Home » Eclipse Projects » Eclipse Platform » java.lang.reflect.InvocationTargetException when Opening Editor
java.lang.reflect.InvocationTargetException when Opening Editor [message #323674] Sat, 05 January 2008 04:02 Go to next message
I encounter the below exception when opening an editor.
In my RCP application a current navigation is
opening an editor E1
From this editor : close E1; open E2
From E2 ; close E2; open E3;
From E3 : close E3; open E1.
... and so on.
The exception doesn't come immediatly, but after N (10, 15 ?) such close
/ open executions.
I suspect a resource / memory problem but have no elements with this
exception to track it.
Any idea ?
Thanks in advance.
Richard
My code to open and close Editors
avec
iEditorInput extends org.eclipse.ui.IEditorInput
twActionOpenEditor extends org.eclipse.jface.action.Action
public static void OpenEditor ( String sName,
iEditorInput TheEditorInput)
Event wMyEventData = new Event ();
wMyEventData.data = TheEditorInput;
twActionOpenEditor wActionOpenEditor
= (twActionOpenEditor) mActionCatalog.get (sName);
if (wActionOpenEditor != null)
wActionOpenEditor.runWithEvent (wMyEventData);
else
InfoEditorInexistant (sName);
public static void CloseActiveEditor ()
IWorkbenchPage WorkbenchPage
= PlatformUI.getWorkbench ()
.getActiveWorkbenchWindow ()
.getActivePage();
if (WorkbenchPage == null)
return;
WorkbenchPage.closeEditor (WorkbenchPage.getActiveEditor(), false);
The Exception
strip.runtime.cStripRuntimeFactory.GenericMethodCall(cStripR untimeFactory.java:32)
strip.runtime.jface.cTwingTableDoubleClicListener.mouseDoubl eClick(cTwingTableDoubleClicListener.java:43)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at wwprogres01.intro.Application.start(Application.java:20)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.IllegalAccessError: class
sun.reflect.GeneratedConstructorAccessor73 cannot access its superclass
sun.reflect.ConstructorAccessorImpl
at sun.misc.Unsafe.defineClass(Native Method)
at sun.reflect.ClassDefiner.defineClass(ClassDefiner.java:45)
sun.reflect.MethodAccessorGenerator$1.run(MethodAccessorGene rator.java:381)
sun.reflect.MethodAccessorGenerator.generate(MethodAccessorG enerator.java:377)
sun.reflect.MethodAccessorGenerator.generateConstructor(Meth odAccessorGenerator.java:76)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:30)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at org.xml.sax.helpers.NewInstance.newInstance(NewInstance.java :51)
org.xml.sax.helpers.XMLReaderFactory.loadClass(XMLReaderFact ory.java:187)
org.xml.sax.helpers.XMLReaderFactory.createXMLReader(XMLRead erFactory.java:180)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:311)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:464)
strip.dombuilder.cDOMTreeBuilder.BuildDOMTreeUsingSAX(cDOMTr eeBuilder.java:143)
strip.GUI.ECLIPSE.editors.cEclipseEditor.PrologueEclipseEdit or(cEclipseEditor.java:139)
at strip.GUI.ECLIPSE.editors.cEclipseEditor.init(cEclipseEditor .java:240)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
strip.GUI.ECLIPSE.twActionOpenEditor.runWithEvent(twActionOp enEditor.java:99)
at strip.GUI.ECLIPSE.twActionFactory.OpenEditor(twActionFactory .java:56)
wwprogres01.BRAIN.SearchPersonBrain.TblDataOnDoubleClic(Sear chPersonBrain.java:111)
... 32 more
Re: java.lang.reflect.InvocationTargetException when Opening Editor [message #323677 is a reply to message #323674] Sat, 05 January 2008 13:43 Go to previous messageGo to next message
It's nothing to do with resources, here is where your problem is:
See why you are getting this exception (google it) in setting up your
editor.
Richard Desbiolles wrote:
> ... and so on.
> / open executions.
> Any idea ?
> Thanks in advance.
> Richard
> avec
> else
> .getActivePage();
> return;
> The Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
Re: java.lang.reflect.InvocationTargetException when Opening Editor [message #323687 is a reply to message #323677] Sun, 06 January 2008 02:20 Go to previous messageGo to next message
Thanks for the response.
However, the point is that the same process works ten ou twelve times
before failing and throwing this exception.
I suspect a previous non caught exception occurs(default memory, ... ? )
but I don't know how to diagnose which one.
Richard
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> editor.
>> ... and so on.
>> close / open executions.
>> Any idea ?
>> Thanks in advance.
>> Richard
>> avec
>> else
>> .getActivePage();
>> return; WorkbenchPage.closeEditor
>> The Exception
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> superclass sun.reflect.ConstructorAccessorImpl
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 32 more
Re: java.lang.reflect.InvocationTargetException when Opening Editor [message #323691 is a reply to message #323687] Sun, 06 January 2008 10:04 Go to previous messageGo to next message
I would start by trying to understand why you are getting the exception
you see rather than speculate about what might be happening that you
don't see. That could give you some more data as to why it only happens
intermittently.
> Richard
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> editor.
>>> Hi,
>>> ... and so on.
>>> Any idea ?
>>> Thanks in advance.
>>> Richard
>>> avec
>>> else
>>> } public static void CloseActiveEditor ()
>>> .getActivePage();
>>> The Exception
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 32 more
Re: java.lang.reflect.InvocationTargetException when Opening Editor [message #323747 is a reply to message #323691] Mon, 07 January 2008 11:14 Go to previous message
thanks to try help me, but take a look to
'Not related java.lang.reflect.InvocationTargetException' entry.
regards
Richard
> intermittently.
>> ) but I don't know how to diagnose which one.
>> Regards,
>> Richard
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> editor.
>>>> Hi,
>>>> ... and so on.
>>>> Any idea ?
>>>> Thanks in advance.
>>>> Richard
>>>> avec
>>>> else
>>>> .getActivePage();
>>>> The Exception
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
Previous Topic:Creating a new project type and it's wizard in new -->project --> <project_type>
Next Topic:Not related java.lang.reflect.InvocationTargetException
Current Time: Sat Jul 12 10:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.05113 seconds
