Home » Eclipse Projects » Eclipse Platform » Question about FilteredItemsSelectionDialog
Question about FilteredItemsSelectionDialog [message #323638] Fri, 04 January 2008 11:19 Go to next message
I'm writing a dialog that extends
org.eclipse.ui.dialogs.FilteredItemsSelectionDialog and I have a
requirement to pre-select items in the list. I see that I can call
setInitialSelections() inherited from
org.eclipse.ui.dialogs.SelectionDialog but it appears that is not used
by FilteredItemsSelectionDialog.
Is there any way to set the selection of the viewer in
FilteredItemsSelectionDialog?
TIA,
Eric
Re: Question about FilteredItemsSelectionDialog [message #323655 is a reply to message #323638] Fri, 04 January 2008 13:34 Go to previous messageGo to next message
Off the top of my head, I would create a subclass and override
createDialogArea, and then just call setSelection() to whatever value
the initial selection is set to since the viewer is up at that point.
I would also file a bug on this; the FilteredItemsSelectionDialog should
respect this.
> TIA,
> Eric
Re: Question about FilteredItemsSelectionDialog [message #323741 is a reply to message #323655] Mon, 07 January 2008 10:36 Go to previous messageGo to next message
The TableViewer is private with no getter method, so a subclass has no
reference to it.
> respect this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214491
>> TIA,
>> Eric
Re: Question about FilteredItemsSelectionDialog [message #323756 is a reply to message #323741] Mon, 07 January 2008 13:45 Go to previous messageGo to next message
Oops, the setSelection() that I saw was in an inner class. Sorry.
> reference to it.
>> should respect this.
>>> used by FilteredItemsSelectionDialog.
>>> TIA,
>>> Eric
Re: Question about FilteredItemsSelectionDialog [message #323765 is a reply to message #323638] Mon, 07 January 2008 19:16 Go to previous messageGo to next message
Have a look at FilteredResourcesSelectionDialog.open(). It sets the
initial selection by setting the pattern (it gets the selection from the
window). I think this will do what you want. Sorry for the earlier red
herring.
> TIA,
> Eric
Re: Question about FilteredItemsSelectionDialog [message #894462 is a reply to message #323765] Mon, 09 July 2012 06:20 Go to previous message
Any update on this topic?
Previous Topic:FilteredItemsSelectionDialog - refreshing content provider
Next Topic:error creating a JPA project
Current Time: Sun Jul 13 01:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.03821 seconds
