Home » Eclipse Projects » Eclipse Platform » Text Editor problem.
Text Editor problem. [message #323887] Fri, 11 January 2008 03:49 Go to next message
I'm now working on a text editor of my own. The only difference between
my editor and the standard text editor is that the input of my editor is
a string which is built myself( actually, I parse an xml, and make a
string according to the content of the xml).
So, I extended the org.eclipse.ui.editors.text.TextEditor, and the
AbstractDocumentProvider.
In the DocumentProvider class, I only override the createDocument method.
protected IDocument createDocument(Object element) throws CoreException {
if (element instanceof IEditorInput) {
IDocument document= createEmptyDocument();
if (setDocumentContent(document, (IEditorInput) element, null)) { // in
the setDocumentContent method, I only call the document.set() to set //
the content of the document.
return document;
return null;
as of the other method of this class, do nothing special.
And in the editor's class, only called the setDocumentprovider() in the
constructor.
It can now display the string I give to it, but cann't edit (just like
"readonly"), and there is now ruler in the left side even if I chose to
display the line number.
What else should I do to edit the content and to display the ruler in
the side?
Any suggestion is welcome and may be great help to me.
Thanks.
*/Dollyn/*
Re: Text Editor problem. [message #323902 is a reply to message #323887] Fri, 11 January 2008 13:21 Go to previous messageGo to next message
Try providing something like these overrides in your DocumentProvider:
* @see
org.eclipse.ui.texteditor.IDocumentProviderExtension#isModif iable(java.lang.Object)
public boolean isModifiable(Object element) {
if (element instanceof IPathEditorInput) {
IPathEditorInput pei= (IPathEditorInput) element;
File file= pei.getPath().toFile();
return file.canWrite() || !file.exists(); // Allow to edit new files
return false;
* @see
org.eclipse.ui.texteditor.IDocumentProviderExtension#isReadO nly(java.lang.Object)
public boolean isReadOnly(Object element) {
return !isModifiable(element);
Dollyn wrote:
> @Override
> return document;
> return null;
> constructor.
> the side?
> Thanks.
Re: Text Editor problem. [message #323932 is a reply to message #323902] Sun, 13 January 2008 22:03 Go to previous messageGo to next message
Thanks for your help! The content is now editable.
But the line number is still unvisable, even if I select the "show line
number" in the prefereces page.
Is this some thing matter with the document provider? Or, it is just
needed to modify the Editor class?
But I just extended the TextEdotor directly, and the TextEditor can show
the ruler.
By the way, my editor is under a rcp program, I donn't know whether this
is relational.
> * @see
> return false;
> * @see
> Dollyn wrote:
>> @Override
>> return document;
>> return null;
>> constructor.
>> the side?
>> Thanks.
*/Dollyn/*
Re: Text Editor problem. [message #323933 is a reply to message #323932] Sun, 13 January 2008 22:29 Go to previous messageGo to next message
Make sure you subclass from AbstractDecoratedTextEditor, that has the
line number stuff, and it should just work with the preferences.
This will work fine with an RCP app.
> the ruler.
> is relational.
>> * @see
>> return false;
>> * @see
>> Dollyn wrote:
>>> Hi,
>>> @Override
>>> return document;
>>> return null;
>>> constructor.
>>> the side?
>>> Thanks.
Re: Text Editor problem. [message #323934 is a reply to message #323933] Mon, 14 January 2008 00:46 Go to previous messageGo to next message
Yes, I subclass the AbstractDecoratedTextEditor ,and do nothing except
the constructor:
super();
setDocumentProvider();
But the linenumber can not be seen. I checked the TextEditor class, and
find nothing special in it, so I donn't know what else should I do.
>> the ruler.
>> is relational.
>>> * @see
>>> return false;
>>> * @see
>>> Dollyn wrote:
>>>> Hi,
>>>> @Override
>>>> return document;
>>>> return null;
>>>> constructor.
>>>> the side?
>>>> Thanks.
*/Dollyn/*
Re: Text Editor problem. [message #323935 is a reply to message #323933] Mon, 14 January 2008 01:14 Go to previous messageGo to next message
It is the case that there is something wrong with my document provider.
I returned a null in the createAnnotationModel method. And now, I give
it an instance, the line number can be seen now.
It seems that the text editor framwork is somewhat complex to me. :)
>> the ruler.
>> is relational.
>>> * @see
>>> return false;
>>> * @see
>>> Dollyn wrote:
>>>> Hi,
>>>> @Override
>>>> return document;
>>>> return null;
>>>> constructor.
>>>> the side?
>>>> Thanks.
*/Dollyn/*
Re: Text Editor problem. [message #323936 is a reply to message #323935] Mon, 14 January 2008 02:34 Go to previous message
I think it's complex to everyone. Thanks for your discovery and glad
you got it working.
>>> the ruler.
>>> is relational.
>>>> * @see
>>>> return false;
>>>> * @see
>>>> Dollyn wrote:
>>>>> Hi,
>>>>> @Override
>>>>> return document;
>>>>> return null;
>>>>> constructor.
>>>>> the side?
>>>>> Thanks.
Previous Topic:Cell editing in TreeViewer in 3.3
Next Topic:How to handle the white spaces in the file path
Current Time: Sat Jul 12 23:31:49 EDT 2025
Powered by FUDForum. Page generated in 0.05711 seconds
