction, I think it does what you want.
Marcel wrote:
> Hi folks,
> functioning in 3.2.
> Cheers
> Marcel
> protected boolean
> In widgetSelected:
Re: Cell editing in TreeViewer in 3.3 [message #323914 is a reply to message #323912] Sat, 12 January 2008 13:08 Go to previous messageGo to next message
Marcel schrieb:
> Hi folks,
There was a regression introduced into 3.3 because an editor has been
activated on right click which is wrong.
This is fixed in 3.3.2.
Please provide a snippet so we can reproduce the problem.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Cell editing in TreeViewer in 3.3 [message #323915 is a reply to message #323913] Sat, 12 January 2008 13:11 Go to previous messageGo to next message
Thanks for the suggestion - I could certainly do the rename via a
dialog, standard or not, but I was hoping to stick with the edit in
place approach if possible.
> Marcel wrote:
>> Hi folks,
>> Moving from 3.2 to 3.3 has broken this.
>> called, but modify is not called. On the screen, the user is not given
>> the chance to edit the cell - there is a flash, like a refresh, in
>> which I think the editor is activated and then deactivated (modify is
>> not called as the value hasn't been changed).
>> the event type to isEditorActivated - the whole thing works fine. The
>> only new code for 3.3 is the TreeViewerEditor.create call, the rest
>> was functioning in 3.2.
>> to allow me to programmatically invoke the cell editor? Why does
>> single click editing work, but programmatic invocation result in the
>> editor simply opening and closing?
>> Cheers
>> Marcel
>> protected boolean
>> In widgetSelected:
Re: Cell editing in TreeViewer in 3.3 [message #323919 is a reply to message #323915] Sat, 12 January 2008 15:24 Go to previous messageGo to next message
This action does both a dialog and inline. See the
queryNewResourceNameInline method.
>> Marcel wrote:
>>> Hi folks,
>>> given the chance to edit the cell - there is a flash, like a refresh,
>>> in which I think the editor is activated and then deactivated (modify
>>> is not called as the value hasn't been changed).
>>> Cheers
>>> Marcel
>>> SWT.V_SCROLL);
>>> protected boolean
>>> In widgetSelected:
Re: Cell editing in TreeViewer in 3.3 [message #323920 is a reply to message #323914] Sat, 12 January 2008 18:42 Go to previous messageGo to next message
Tom Schindl wrote:
> Marcel schrieb:
>> Hi folks,
> Tom
Thanks for the help all - I found the problem while putting together a
snippet. I was calling TreeViewer.refresh after the edit call in the
menu selection handler to display the changes after the edit. This was
refreshing the tree and closing the editor.
Marcel
Re: Cell editing in TreeViewer in 3.3 [message #323923 is a reply to message #323920] Sun, 13 January 2008 05:49 Go to previous messageGo to next message
Great, I often encounter this when I ask people to provide a snippet :-)
Tom
Marcel schrieb:
> Tom Schindl wrote:
>> Marcel schrieb:
>>> Hi folks,
>> Tom
> Marcel
Re: Cell editing in TreeViewer in 3.3 [message #323924 is a reply to message #323923] Sun, 13 January 2008 05:51 Go to previous messageGo to next message
> Tom
.... because it seems your snippet is fairly ready would like to
integrate it into our snippet collection?
http://wiki.eclipse.org/JFaceSnippets
Tom
Re: Cell editing in TreeViewer in 3.3 [message #323927 is a reply to message #323924] Sun, 13 January 2008 08:43 Go to previous messageGo to next message
>> Tom
> Tom
If it's useful, please feel free to add it in. The base is from one or
two of your snippets. I've included it below but can send you the file
off list if the formatting gets mangled.
