Contents of plugin.properties not being parsed at runtime. [message #323877] |
Thu, 10 January 2008 15:39  |
Originally posted by: marcio.debarros.gmail.com
I am using Eclipse 3.3.1 and at runtime, all the externalized strings
that I have placed on my plugin.properties file are not being translated.
I could not find anything on the NG, besides doing a eclipse -clean that
could solve my problem.
The file is located in the root of my plug-in, it is also included in
the .bin build.
Externalized strings that are used in the plugin.xml and manifest.MF are
visible through the manifest editor, however I need to close it and
reopen it.
Any ideas or suggestions ?
--MD.
Re: Contents of plugin.properties not being parsed at runtime. [message #323881 is a reply to message #323880] |
Thu, 10 January 2008 15:59  |
Chris Aniszczyk wrote:
>> That did it. What could have caused the MANIFEST.MF to be created
>> without it ?
> I assume you're using Eclipse 3.3
> There was a scenario where if you use the Externalize Strings wizard in
> PDE, it wouldn't add the Bundle-Localization: plugin property to your
> MANIFEST.MF. This was fixed in Eclipse 3.4 along with better error
> detection in case you had externalized strings and were missing that
> header.
> See my blog post for more information :)
> http://mea-bloga.blogspot.com/2007/12/externalizing-strings- with-pde.html
> Cheers,
> ~ Chris
I read the blog, and will keep that in mind moving forward.
Marcio
FUDForum. Page generated in 0.08770 seconds
