Home » Eclipse Projects » Eclipse Platform » Mac OS X specific problem reading @WebService annotation
Mac OS X specific problem reading @WebService annotation [message #323697] Sun, 06 January 2008 11:35
--RUMwRitYQ3lvcStGMlZ5WQAAAAI=
Content-Type: text/plain
My Eclipse application depends on communicating with a server via web
services. I use standard annotations in the classes. This has been
working for a long time under both Win XP and Linux without issue. I
am now trying to get the application running on OS X 10.5 (Leopard)
and I have ran into a problem.
On OS X I get a RuntimeModelerException "A WebService annotation is
not present on class: com.etish.useme.est.webservices.server.Server"
when running inside Eclipse.
Well the class in questions is annotated. In fact I have a mock client
I use for testing the server code which exercises the same call from
the command line and it works perfectly.
I have ran this through the debugger and it appears that the class in
question does *not* have annotations. At least the annotations field
on the interface inside the debugger indicates a size=0 and keyset is
null.
There is no chance of a bad copy being loaded as only one copy exists
in the workspace and as I said the exact same artifacts are used to
launch the tests as a java program.
I have attached a stacktrace.
I would be very grateful for any suggestion on where to go with
solving this.
Many thanks,
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Tool
====w=w==== [https://useme.dev.java.net]
Content-Type: text/html
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head><meta content="text/html;charset=us-ascii ;" http-equiv="content-type"></head><body><pre><span style="font-family:Courier New ;">My Eclipse application depends on communicating with a server via web
null.
solving this.
Many thanks,
Joel
</span> <a href=" cid:84546A99-5901-469C-B3A2-445936FCC55A-189-000004A65F07E67 F ">stacktrace.txt</a><br><pre>--
Joel Rosi-Schwartz
</pre></span></body></html>
Content-Disposition: attachment; filename=stacktrace.txt
Content-Type: application/octet-stream; name=stacktrace.txt
