Home » Eclipse Projects » Eclipse Platform » Opening an editor without bringing it to top
Opening an editor without bringing it to top [message #323859] Thu, 10 January 2008 10:03 Go to next message
Hey,
is it possible to open an editor but not bringing it to the top. at the
moment i am working around this by saving the current one before opening
and switching back to it after opening, but that is no final solution
since it shows the openend one for some secs which is quite irritating. i
have looked through the Workbenchpage code and as far as i read it it
allways performs a bringtotop for the freshly opened editor. So the
question could also be: "is there another way to open an editor beside via
IWorkbenchpage.openEditor(), which does not bring it to the top?".
thanks in advance
Philipp
Re: Opening an editor without bringing it to top [message #323860 is a reply to message #323859] Thu, 10 January 2008 11:08 Go to previous messageGo to next message
There was a thread or bug on this recently. There is no way to do that.
If it was a bug (searching bugzilla in Eclipse Platform UI would show
it) then it is an enhancement request.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Opening an editor without bringing it to top [message #323862 is a reply to message #323859] Thu, 10 January 2008 12:07 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
have you tried:
openEditor(IEditorInput input, String editorId, boolean activate) throws
PartInitException;
where activate is false?
Philipp Simon wrote:
> Hey,
> i have looked through the Workbenchpage code and as far as i read it it
> via IWorkbenchpage.openEditor(), which does not bring it to the top?".
> thanks in advance
> Philipp
Rich Kulp
Re: Opening an editor without bringing it to top [message #323863 is a reply to message #323862] Thu, 10 January 2008 12:10 Go to previous messageGo to next message
yes i tried that and as allready stated following the sourcecode of
workbenchpage implementation some lines get ommited with activate==false
but bringtotop is somehow allways called. Therefore i guess it wont be
doable via the workbenchpage and i will need another way.
Re: Opening an editor without bringing it to top [message #325556 is a reply to message #323859] Thu, 21 February 2008 17:47 Go to previous message
I am also wondering if this is possible
If you find an answer please let me know
Charles
Previous Topic:Package Explorer Handler
Next Topic:Drag File out a View to Package Explorer
Current Time: Thu Jul 17 17:44:03 EDT 2025
Powered by FUDForum. Page generated in 0.06994 seconds
