Home » Eclipse Projects » Eclipse Platform » Creating a new Resource Marker
Creating a new Resource Marker [message #323706] Mon, 07 January 2008 02:46 Go to next message
I am trying to create a new Resource marker and view the same in Problems
View.
I have defined the marker in my plugin .xml as
<extension
id="docproblem"
name="Javadoc Problem"
point="org.eclipse.core.resources.markers">
<super type="org.eclipse.core.resources.problemmarker"/>
<super type="com.iflex.fcr.tools.plugin.flexcubeapi"/>
<persistent value="false"/>
<attribute name="operation"/>
</extension>
IMarker marker = resource.createMarker(“XXXXXX”);
Can anyone please tell me what should I use in the place of “XXXXXX”??
Re: Creating a new Resource Marker [message #323709 is a reply to message #323706] Mon, 07 January 2008 04:48 Go to previous messageGo to next message
Vallabh,
You'd use "<plugin-id>.docproblem" where plugin-id is (not surprisingly)
the ID of the plugin that contains the plugin.xml below. BTW, is
"com.iflex.fcr.tools.plugin.flexcubeapi" the ID of another registered
marker type?
> Problems View.
> <extension
> id="docproblem"
> </extension>
> IMarker marker = resource.createMarker(�XXXXXX�);
> Can anyone please tell me what should I use in the place of �XXXXXX�??
Re: Creating a new Resource Marker [message #323711 is a reply to message #323709] Mon, 07 January 2008 05:21 Go to previous messageGo to next message
thanks a lot for your reply.
No you can ignore the
<super type="com.iflex.fcr.tools.plugin.flexcubeapi"/> It has no
significance in this context.
Re: Creating a new Resource Marker [message #323712 is a reply to message #323706] Mon, 07 January 2008 05:24 Go to previous messageGo to next message
> View.
> <extension
> id="docproblem"
> </extension>
Thanks a lot for ur valuable reply.
You can ignore the other super tag. It has no significance in this context.
REgards,
Re: Creating a new Resource Marker [message #323714 is a reply to message #323709] Mon, 07 January 2008 05:26 Go to previous message
thanks a lot for your valuable reply.
No you can ignore the "com.iflex.fcr.tools.plugin.flexcubeapi" it has not
significance.
Previous Topic:Mac OS X specific problem reading @WebService annotation
Next Topic:Using Reflect API in JDT
Current Time: Wed Jul 16 05:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.03611 seconds