Content-Id: <84546A99-5901-469C-B3A2-445936FCC55A-189-000004A65F07E67F>
Q29uZmlndXJhdGlvbiBsb2NhdGlvbjoKICAgIGZpbGU6L1VzZXJzL2pvZWwv cHJvamVjdHMvRXRp
c2gtMzMxLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5wZGUuY29y ZS9Vc2VNZSBFZGl0
b3IgZm9yIE9TWC8KQ29uZmlndXJhdGlvbiBmaWxlOgogICAgZmlsZTovVXNl cnMvam9lbC9wcm9q
ZWN0cy9FdGlzaC0zMzEvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LnBkZS5jb3JlL1Vz
ZU1lIEVkaXRvciBmb3IgT1NYL2NvbmZpZy5pbmkgbG9hZGVkCkluc3RhbGwg bG9jYXRpb246CiAg
ICBmaWxlOi9BcHBsaWNhdGlvbnMvZWNsaXBzZS8KRnJhbWV3b3JrIGxvY2F0 ZWQ6CiAgICBmaWxl
Oi9BcHBsaWNhdGlvbnMvZWNsaXBzZS9wbHVnaW5zL29yZy5lY2xpcHNlLm9z Z2lfMy4zLjEuUjMz
eF92MjAwNzA4MjguamFyCkZyYW1ld29yayBjbGFzc3BhdGg6CiAgICBmaWxl Oi9BcHBsaWNhdGlv
bnMvZWNsaXBzZS9wbHVnaW5zL29yZy5lY2xpcHNlLm9zZ2lfMy4zLjEuUjMz eF92MjAwNzA4Mjgu
amFyClNwbGFzaCBsb2NhdGlvbjoKICAgIC9BcHBsaWNhdGlvbnMvZWNsaXBz ZS9wbHVnaW5zL29y
Zy5lY2xpcHNlLnBsYXRmb3JtXzMuMy4yLlIzM3hfdjIwMDcxMDIyL3NwbGFz aC5ibXAKRGVidWcg
b3B0aW9uczoKICAgIGZpbGU6L0FwcGxpY2F0aW9ucy9lY2xpcHNlL0VjbGlw c2UuYXBwL0NvbnRl
bnRzL01hY09TL2M6L3Byb2plY3RzL0V0aXNoLXJ1bnRpbWUvb3B0aW9ucyBu b3QgZm91bmQKVGlt
ZSB0byBsb2FkIGJ1bmRsZXM6IDQ2ClN0YXJ0aW5nIGFwcGxpY2F0aW9uOiAx MzI0CkFwcGxpY2F0
aW9uIFN0YXJ0ZWQ6IDQzMTgKY29tLmV0aXNoLnVzZW1lLmNsaWVudC5iYXNl LmNvcmUuY29tbW9u
LmV4Y2VwdGlvbnMuRnJhbWV3b3JrRXhjZXB0aW9uOiBGYWlsZWQgdG8gY29t bXVuaWNhdGUgd2l0
aCBzZXJ2aWNlIFthXSBhdCBbbG9jYWxob3N0OjQ4MDgwXS4gUGxlYXNlIHRy eSBhZ2FpbiBsYXRl
ci4gSWYgdGhlIHByb2JsZW0gcGVyc2lzdHMgY29udGFjdCB5b3VyIHN5c3Rl bSBhZG1pbmlzdHJh
dG9yLgoJYXQgY29tLmV0aXNoLnVzZW1lLmNsaWVudC5iYXNlLmNvcmUuc2Vy dmljZXMuU2VydmVy
RGVsZWdhdGUuZ2V0QWdlbnQoU2VydmVyRGVsZWdhdGUuamF2YToyMTkpCglh dCBjb20uZXRpc2gu
dXNlbWUuY2xpZW50LmJhc2UuY29yZS5zZXJ2aWNlcy5TZXJ2ZXJEZWxlZ2F0 ZS52YWxpZGF0ZShT
ZXJ2ZXJEZWxlZ2F0ZS5qYXZhOjcxNykKCWF0IGNvbS5ldGlzaC51c2VtZS5j bGllbnQuYmFzZS5j
b3JlLnNlcnZpY2VzLlNlcnZlckxpYWlzb24uYWRkU2VydmVyTG9jYXRpb24o U2VydmVyTGlhaXNv
bi5qYXZhOjEyMikKCWF0IGNvbS5ldGlzaC51c2VtZS5jbGllbnQuZWRpdG9y LnVpLndpemFyZHMu
c2VydmVybG9jYXRpb24uU2VydmVyTG9jYXRpb25XaXphcmQuYWRkTG9jYXRp b24oU2VydmVyTG9j
