Adding stacked views to an existing perspective via "perspectiveExtensions" [message #323831] |
Wed, 09 January 2008 11:55  |
hi I've been trying different ways to add a stack of views to an
existing perspective via the extension point "perspectiveExtensions".
Sounds fairly standard. The problem is that at the location where I'd
like to add the stacked views, there is not an existing view in the
target perspective. So using the extension point I can add the first
view but I can't add any additional views to the same stack since the
extension point requires an existing view, in the original perspective
definition, as the reference point.
I'm pretty sure it is not possible as per the current API but would like
to as if anyone has found a way to do that.
Thanks!
FUDForum. Page generated in 0.25902 seconds
