Home » Eclipse Projects » Eclipse Platform » How to make dynamic object contributions at runtime
How to make dynamic object contributions at runtime [message #323818] Wed, 09 January 2008 09:11 Go to next message
Originally posted by: tas.frangoullides.barclaysglobal.com
Could anyone please give me a quick pointer on how to dynamically
contribute actions to an object menu at runtime.
I am able to contribute a menu called "Connect" by using the
objectContribution elemnt of the org.eclipse.ui.popupMenus extension
point. However I cannot work out how to hook into this menu at runtime and
contribute actions. I cannot statically declare actions using the <action>
element becuase the avialalbe actions are only known at runtime.
Thanks for your help,
Tas
Re: How to make dynamic object contributions at runtime [message #323823 is a reply to message #323818] Wed, 09 January 2008 10:20 Go to previous messageGo to next message
If you own the view you can create the actions at runtime directly into
the menu manaqer.
If you are just trying to make a dynamic object contribution, you can't
do that with the action framework.
With menu contributions/commands you can use org.eclipse.ui.menus to add
a dynamic element to a popup menu, which implements
CompoundContributionItem.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to make dynamic object contributions at runtime [message #323826 is a reply to message #323823] Wed, 09 January 2008 10:59 Go to previous messageGo to next message
Paul,
Thanks for helping out.
I don't own the view. I want this menu anytime an object of a particular
class is right clicked. I've had a look at the org.eclipse.ui.menus
extension point but I can't see where to hook in the dynamic menu
creation. Where is a CompundContributionItem hooked in?
Thanks again,
Tas
Re: How to make dynamic object contributions at runtime [message #323835 is a reply to message #323826] Wed, 09 January 2008 12:27 Go to previous messageGo to next message
Check out the example matrix off of
http://wiki.eclipse.org/Menu_Contributions especially the 2 for problems
view.
PW
Paul Webster
Re: How to make dynamic object contributions at runtime [message #323854 is a reply to message #323835] Thu, 10 January 2008 09:01 Go to previous message
I'm with you now. I was using Eclipse 3.2 and couldn't see the elements.
Thanks very much for your help.
Tas
Previous Topic:ResourceBundle located in another Plugin without Classes
Next Topic:Avoid flooding the SWT UI Thread. alternative to jface.deferred
Current Time: Wed Jul 16 14:39:31 EDT 2025
Powered by FUDForum. Page generated in 0.03976 seconds