YXRpb25XaXphcmQuamF2YTo5MCkKCWF0IGNvbS5ldGlzaC51c2VtZS5jbGll bnQuZWRpdG9yLnVp
LndpemFyZHMuc2VydmVybG9jYXRpb24uU2VydmVyTG9jYXRpb25XaXphcmQu cGVyZm9ybUZpbmlz
aChTZXJ2ZXJMb2NhdGlvbldpemFyZC5qYXZhOjE3NykKCWF0IG9yZy5lY2xp cHNlLmpmYWNlLndp
emFyZC5XaXphcmREaWFsb2cuZmluaXNoUHJlc3NlZChXaXphcmREaWFsb2cu amF2YTo3NDIpCglh
dCBvcmcuZWNsaXBzZS5qZmFjZS53aXphcmQuV2l6YXJkRGlhbG9nLmJ1dHRv blByZXNzZWQoV2l6
YXJkRGlhbG9nLmphdmE6MzczKQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuZGlh bG9ncy5EaWFsb2ck
Mi53aWRnZXRTZWxlY3RlZChEaWFsb2cuamF2YTo2MTYpCglhdCBvcmcuZWNs aXBzZS5zd3Qud2lk
Z2V0cy5UeXBlZExpc3RlbmVyLmhhbmRsZUV2ZW50KFR5cGVkTGlzdGVuZXIu amF2YToyMjcpCglh
dCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5FdmVudFRhYmxlLnNlbmRFdmVu dChFdmVudFRhYmxl
LmphdmE6NjYpCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5XaWRnZXQu c2VuZEV2ZW50KFdp
ZGdldC5qYXZhOjE0OTUpCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5X aWRnZXQuc2VuZEV2
ZW50KFdpZGdldC5qYXZhOjE1MTkpCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lk Z2V0cy5XaWRnZXQu
c2VuZEV2ZW50KFdpZGdldC5qYXZhOjE1MDQpCglhdCBvcmcuZWNsaXBzZS5z d3Qud2lkZ2V0cy5X
aWRnZXQubm90aWZ5TGlzdGVuZXJzKFdpZGdldC5qYXZhOjEyOTUpCglhdCBv cmcuZWNsaXBzZS5z
d3Qud2lkZ2V0cy5EaXNwbGF5LnJ1bkRlZmVycmVkRXZlbnRzKERpc3BsYXku amF2YTozMzUwKQoJ
YXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFkQW5kRGlz cGF0Y2goRGlzcGxh
eS5qYXZhOjI5NTQpCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53aW5kb3cuV2lu ZG93LnJ1bkV2ZW50
TG9vcChXaW5kb3cuamF2YTo4MjApCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53 aW5kb3cuV2luZG93
Lm9wZW4oV2luZG93LmphdmE6Nzk2KQoJYXQgb3JnLmVjbGlwc2UudWkuYWN0 aW9ucy5OZXdXaXph
cmRBY3Rpb24ucnVuKE5ld1dpemFyZEFjdGlvbi5qYXZhOjE4MikKCWF0IG9y Zy5lY2xpcHNlLnVp
LmFjdGlvbnMuTmV3V2l6YXJkRHJvcERvd25BY3Rpb24ucnVuKE5ld1dpemFy ZERyb3BEb3duQWN0
aW9uLmphdmE6MTc0KQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFj dGlvbi5ydW5XaXRo
RXZlbnQoQWN0aW9uLmphdmE6NDk4KQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uu YWN0aW9uLkFjdGlv
bkNvbnRyaWJ1dGlvbkl0ZW0uaGFuZGxlV2lkZ2V0U2VsZWN0aW9uKEFjdGlv bkNvbnRyaWJ1dGlv
