Home » Eclipse Projects » Eclipse Platform » Invalid Thread Access during DebugUIPlugin.start()
Invalid Thread Access during DebugUIPlugin.start() [message #323614] Thu, 03 January 2008 17:22 Go to next message
Originally posted by: david.c.pace.gmail.com
In my RCP application (based on Eclipse 3.3), if I hover over some text
in my editor and the org.eclipse.debug.ui plugin has not yet been
activated, I get an Invalid Thread Access SWTException.
My editor's ITextHover calls DebugUITools.getDebugContext() when
determining what hover text to display. It does not do this on the UI
thread.
Because the plugin has not been activated at this point, the bundle
activation is started from a non-UI thread and the SWTException is thrown.
Should the DebugUIPlugin.start() method be making any calls that require
the UI thread?
It seems like this is a bug similar to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=79757.
Below is the stack trace from the DebugUIPlugin.start() method call.
The invalid access comes from the default preference initializer.
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.swt.widgets.Display.error(Display.java:1137)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:666 )
at org.eclipse.swt.widgets.Display.getSystemColor(Display.java: 2129)
org.eclipse.debug.internal.ui.DebugUIPreferenceInitializer.i nitializeDefaultPreferences(DebugUIPreferenceInitializer.jav a:79)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.runInitializer(PreferenceServiceRegistryHelper.jav a:276)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelp er.java:130)
org.eclipse.core.internal.preferences.PreferencesService.app lyRuntimeDefaults(PreferencesService.java:337)
org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:163)
org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:236)
org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:232)
org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:543)
org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
org.eclipse.core.runtime.preferences.DefaultScope.getNode(De faultScope.java:67)
org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:247)
org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:281)
org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:471)
org.eclipse.ui.preferences.ScopedPreferenceStore.getString(S copedPreferenceStore.java:531)
org.eclipse.debug.internal.ui.launchConfigurations.Perspecti veManager.initPerspectives(PerspectiveManager.java:947)
org.eclipse.debug.internal.ui.launchConfigurations.Perspecti veManager.startup(PerspectiveManager.java:252)
org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlu gin.java:499)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
-Dave
Re: Invalid Thread Access during DebugUIPlugin.start() [message #323623 is a reply to message #323614] Fri, 04 January 2008 06:42 Go to previous messageGo to next message
Dave,
I'm surprised that DebugUIPlugin.start would do things that require
being on the GUI thread. Maybe that's necessary but it seems like a
problematic thing. It seems the other bug was fixed though, so maybe a
new such issue has crept back in, so perhaps that's worth another
bugzilla. It might be best to have DebugUITools.getDebugContext() be
called on the UI thread to avoid the problem (or at least call it there
once to force bundle activation)...
Dave Pace wrote:
> Hello,
> text in my editor and the org.eclipse.debug.ui plugin has not yet been
> thread.
> thrown.
> require the UI thread?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> -Dave
Re: Invalid Thread Access during DebugUIPlugin.start() [message #323667 is a reply to message #323623] Fri, 04 January 2008 18:17 Go to previous message
Thanks for the quick response Ed.
I filed a bug but it was a duplicate of a bug 193317 that had been fixed
in 3.3.1. We'll upgrade our target platform to 3.3.1 to resolve the issue.
thanks,
Dave
Ed Merks wrote:
> Dave,
> Dave Pace wrote:
>> Hello,
>> thread.
>> thrown.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> -Dave
Previous Topic:Debugger very very slow.
Next Topic:Mac OS X specific problem reading @WebService annotation
Current Time: Fri Jul 18 17:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.27415 seconds