Marcel
import java.util.ArrayList;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.TreeViewerEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TreeItem;
* A simple TreeViewer to demonstrate usage
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class TreeViewerSnippet implements SelectionListener {
private TreeViewer viewer;
private class MyContentProvider implements ITreeContentProvider {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IStructuredContentProvider#getElem ents(java.lang.Object)
public Object[] getElements(Object inputElement) {
return ((MyModel)inputElement).child.toArray();
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#dispose()
public void dispose() {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IContentProvider#inputChanged(org. eclipse.jface.viewers.Viewer,
java.lang.Object, java.lang.Object)
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ITreeContentProvider#getChildren(j ava.lang.Object)
public Object[] getChildren(Object parentElement) {
return getElements(parentElement);
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ITreeContentProvider#getParent(jav a.lang.Object)
public Object getParent(Object element) {
if( element == null) {
return null;
return ((MyModel)element).parent;
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ITreeContentProvider#hasChildren(j ava.lang.Object)
public boolean hasChildren(Object element) {
return ((MyModel)element).child.size() > 0;
public class MyModel {
public MyModel parent;
public ArrayList child = new ArrayList();
public int counter;
public MyModel(int counter, MyModel parent) {
this.parent = parent;
this.counter = counter;
public String toString() {
String rv = "Item ";
if( parent != null ) {
rv = parent.toString() + ".";
rv += counter;
return rv;
public TreeViewerSnippet(Shell shell) {
viewer = new TreeViewer(shell, SWT.BORDER);
viewer.setContentProvider(new MyContentProvider());
viewer.setCellModifier(new ICellModifier() {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ICellModifier#canModify(java.lang. Object,
java.lang.String)
public boolean canModify(Object element, String property) {
return ((MyModel)element).counter % 2 == 0;
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ICellModifier#getValue(java.lang.O bject,
java.lang.String)
public Object getValue(Object element, String property) {
return ((MyModel)element).counter + "";
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.ICellModifier#modify(java.lang.Obj ect,
java.lang.String, java.lang.Object)
public void modify(Object element, String property, Object value) {
TreeItem item = (TreeItem)element;
((MyModel)item.getData()).counter = Integer.parseInt(value.toString());
viewer.update(item.getData(), null);
protected boolean
Menu menu = new Menu(viewer.getControl());
MenuItem renameItem = new MenuItem(menu, SWT.PUSH);
renameItem.addSelectionListener(this);
renameItem.setText("Rename");
viewer.getTree().setMenu(menu);
viewer.setInput(createModel());
public void widgetDefaultSelected(SelectionEvent e) {
public void widgetSelected(SelectionEvent e) {
IStructuredSelection selection = (IStructuredSelection)
viewer.getSelection();
private MyModel createModel() {
MyModel root = new MyModel(0,null);
root.counter = 0;
MyModel tmp;
for( int i = 1; i < 10; i++ ) {
tmp = new MyModel(i, root);
root.child.add(tmp);
for( int j = 1; j < i; j++ ) {
tmp.child.add(new MyModel(j,tmp));
return root;
Display display = new Display ();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new TreeViewerSnippet(shell);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Cell editing in TreeViewer in 3.3 [message #323928 is a reply to message #323927] Sun, 13 January 2008 10:01 Go to previous messageGo to next message
Could you please file a bug against
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
And include the snippet?
Tom
>>> Tom
>> Tom
> Marcel
> import org.eclipse.swt.widgets.Display;
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> /* (non-Javadoc)
> * @see
> newInput) {
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> * @see
> return null;
> /* (non-Javadoc)
> * @see
> public int counter;
> rv += counter;
> return rv;
> /* (non-Javadoc)
> * @see
> java.lang.String)
> /* (non-Javadoc)
> * @see
> java.lang.String)
> /* (non-Javadoc)
> * @see
> value) {
> protected boolean
> root.counter = 0;
> MyModel tmp;
> return root;
> public static void main(String[] args) {
> shell.open ();
> display.dispose ();
Re: Cell editing in TreeViewer in 3.3 [message #323929 is a reply to message #323928] Sun, 13 January 2008 11:13 Go to previous message
Done
> Tom
>>>> Tom
>>> Tom
>> Marcel
>> /* (non-Javadoc)
>> * @see
>> /* (non-Javadoc)
>> /* (non-Javadoc)
>> * @see
>> Object newInput) {
>> /* (non-Javadoc)
>> * @see
>> /* (non-Javadoc)
>> * @see
>> return null;
>> /* (non-Javadoc)
>> * @see
>> public int counter;
>> rv += counter;
>> return rv;
>> /* (non-Javadoc)
>> * @see
>> java.lang.String)
>> /* (non-Javadoc)
>> * @see
>> java.lang.String)
>> /* (non-Javadoc)
>> * @see
>> value) {
>> protected boolean
>> root.counter = 0;
>> MyModel tmp;
>> return root;
>> shell.open ();
>> display.dispose ();
Previous Topic:Editor & CommandStack
Next Topic:Text Editor problem.
Current Time: Fri Nov 21 15:40:44 EST 2025
Powered by FUDForum. Page generated in 0.27889 seconds