bkl0ZW0uamF2YTo1NDYpCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5hY3Rpb24u QWN0aW9uQ29udHJp
YnV0aW9uSXRlbS5hY2Nlc3MkMihBY3Rpb25Db250cmlidXRpb25JdGVtLmph dmE6NDkwKQoJYXQg
b3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbkNvbnRyaWJ1dGlvbkl0 ZW0kNi5oYW5kbGVF
dmVudChBY3Rpb25Db250cmlidXRpb25JdGVtLmphdmE6NDQzKQoJYXQgb3Jn LmVjbGlwc2Uuc3d0
LndpZGdldHMuRXZlbnRUYWJsZS5zZW5kRXZlbnQoRXZlbnRUYWJsZS5qYXZh OjY2KQoJYXQgb3Jn
LmVjbGlwc2Uuc3d0LndpZGdldHMuV2lkZ2V0LnNlbmRFdmVudChXaWRnZXQu amF2YToxNDk1KQoJ
YXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuV2lkZ2V0LnNlbmRFdmVudChX aWRnZXQuamF2YTox
NTE5KQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuV2lkZ2V0LnNlbmRF dmVudChXaWRnZXQu
amF2YToxNTA0KQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuV2lkZ2V0 Lm5vdGlmeUxpc3Rl
bmVycyhXaWRnZXQuamF2YToxMjk1KQoJYXQgb3JnLmVjbGlwc2Uuc3d0Lndp ZGdldHMuRGlzcGxh
eS5ydW5EZWZlcnJlZEV2ZW50cyhEaXNwbGF5LmphdmE6MzM1MCkKCWF0IG9y Zy5lY2xpcHNlLnN3
dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERpc3BsYXkuamF2 YToyOTU0KQoJYXQg
b3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoLnJ1bkV2ZW50TG9v cChXb3JrYmVuY2gu
amF2YToyMzg5KQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2Jl bmNoLnJ1blVJKFdv
cmtiZW5jaC5qYXZhOjIzNTMpCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5h bC5Xb3JrYmVuY2gu
YWNjZXNzJDQoV29ya2JlbmNoLmphdmE6MjIxOSkKCWF0IG9yZy5lY2xpcHNl LnVpLmludGVybmFs
LldvcmtiZW5jaCQ0LnJ1bihXb3JrYmVuY2guamF2YTo0NjYpCglhdCBvcmcu ZWNsaXBzZS5jb3Jl
LmRhdGFiaW5kaW5nLm9ic2VydmFibGUuUmVhbG0ucnVuV2l0aERlZmF1bHQo UmVhbG0uamF2YToy
ODkpCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2guY3Jl YXRlQW5kUnVuV29y
a2JlbmNoKFdvcmtiZW5jaC5qYXZhOjQ2MSkKCWF0IG9yZy5lY2xpcHNlLnVp LlBsYXRmb3JtVUku
Y3JlYXRlQW5kUnVuV29ya2JlbmNoKFBsYXRmb3JtVUkuamF2YToxNDkpCglh dCBvcmcuZWNsaXBz
ZS51aS5pbnRlcm5hbC5pZGUuYXBwbGljYXRpb24uSURFQXBwbGljYXRpb24u c3RhcnQoSURFQXBw
bGljYXRpb24uamF2YToxMDYpCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94Lmlu dGVybmFsLmFwcC5F
Y2xpcHNlQXBwSGFuZGxlLnJ1bihFY2xpcHNlQXBwSGFuZGxlLmphdmE6MTY5 KQoJYXQgb3JnLmVj
bGlwc2UuY29yZS5ydW50aW1lLmludGVybmFsLmFkYXB0b3IuRWNsaXBzZUFw cExhdW5jaGVyLnJ1
