Home » Modeling » GMF (Graphical Modeling Framework) » To seperate out the code for the new diagram file creation and the GMF part
To seperate out the code for the new diagram file creation and the GMF part [message #32765] Tue, 29 August 2006 09:19 Go to next message
Originally posted by: naveen.venkatesh.flextronicssoftware.com
Hi All,
I want to seperate out the code for the new file creation and the GMF part.
To be more specific i want to make the new file creation wizard
independent of the
GMF projects.
For instance, if i have two GMF projects
1) Mindmap
2) Library
I should be able to create diagram files for both Mindmap and Library
using the same wizard.
To explain it further..
1) I have both these examples as plugin projects in my workspace
2) I start the runtime eclipse window.
3) Now select file->new->other--Mindmap
--Library
4) By default the entry points for these plugins are as given above
and from there when u select either of the examples individual plugins
will be launched which will have its own new file creation wizard code to
accept
the diagram name and then creates the diagram.
I want to seperate out this wizard code for creating the diagram file
and make it reusable for both of these examples.
my requirement looks something like this
1)I will extend my wizard from org.eclipse.ui.newWizards extension point.
It would look something like this.
file->new--Mindmap
--Library.
2) Now when i select either of the two ie., mindmap/library the same
wizard should be
invoked and based on the selection the wizard should create the respective
diagram file.
Pls let me know your suggestion to achieve the same.
Re: To seperate out the code for the new diagram file creation and the GMF part [message #33972 is a reply to message #32765] Wed, 30 August 2006 07:49 Go to previous message
Originally posted by: 5d5.mail.ru
Hello!
You could write and register your own wizard that will reuse generated
wizard parts. I'm just curious - why do you need this?
Naveen wrote:
> Hi All,
> independent of the GMF projects.
> For instance, if i have two GMF projects 1) Mindmap
> 2) Library
> --Library
> to accept the diagram name and then creates the diagram.
> file->new--Mindmap
> --Library.
> wizard should be
> respective diagram file.
Previous Topic:how to create two linked element in a diagram related to a single element in the model
Next Topic:Linking multiple files together
Current Time: Sun May 11 16:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.05009 seconds
