Home » Eclipse Projects » Remote Application Platform (RAP) » Perspective ext. point is not recognized under M4
Perspective ext. point is not recognized under M4 [message #32737] Wed, 13 June 2007 06:13 Go to next message
After downloading & installing M4 target 3.3, I encounter message Unknown
extension point: 'org.eclipse.ui.perspectives' from manifest editor.
When I open ext. point lists, I only find
org.eclipse.rap.ui.workbench.org.eclipse.ui.perspectives, which is
definitely wrong perspective ext. point ID.
If I set the ext. point to the one above, message from manifest editor
dissappears, but when I run the application, a dialog box with similiar
message popups.
I also encounter similiar message with view ext. point.
Do we have plugin conflict here ?
Setya
Re: Perspective ext. point is not recognized under M4 [message #32840 is a reply to message #32737] Wed, 13 June 2007 06:28 Go to previous messageGo to next message
i just downloaded a fresh 3.3 target from the website and it's working
without any problem.
Did you follow the installation guide on the downloads page
(http://www.eclipse.org/rap/downloads.php) how to use the target?
Be sure that you _didn't_ install the target on top of your existing
eclipse installation. This will not work.
If that doesn't help, you could tell us how to reproduce the problem.
Cheers
Benny
Setya wrote:
> Unknown extension point: 'org.eclipse.ui.perspectives' from manifest
> editor.
> message popups.
> Setya
Re: Perspective ext. point is not recognized under M4 [message #32983 is a reply to message #32840] Wed, 13 June 2007 08:58 Go to previous message
I downloaded then extracted it to a folder, then I point the target
platform to that folder just as instructed in the installation guide. No,
I did not extract anything to existing eclipse installation, but I did
delete previous installation of M3. I also tried adding -clean when I
start Eclipse, but it didn't work.
Here's the message in the log file:
!SESSION 2007-06-13 20:22:21.515
eclipse.buildId=unknown
java.version=1.4.2_10
Command-line arguments: -dev
file:E:/Projects/SDI/workspace/.metadata/.plugins/org.eclips e.pde.core/Soltius
Core/dev.properties -os win32 -ws win32 -arch x86 -console -clean
!ENTRY org.eclipse.core.runtime 2 0 2007-06-13 20:22:22.796
!MESSAGE Authorization infrastructure
(org.eclipse.core.runtime.compatibility.auth) not installed.
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
org.eclipse.core.internal.runtime.InternalPlatform.initializ eAuthorizationHandler(InternalPlatform.java:603)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:745)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:31)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.MultiSourcePackage. loadClass(MultiSourcePackage.java:31)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.rap.ui.workbench 2 0 2007-06-13 20:22:32.031
!MESSAGE Warnings while parsing the commands from the
'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension
points.
!SUBENTRY 1 org.eclipse.rap.ui.workbench 2 0 2007-06-13 20:22:32.031
!MESSAGE Commands should really have a category:
plug-in='org.eclipse.rap.ui.workbench',
id='org.eclipse.ui.views.showView',
categoryId='org.eclipse.ui.category.views'
Setya
Previous Topic:Server Sie Log
Next Topic:why my rap demo doesnt run ?
Current Time: Fri May 09 08:10:42 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