bkFwcGxpY2F0aW9uKEVjbGlwc2VBcHBMYXVuY2hlci5qYXZhOjEwNikKCWF0 IG9yZy5lY2xpcHNl
LmNvcmUucnVudGltZS5pbnRlcm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVu Y2hlci5zdGFydChF
Y2xpcHNlQXBwTGF1bmNoZXIuamF2YTo3NikKCWF0IG9yZy5lY2xpcHNlLmNv cmUucnVudGltZS5h
ZGFwdG9yLkVjbGlwc2VTdGFydGVyLnJ1bihFY2xpcHNlU3RhcnRlci5qYXZh OjM2MykKCWF0IG9y
Zy5lY2xpcHNlLmNvcmUucnVudGltZS5hZGFwdG9yLkVjbGlwc2VTdGFydGVy LnJ1bihFY2xpcHNl
U3RhcnRlci5qYXZhOjE3NikKCWF0IHN1bi5yZWZsZWN0Lk5hdGl2ZU1ldGhv ZEFjY2Vzc29ySW1w
bC5pbnZva2UwKE5hdGl2ZSBNZXRob2QpCglhdCBzdW4ucmVmbGVjdC5OYXRp dmVNZXRob2RBY2Nl
c3NvckltcGwuaW52b2tlKE5hdGl2ZU1ldGhvZEFjY2Vzc29ySW1wbC5qYXZh OjM5KQoJYXQgc3Vu
LnJlZmxlY3QuRGVsZWdhdGluZ01ldGhvZEFjY2Vzc29ySW1wbC5pbnZva2Uo RGVsZWdhdGluZ01l
dGhvZEFjY2Vzc29ySW1wbC5qYXZhOjI1KQoJYXQgamF2YS5sYW5nLnJlZmxl Y3QuTWV0aG9kLmlu
dm9rZShNZXRob2QuamF2YTo1ODUpCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94 LmxhdW5jaGVyLk1h
aW4uaW52b2tlRnJhbWV3b3JrKE1haW4uamF2YTo1MDgpCglhdCBvcmcuZWNs aXBzZS5lcXVpbm94
LmxhdW5jaGVyLk1haW4uYmFzaWNSdW4oTWFpbi5qYXZhOjQ0NykKCWF0IG9y Zy5lY2xpcHNlLmVx
dWlub3gubGF1bmNoZXIuTWFpbi5ydW4oTWFpbi5qYXZhOjExNzMpCglhdCBv cmcuZWNsaXBzZS5l
cXVpbm94LmxhdW5jaGVyLk1haW4ubWFpbihNYWluLmphdmE6MTE0OCkKY29t LmV0aXNoLnVzZW1l
LmNsaWVudC5iYXNlLmNvcmUuY29tbW9uLmV4Y2VwdGlvbnMuRnJhbWV3b3Jr RXhjZXB0aW9uWzJd
OiBBIFdlYlNlcnZpY2UgYW5ub3RhdGlvbiBpcyBub3QgcHJlc2VudCBvbiBj bGFzczogY29tLmV0
aXNoLnVzZW1lLmVzdC53ZWJzZXJ2aWNlcy5zZXJ2ZXIuU2VydmVyCglhdCBj b20uc3VuLnhtbC53
cy5tb2RlbGVyLlJ1bnRpbWVNb2RlbGVyLmdldFBvcnRUeXBlTmFtZShSdW50 aW1lTW9kZWxlci5q
YXZhOjEyODEpCglhdCBjb20uc3VuLnhtbC53cy5jbGllbnQuU2VydmljZUNv bnRleHRCdWlsZGVy
LnByb2Nlc3NBbm5vdGF0aW9ucyhTZXJ2aWNlQ29udGV4dEJ1aWxkZXIuamF2 YToxMDYpCglhdCBj
b20uc3VuLnhtbC53cy5jbGllbnQuU2VydmljZUNvbnRleHRCdWlsZGVyLmNv bXBsZXRlU2Vydmlj
ZUNvbnRleHQoU2VydmljZUNvbnRleHRCdWlsZGVyLmphdmE6ODcpCglhdCBj b20uc3VuLnhtbC53
cy5jbGllbnQuV1NTZXJ2aWNlRGVsZWdhdGUucHJvY2Vzc1NlcnZpY2VDb250 ZXh0KFdTU2Vydmlj
ZURlbGVnYXRlLmphdmE6MTMzKQoJYXQgY29tLnN1bi54bWwud3MuY2xpZW50 LldTU2VydmljZURl
bGVnYXRlLmNyZWF0ZUVuZHBvaW50SUZCYXNlUHJveHkoV1NTZXJ2aWNlRGVs ZWdhdGUuamF2YToy
ODQpCglhdCBjb20uc3VuLnhtbC53cy5jbGllbnQuV1NTZXJ2aWNlRGVsZWdh dGUuZ2V0UG9ydChX
U1NlcnZpY2VEZWxlZ2F0ZS5qYXZhOjE4MCkKCWF0IGphdmF4LnhtbC53cy5T ZXJ2aWNlLmdldFBv
cnQoU2VydmljZS5qYXZhOjEyMCkKCWF0IGNvbS5ldGlzaC51c2VtZS5jbGll bnQuYmFzZS5jb3Jl
LnNlcnZpY2VzLlNlcnZlckRlbGVnYXRlLmdldEFnZW50KFNlcnZlckRlbGVn YXRlLmphdmE6MjEy
KQoJYXQgY29tLmV0aXNoLnVzZW1lLmNsaWVudC5iYXNlLmNvcmUuc2Vydmlj ZXMuU2VydmVyRGVs
ZWdhdGUudmFsaWRhdGUoU2VydmVyRGVsZWdhdGUuamF2YTo3MTcpCglhdCBj b20uZXRpc2gudXNl
bWUuY2xpZW50LmJhc2UuY29yZS5zZXJ2aWNlcy5TZXJ2ZXJMaWFpc29uLmFk ZFNlcnZlckxvY2F0
aW9uKFNlcnZlckxpYWlzb24uamF2YToxMjIpCglhdCBjb20uZXRpc2gudXNl bWUuY2xpZW50LmVk
aXRvci51aS53aXphcmRzLnNlcnZlcmxvY2F0aW9uLlNlcnZlckxvY2F0aW9u V2l6YXJkLmFkZExv
Y2F0aW9uKFNlcnZlckxvY2F0aW9uV2l6YXJkLmphdmE6OTApCglhdCBjb20u ZXRpc2gudXNlbWUu
Y2xpZW50LmVkaXRvci51aS53aXphcmRzLnNlcnZlcmxvY2F0aW9uLlNlcnZl ckxvY2F0aW9uV2l6
YXJkLnBlcmZvcm1GaW5pc2goU2VydmVyTG9jYXRpb25XaXphcmQuamF2YTox NzcpCglhdCBvcmcu
ZWNsaXBzZS5qZmFjZS53aXphcmQuV2l6YXJkRGlhbG9nLmZpbmlzaFByZXNz ZWQoV2l6YXJkRGlh
bG9nLmphdmE6NzQyKQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uud2l6YXJkLldp emFyZERpYWxvZy5i
dXR0b25QcmVzc2VkKFdpemFyZERpYWxvZy5qYXZhOjM3MykKCWF0IG9yZy5l Y2xpcHNlLmpmYWNl
LmRpYWxvZ3MuRGlhbG9nJDIud2lkZ2V0U2VsZWN0ZWQoRGlhbG9nLmphdmE6 NjE2KQoJYXQgb3Jn
LmVjbGlwc2Uuc3d0LndpZGdldHMuVHlwZWRMaXN0ZW5lci5oYW5kbGVFdmVu dChUeXBlZExpc3Rl
bmVyLmphdmE6MjI3KQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRXZl bnRUYWJsZS5zZW5k
RXZlbnQoRXZlbnRUYWJsZS5qYXZhOjY2KQoJYXQgb3JnLmVjbGlwc2Uuc3d0 LndpZGdldHMuV2lk
Z2V0LnNlbmRFdmVudChXaWRnZXQuamF2YToxNDk1KQoJYXQgb3JnLmVjbGlw c2Uuc3d0LndpZGdl
dHMuV2lkZ2V0LnNlbmRFdmVudChXaWRnZXQuamF2YToxNTE5KQoJYXQgb3Jn LmVjbGlwc2Uuc3d0
LndpZGdldHMuV2lkZ2V0LnNlbmRFdmVudChXaWRnZXQuamF2YToxNTA0KQoJ YXQgb3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuV2lkZ2V0Lm5vdGlmeUxpc3RlbmVycyhXaWRnZXQu amF2YToxMjk1KQoJ
YXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5ydW5EZWZlcnJl ZEV2ZW50cyhEaXNw
bGF5LmphdmE6MzM1MCkKCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkRp c3BsYXkucmVhZEFu
ZERpc3BhdGNoKERpc3BsYXkuamF2YToyOTU0KQoJYXQgb3JnLmVjbGlwc2Uu amZhY2Uud2luZG93
LldpbmRvdy5ydW5FdmVudExvb3AoV2luZG93LmphdmE6ODIwKQoJYXQgb3Jn LmVjbGlwc2UuamZh
Y2Uud2luZG93LldpbmRvdy5vcGVuKFdpbmRvdy5qYXZhOjc5NikKCWF0IG9y Zy5lY2xpcHNlLnVp
LmFjdGlvbnMuTmV3V2l6YXJkQWN0aW9uLnJ1bihOZXdXaXphcmRBY3Rpb24u amF2YToxODIpCglh
dCBvcmcuZWNsaXBzZS51aS5hY3Rpb25zLk5ld1dpemFyZERyb3BEb3duQWN0 aW9uLnJ1bihOZXdX
aXphcmREcm9wRG93bkFjdGlvbi5qYXZhOjE3NCkKCWF0IG9yZy5lY2xpcHNl LmpmYWNlLmFjdGlv
bi5BY3Rpb24ucnVuV2l0aEV2ZW50KEFjdGlvbi5qYXZhOjQ5OCkKCWF0IG9y Zy5lY2xpcHNlLmpm
YWNlLmFjdGlvbi5BY3Rpb25Db250cmlidXRpb25JdGVtLmhhbmRsZVdpZGdl dFNlbGVjdGlvbihB
Y3Rpb25Db250cmlidXRpb25JdGVtLmphdmE6NTQ2KQoJYXQgb3JnLmVjbGlw c2UuamZhY2UuYWN0
aW9uLkFjdGlvbkNvbnRyaWJ1dGlvbkl0ZW0uYWNjZXNzJDIoQWN0aW9uQ29u dHJpYnV0aW9uSXRl
bS5qYXZhOjQ5MCkKCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmFjdGlvbi5BY3Rp b25Db250cmlidXRp
b25JdGVtJDYuaGFuZGxlRXZlbnQoQWN0aW9uQ29udHJpYnV0aW9uSXRlbS5q YXZhOjQ0MykKCWF0
IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkV2ZW50VGFibGUuc2VuZEV2ZW50 KEV2ZW50VGFibGUu
amF2YTo2NikKCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldpZGdldC5z ZW5kRXZlbnQoV2lk
Z2V0LmphdmE6MTQ5NSkKCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldp ZGdldC5zZW5kRXZl
bnQoV2lkZ2V0LmphdmE6MTUxOSkKCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLldpZGdldC5z
ZW5kRXZlbnQoV2lkZ2V0LmphdmE6MTUwNCkKCWF0IG9yZy5lY2xpcHNlLnN3 dC53aWRnZXRzLldp
ZGdldC5ub3RpZnlMaXN0ZW5lcnMoV2lkZ2V0LmphdmE6MTI5NSkKCWF0IG9y Zy5lY2xpcHNlLnN3
dC53aWRnZXRzLkRpc3BsYXkucnVuRGVmZXJyZWRFdmVudHMoRGlzcGxheS5q YXZhOjMzNTApCglh
dCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EaXNwbGF5LnJlYWRBbmREaXNw YXRjaChEaXNwbGF5
LmphdmE6Mjk1NCkKCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmti ZW5jaC5ydW5FdmVu
dExvb3AoV29ya2JlbmNoLmphdmE6MjM4OSkKCWF0IG9yZy5lY2xpcHNlLnVp LmludGVybmFsLldv
cmtiZW5jaC5ydW5VSShXb3JrYmVuY2guamF2YToyMzUzKQoJYXQgb3JnLmVj bGlwc2UudWkuaW50
ZXJuYWwuV29ya2JlbmNoLmFjY2VzcyQ0KFdvcmtiZW5jaC5qYXZhOjIyMTkp CglhdCBvcmcuZWNs
aXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2gkNC5ydW4oV29ya2JlbmNoLmph dmE6NDY2KQoJYXQg
b3JnLmVjbGlwc2UuY29yZS5kYXRhYmluZGluZy5vYnNlcnZhYmxlLlJlYWxt LnJ1bldpdGhEZWZh
dWx0KFJlYWxtLmphdmE6Mjg5KQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJu YWwuV29ya2JlbmNo
LmNyZWF0ZUFuZFJ1bldvcmtiZW5jaChXb3JrYmVuY2guamF2YTo0NjEpCglh dCBvcmcuZWNsaXBz
ZS51aS5QbGF0Zm9ybVVJLmNyZWF0ZUFuZFJ1bldvcmtiZW5jaChQbGF0Zm9y bVVJLmphdmE6MTQ5
KQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuaWRlLmFwcGxpY2F0aW9u LklERUFwcGxpY2F0
aW9uLnN0YXJ0KElERUFwcGxpY2F0aW9uLmphdmE6MTA2KQoJYXQgb3JnLmVj bGlwc2UuZXF1aW5v
eC5pbnRlcm5hbC5hcHAuRWNsaXBzZUFwcEhhbmRsZS5ydW4oRWNsaXBzZUFw cEhhbmRsZS5qYXZh
OjE2OSkKCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5pbnRlcm5hbC5h ZGFwdG9yLkVjbGlw
c2VBcHBMYXVuY2hlci5ydW5BcHBsaWNhdGlvbihFY2xpcHNlQXBwTGF1bmNo ZXIuamF2YToxMDYp
CglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuaW50ZXJuYWwuYWRhcHRv ci5FY2xpcHNlQXBw
TGF1bmNoZXIuc3RhcnQoRWNsaXBzZUFwcExhdW5jaGVyLmphdmE6NzYpCglh dCBvcmcuZWNsaXBz
ZS5jb3JlLnJ1bnRpbWUuYWRhcHRvci5FY2xpcHNlU3RhcnRlci5ydW4oRWNs aXBzZVN0YXJ0ZXIu
amF2YTozNjMpCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuYWRhcHRv ci5FY2xpcHNlU3Rh
cnRlci5ydW4oRWNsaXBzZVN0YXJ0ZXIuamF2YToxNzYpCglhdCBzdW4ucmVm bGVjdC5OYXRpdmVN
ZXRob2RBY2Nlc3NvckltcGwuaW52b2tlMChOYXRpdmUgTWV0aG9kKQoJYXQg c3VuLnJlZmxlY3Qu
TmF0aXZlTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZShOYXRpdmVNZXRob2RB Y2Nlc3NvckltcGwu
amF2YTozOSkKCWF0IHN1bi5yZWZsZWN0LkRlbGVnYXRpbmdNZXRob2RBY2Nl c3NvckltcGwuaW52
b2tlKERlbGVnYXRpbmdNZXRob2RBY2Nlc3NvckltcGwuamF2YToyNSkKCWF0 IGphdmEubGFuZy5y
ZWZsZWN0Lk1ldGhvZC5pbnZva2UoTWV0aG9kLmphdmE6NTg1KQoJYXQgb3Jn LmVjbGlwc2UuZXF1
aW5veC5sYXVuY2hlci5NYWluLmludm9rZUZyYW1ld29yayhNYWluLmphdmE6 NTA4KQoJYXQgb3Jn
LmVjbGlwc2UuZXF1aW5veC5sYXVuY2hlci5NYWluLmJhc2ljUnVuKE1haW4u amF2YTo0NDcpCglh
dCBvcmcuZWNsaXBzZS5lcXVpbm94LmxhdW5jaGVyLk1haW4ucnVuKE1haW4u amF2YToxMTczKQoJ
YXQgb3JnLmVjbGlwc2UuZXF1aW5veC5sYXVuY2hlci5NYWluLm1haW4oTWFp bi5qYXZhOjExNDgp
Cg==
--RUMwRitYQ3lvcStGMlZ5WQAAAAI=--
Previous Topic:Mac OS X specific problem reading @WebService annotation
Next Topic:Creating a new Resource Marker
Current Time: Wed Jul 16 06:24:03 EDT 2025
Powered by FUDForum. Page generated in 0.28874 seconds
